Old 15th January 2012, 22:09   #16
vak
Thanked: 43 Times
Default Mahindra OE pintle hook on Bolero
I have fitted a Mahindra OE pintle hook on my Bolero Di 4wd. It was mounted on a military MM550 pintle mount plate. Silencer tail pipe was cut and bent for the fitment of mount plate
vak is offline   (2) Thanks Reply With Quote
Old 1st February 2012, 17:01   #17
Thanked: 61 Times
Default Re: Mahindra Parts Database
Originally Posted by jeepster View Post
yes i have one gypsy pintle hook which i want to install.
Attachment 601122
Attachment 601123
please tell the necessary steps involved instead of hints.
rgds,
Nikhil
Nikhil, please can you share pictures of the pintle hook after fixing to your Armada ? I have a ditto pintle hook and would like it on my 99' Armada Grand 4x4
charan is offline   Reply With Quote
Old 3rd February 2012, 10:18   #18
jeepster's Avatar
Thanked: 1,036 Times
hi,
i have not installed it as NGCS chassis dosnt have a K member which helps to distribute the load evenly.
so i (we ) need a PLATE to strengthen the cross member just as vak has done to his bolero.
so use a MM540/550 or Thar Plate, simple .. ahh not quite !!
see these pics
Name:  DSC07194 Medium.JPG
Name:  DSC07195 Medium.JPG
Name:  DSC07196 Medium.JPG
Compare them with these , you will see the problem.
BTW i am thinking (still thinking ) to make a custom rear bumper with a beefy L ot C channel to support the rear cross member.
rgds,
Nikhil
jeepster is offline   (1) Thanks Reply With Quote
Old 3rd February 2012, 10:57   #19
ex670c's Avatar
Thanked: 1,821 Times
hi,
Hi Nikhil,
I cannot see what is the problem, please elaborate for inexperienced members like me.
Arka
Old 3rd February 2012, 12:33   #20
starter's Avatar
Thanked: 327 Times
Originally Posted by ex670c View Post
Hi Nikhil,
Arka
Hey Arka,
When you look at the first or the second picture in Nikhil's post, he is trying to match the holes on the pintle hook with the holes on the rear member. Only one set of holes match, but the other two holes are off.
I am not really sure, but i guess this is what he points to as the problem.
And no, i am not elaborating because you are an inexperienced member
Cheers,
Deepak
starter is offline   (1) Thanks Reply With Quote
Old 3rd February 2012, 17:14   #21
ex670c's Avatar
Originally Posted by starter View Post
Hey Arka,
Hi Deepak,
Post 1993 the K-Member was removed, and 4WD vehicles had a plate to reinforce the Cross-member.
The MM550XD Plate or the Commander 750 Plate works better with the older vehicles.
Arka
ex670c is offline   (2) Thanks Reply With Quote
Old 4th February 2012, 10:08   #22
jeepster's Avatar
hi Arka,
bache ki jan loge kya ?
hi Deepak,
you are correct.
see this pic.
if i fit the pintle hook like this it will hit body when i open it.
here
i cant drill hole in this position.
so i have to buy a new plate & drill the holes according to it. (red)
thanks.
jeepster is offline   Reply With Quote
Old 16th February 2012, 13:51   #23
vak
Thanked: 43 Times
yes gypsy dose have similar plate in army version.
Attachment 510363
Attachment 510364
Dear Jeepster,
My Bolero 4wd had four holes at the rear cross member. The holes were welded with a small tube in each holes, going all the way to the other side of boxed section of the cross member. Please check the photo. I have used the military MM 550 pintle mount plate.
Vinshad Aziz
vak is offline   (1) Thanks Reply With Quote
Old 21st February 2012, 12:10   #24
vak
Thanked: 43 Times
[quote=jeepster;2668307]
Dear Jeepster,
I have built and fitted a custom rear bumper on my Bolero 4wd. I thought this will be helpful for you.
It is not a full bumper but one in two pieces, similar to the OE bumper, but stronger. I went for the two piece design, as I didn't want to fit the pintle hook on the bumper. Moreover fitting pintle hook on bumper will compromise the departure angle. The bumper was made using four inch C channel. The bumper is strong and can be used for lifting the vehicle using a Hi-lift jack. The bumper is fitted on a improvised mount made of 6m steel. Picture shall be uploaded later.
Spare Parts - Sundar Auto Parts (Worli, Mumbai) aah78 Mumbai 1 9th June 2010 12:46
Database Errors Gordon Shifting gears 5 18th December 2004 10:00
Database of Car Chases in movies GTO The International Automotive Scene 0 15th September 2004 21:35
