Old 23rd January 2011, 12:32   #136
Thanked: 825 Times
Default Re: Is Independent Front Suspension (IFS) good for offroading?
For those who are further interested ,these are the links for MAZ category vehicles .
Links http://www.janes.com/articles/Janes-...ederation.html
http://www.eilatgordinlevitan.com/pi...hapashnik.html
http://www.militaryphotos.net/forums...p/t-74830.html
You can go into details if you want to ,with these links .
Also want to share few pics have a look this IS IFS
Well I have to admit that this is really interesting
Sudarshan
Last edited by GTO : 25th January 2011 at 17:25. Reason: Removing FONT Tags. Please do NOT cut-copy-paste text from other word softwares. It results in a formatting error.
Sudarshan is offline   Reply With Quote
Old 24th January 2011, 01:30   #137
desertfox's Avatar
Thanked: 549 Times
Since I regularly travel same stretch of bad roads in both solid axle & IFS 4WD vehicles, I can probably contribute my 2 cents.
Since most of these are familiar stretch of bad roads (there is no other kind around here), I do make full use of these high GC vehicles and drive fast. In certain rough stretches, the Jeep literally floats above the roads without any trace of traction. I simply have no control over the vehicle at this point. The same stretch on GV, at even higher speed the vehicle remains glued to the road and I don't lose traction. If such stretch occurs in a curve, I really slow down in the Jeep, but can easily turn in the GV without slowing down.
In my experience GV being a IFS 4WD is a much better trail or bad road vehicle, way superior to solid axle CJ340. But when it comes to rock crawling and offroad hill climbs, the roles reverse completely. On bad roads CJ340 can follow the GV, albeit much slowly. But when it comes to rock crawling, slush or hill climbing, CJ340 leads and GV can't even follow.
During a hard core off road session in the heat of August 2006, look what happened.
desertfox is offline   Reply With Quote
Old 24th January 2011, 06:50   #138
Thanked: 825 Times
interesting , ( though very much Sad ) ,but can you explain when did it exactly happen ?
also will be interesting to know as to what was revealed at the time of repairs , because it will shed some light as to what is the weakest link in this particular vehicle ( TLC Prado ? )
Sudarshan
Old 24th January 2011, 23:04   #139
desertfox's Avatar
Thanked: 549 Times
It was a tough Dune climb. The Inclinometer on my Prado showed over 30 degree and the sand was soft. The base of the dune was badly rutted.
I deflated to 12 psi, took a run from 250 yards in L with 4 H engaged and central diff lock engaged.
The Vehicle was at 40 kmph at the base of the dune and 4500 rpm. It hit the rut with a loud thud but it went up the dune where Range rovers, Jeep Wranglers and Nissan Patrols had failed. I turned the vehicle on the dune top and on descent the vehicle swerved to the right and went down to the ground. The ball joint had broken. There had been some funny metallic sounds earlier in the morning too.
Cost of recovery by 8x8 Truck Rs. 25,000.
Cost of repairs Rs. 75,000 odd!
After repairs I swapped the vehicle with a friend for a M/T SWB 3 Door Prado with the same 5VZFE 3400 V6 engine. This too was full time 4WD with central diff locks and rear LSD.
desertfox is offline   (1) Thanks Reply With Quote
Old 24th January 2011, 23:17   #140
desertfox's Avatar
Thanked: 549 Times
Some Pics when this car was modified with Nitro Shockers, ARB bumper and Old Man EMU Extra Duty heavy coil springs
Old 26th January 2011, 09:34   #141
headers's Avatar
Thanked: 464 Times
Suggests you had a weak joint before the incident. Glad there are no injuries to anyone.
Drive safe
Old 28th January 2011, 22:14   #142
desertfox's Avatar
Thanked: 549 Times
No injuries, only damage, all in the dangerous game we off roaders play!
Old 18th March 2014, 12:06   #143
Default Solid Axle Coil Spring 4WD Vehicle In India
Why wouldn't they make 4WD vehicles with Solid Axle & Coil Springs upfront?
-Jai
sunwarior is offline   Reply With Quote
Why are car makers abandoning independent rear suspension? directinjection Technical Stuff 35 31st January 2017 01:57
Need a good mechanic/Independent garage for Palio 1.6 - Hyderabad windsurfer Indian Car Dealerships 26 28th October 2016 20:25
Mahindra Thar - *Converted* Independent Front Suspension to Solid Axle Jaskirat 4x4 Technical 72 10th October 2013 14:01
Can we swap the Thar's IFS with the MM550's rigid axle? jeepbug 4x4 Technical 17 5th June 2012 10:46
IFS-Upsc smilenow Shifting gears 9 5th August 2009 14:23
