Old 9th February 2009, 23:32   #1
Thanked: 23 Times
Default MM550 rebuild - new engine ?
Some of you may know but I became the owner of a 2001 MM550 last week (army disposal). I had not started a new thread as I do not have any pictures.
I encountered the first big decision in the rebuild. The mechanic took the engine out etc and had a good look at it. It is not in very good condition and he says it will cost at least RS18K to get it into running condition (fuel pump etc needs work, head is not in good condition etc etc).
However he can get a 2003/4 Bolero XD3P engine which is in excellent working order. The chap want RS12K for it, having studied actuarial science etc my brian tells me it is better (financially) to go for the 2003/4 engine. He says the gearbox/transfer case look fine and they will mate with the new engine without any problems. I will get him to change belts, tensioners etc for peace of mind.
I have asked my cousin to contact a place in Punjab where they buy army disposals to check if they have any later MM550 engines with the 5 speed box.
So please can anyone point out any negatives of going for the 03/04 Bolero engine ? I know the army version has an oil cooler and a few extra bhp but besides that are there any other major differences ?
Thanks in advance.
bigman is offline   Reply With Quote
Old 9th February 2009, 23:42   #2
Thanked: 660 Times
WHen you bought! it was not even in working order.?
12k for that engine is a steal. But i guess he will want this engine in exchange.
I would recommend you to do and post here the compression test data. So that we can be sure of the condition of your engine.
PS: some images please.
Old 9th February 2009, 23:55   #3
Thanked: 23 Times
Thanks for your quick reply Alec.
Nope not in working order. These army disposals are rarely in working order. Chassis and body are in excellent condition though. The gearbox and transfer case appear to be fine as well.
Yes thats with the current engine in exchange but I could pay a bit more and keep it if I want.
Are there any negatives to using the newer Bolero XD3P ? Also how much is it for brand spanking new XD3P ? I have asked him to start the 03/04 engine and make sure it is in decent condition etc.
I asked my old neighbour to take some pictures but he has not bothered yet. Strange how when he needs help/favours he is willing to do anything, I guess thats human nature.
Old 10th February 2009, 00:22   #4
4x4addict's Avatar
Thanked: 2,668 Times
I think you should get the Bolero engine if it in good condition. Make sure you remove the oil cooler from the army engine and transfer it to the Bolero engine. These engines are identical except that the army version is tuned output 75 bhp as opposed to 72 pre bsII or 68 for bs II for the Bolero version. I am sure that you can adjust the fuel pump to get the same output as the army version. The army version also has the oil cooler. Other than these two changes, they are the same engines.
New one costs upward of 2 Lakhs. GTO did get one for his Classic.
4x4addict is offline   Reply With Quote
Old 10th February 2009, 01:27   #5
Thanked: 23 Times
Thanks for that 4x4addict.
I will tell him to take it off and fit to the Bolero engine.
Whereabouts is the oil cooler on the MM550 engine ?
Old 10th February 2009, 02:14   #6
4x4addict's Avatar
It is placed between the engine and the oil filter. There is a pipe that runs water from the radiator through the cooler.
Old 10th February 2009, 02:28   #7
Thanked: 23 Times
Thanks for that. I have passed on the message to keep the oil cooler.
Just got to wait to see if the army disposal guy has a working engine with a 5 speed box and transfer case before buying the bolero unit.
Old 10th February 2009, 11:53   #8
randeep04's Avatar
Thanked: 16 Times
Hey Satnam,
Congrats on your new purchase. Waiting for some pics brother. keep pestering your neighbor so that he does take the pics and sends them to you.
Cheers and all the best !!!!!!!
randeep04 is offline   Reply With Quote
Old 10th February 2009, 22:08   #9
Thanked: 23 Times
Thanks guys.
He got the bolero engine delivered (not paid for yet) and he says he is going to start it etc before he commits to buying it.
How far gone would an engine have to be before it is beyond use. If the sump & head are ok and the fuel pump can be calibrated then it should be ok ....?
Maybe the mechanic is looking for the quickest and cheapest option. I will give him a ring and ask him exactly what is wrong with the original engine.
I am going to keep the original engine as well and get a second opinion on it. They were not giving much for it anyway and it can sit in our garage rather instead of a scrap merchants yard.
Old 11th February 2009, 13:51   #10
TheARUN's Avatar
Thanked: 498 Times
Its a very good idea to keep the old engine.
What I usually do is keep the old parts and then open them up and experiment, put them back again and get the general know-how, anyways it can be sold as scrap later.
Its a very good idea to keep the old engine, and open it up and re-assemble it on your own, awesome education at very less fees
TheARUN is offline   Reply With Quote
Old 11th February 2009, 21:13   #11
Thanked: 37 Times
two things i always check about engines may be it can help you..
1),Remove breather pipe and lift engine oil dip stick. accelerate the engine to maximum and check any fumes or smoke coming out through both places. hold your hand above breather hole and check the suction power.
If smoke is coming or you don't feel any suction power.. you may need new set of rings and sleeves.
2). reduce the engine idling speed to minimum as possible ( use screw on Fuel Pump) check for any abnormal Knocking sound . if it is there trouble with bearings
Its always advised to check the calibration of fuel pump when you buy vehicle or engine ( diesel) above 75k kms
All the best
toms_2191 is offline   Reply With Quote
Old 12th February 2009, 11:37   #12
Thanked: 4,736 Times
Please do let me know if your MM540 originally came with the XDP4.90 or the XD3P. If XDP4.90, then the cooling system will need to be upgraded to work with the extra power of the XD3P. As the engines are from the same family, mountings are identical but check for engine mounting bracket orientation as there are a lot of dress levels in use. Please post some photographs for detailed reply.
Best regards,
Behram Dhabhar
DHABHAR.BEHRAM is offline   Reply With Quote
Old 12th February 2009, 13:01   #13
Thanked: 23 Times
Thanks for replies guys.
Behram Dhabhar, it did have a stock xd3p engine. Sadly no photos yet, I am in England and my neighbour does not appear to be compliant with my requests. I will have to wait till my father goes over in a few weeks.
I was looking at rear lights and came across Land Rover NAS lights which are round. Can anyone suggest if anything similar or better is available in India ? My only concern is that of sufficient mounting space, they are 100mm in diameter. They can be flush mounted quite easily. Also military spec ones (NATO) are available which are meant to be tougher.
Old 13th February 2009, 13:51   #14
harjeev's Avatar
Thanked: 256 Times
Satnam
Congrats on you purchase. As everyone, me too eagerly awaiting for the pics.
On the engine swap if I were you I would be more comfortable spending 18k on refurbishing the older engine as
1. If you change the engine then it would not match the engine number on the registration book and this may/can create problems later on.
2. The 12k engine that you are buying, how can you be sure that that engine is not in the same or a worse condition than the one you already have? These engine can be started even with spending very less money and also consider that the person selling you the 12k engine would also be earning something out of it.
3. If you spend 18-20k on the old XD3P engine, it would definitely be more reliable than the 12k engine you are buying as any faulty parts that there might be, would be replaced with new ones.
I have just written what I would do and you should do what feels right to you. Just my 2 cents
Harjeev
harjeev is offline   Reply With Quote
Old 13th February 2009, 14:30   #15
Red Liner's Avatar
Thanked: 1,474 Times
This is pretty interesting... I am at the cross roads of doing a rebuild myself (white smoke + burning eyes)...and I was thinking about the XD3P 2.5 Ltr...will keep my eyes peeled here.
I will agree with Harjeev here...when you do a rebuild you get almost a bone-stock new engine and you will know exactly what you've done to it. The trick is to ensure whoever is doing the re-bore knows what they are doing. If the rebore is done well, then the engine should give you top notch performance for the next 100k kms - provided you take good care of the engine.
But the 2.5 Ltr engine is more refined and offers about 15kgm of torque as opposed to the 12.3 kgm of torque from the XDP 4.90 engine. The DI Turbo would be the best bet. 18 kgm torque at 1440 RPM. Superb.
A rebuild should come to between 20 and 25k. Lets wait to hear what others have to say too. Then I will also make a decision.
Red Liner is offline   Reply With Quote
"Heart Over Mind" 2001 MM550 XD - Rebuild sreejeshmp 4x4 Vehicles 129 1st August 2013 22:46
2lac+ kilometers m800 engine rebuild project. SirAlec Modifications & Accessories 75 24th June 2013 17:36
Help required for a Pajero Engine Rebuild breakneck 4x4 Vehicles 26 13th June 2013 11:45
Gyspy Engine Overhaul / Rebuild jealousdiamond 4x4 Vehicles 13 2nd February 2010 12:23
Sluggish Accent CRDI after engine rebuild. clipto333 Technical Stuff 30 10th March 2008 23:44
