Old 29th August 2010, 22:51   #226
Jaggu's Avatar
Thanked: 8,685 Times
This time LT broke and then right cracked. Khan has the broken leafs with him now, so he should be able to post better pictures.
Old 30th August 2010, 20:54   #227
Thanked: 2,403 Times
@ Spike - Why am I getting the feeling that MM is experimenting with CFLS. Right or wrong?
Sutripta
Old 30th August 2010, 21:55   #228
SPIKE ARRESTOR's Avatar
Thanked: 809 Times
I wanted to see if there is a similarity in failure pattern, how did it shear off etc. Why do you have this ^^ feeling?
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 31st August 2010, 13:01   #229
Desmosedici's Avatar
Thanked: 410 Times
spoke with Dr Pawar.
I didnt know that there were 2 types of CFLs available, one for hardtop and one for soft top.
Desmosedici is offline   Reply With Quote
Old 31st August 2010, 13:49   #230
starter's Avatar
Thanked: 327 Times
Really? The difference in the weight between hard and soft top variants is just 35 Kgs!
Is there any other factor which might force them to make a different CFL for hard-top variant?
starter is online now   Reply With Quote
Old 31st August 2010, 14:00   #231
Thanked: 410 Times
thats the only difference Dr Pawar mentioned, to take care of the additional 50 odd kgs. Sounded a bit strange to me that for a 50 kg payload we would have 2 sets of CFLs. Anyways i am going to go for the hardtop CFL, as i plan to fabricate a partial hardtop made of metal.
Cost is 10K
Old 31st August 2010, 20:32   #232
Spike
To Diplomat/ Lawyer/ Politician Prateesh,
So in absence of a definite answer, I take it as a yes.
Sutripta
Old 1st September 2010, 06:55   #233
Thanked: 1,498 Times
Cost is 10K
Strange is not the word, it sounds like a very silly statement to make, which leads one to casts doubts about whether the man knows what he is doing.
I would make the call on the basis of the load you will run the car with. 4 passengers plus luggage in addition to 2 in front would mean 300 kilos more load than just one/two up. I would think that the harder version would be better for loaded car use, while the softer version would work better if you used the car without load much of the time.
Basically though it is the garage/jugaad nature of this solution that has kept me away from it so far.
Sawyer is offline   Reply With Quote
Old 12th October 2010, 13:43   #234
Thanked: 56 Times
Originally Posted by khan_sultan View Post
I guess I spoke tooo soon . I broke the 3rd set this weekend in the Sowmerpet trail.
The front left leaf broke/snapped at the point where the rear joint is. I was reversing the tyre over a 2ft boulder and it could not take the compression (-ve compression force) applied. I don't know if the -ve camber ability of these is adequate. Also, once the front left broke, the front right also could not take load and started splintering.
Sir is it possible that the leaf broke because of axle wrap? As you were reversing the front axle was experiencing the same stress which the rear one does in forward motion.
Do you have a traction bar for the front axle also?
autoholic is offline   Reply With Quote
Old 21st October 2010, 06:38   #235
Default Leaf under AND over Axle
This is my first post, but been lurking here for a few months. Just shifted to bangalore from california and looking to start a restoration project of some kind.
Khan_Sultan - In one of the events, I have seen a leaf set up for a samurai with a CFL over the axle AND a single leaf under the axle as well on extended shackles. The shackle was modified to accomodate both the leafs, with the leaf under the axle playing a secondary role after the cfl leaf absorbs the initial impact.
I have seen this set up in tractors and heavy trucks, where there are leafs under and over the axles on two sets of shackles to acoomodate the load. The samurai version was done with a analogous but different objective - to support the cfl beyond a certain point.
Could this be an implementable idea in a DIY effort? This could be a potential model for the front axle cfls so that the extra torsions are absorbed and gives insurance/peace of mind as well.
PP
gadgetman is offline   Reply With Quote
Old 21st October 2010, 13:49   #236
khan_sultan's Avatar
Thanked: 3,872 Times
Originally Posted by gadgetman View Post
Khan_Sultan - In one of the events, I have seen a leaf set up for a samurai with a CFL over the axle AND a single leaf under the axle as well on extended shackles. ....
Could this be an implementable idea in a DIY effort? ...
Interesting. Well, do you have any pictures of sketches of this setup? I would be willing to try this out and ready to experiment if we have the sketches. In absence of the pictures it becomes very difficult to explain to the fabricators here .
Am game.. -- especially for the front, as I have the rear sorted out already.
khan_sultan is offline   Reply With Quote
Old 23rd October 2010, 06:53   #237
khan_sultan - Unfortunately, I dont have pictures. I will describe as best as I can remember, it seemed simple enough!
1. perches on top and bottom of axle - seating the CFL leaf on top as SPOA and the single steel leaf on bottom as SPUA.
2. A pair of C bolts (rather than U) holding everything together
3. The steel leaf was a high arch version. It wasnt heavy duty as its purpose was as a secondary support. The CFL had a modest postive camber.
4. The distance between the perch surfaces for the leafs was about 3 inches.
5. The shackles bushings on each side of the leaves was on plates about 5-6 mm thick welded to chasiss beam.
6. The plates had multiple holes about 1 inch apart to change bushing placement, suggesting it was a bit of trial and error. I would say the distance between bushings was about 3-4 inches.
7. The steel leaf was on a single shackle on the front
I guess the the high arch of the SPUA steel leaf, its (longer) length and the shackle placement and the hang length of the shackle determines when the secondary leaf starts to take the load after the initial load absortion of the primary leaf. Will see if i can sketch this out but on the road through next week so may be delayed.
I will PM you for your contacts.
PP
Old 14th January 2011, 13:05   #238
mooza's Avatar
Thanked: 271 Times
Default Re: Composite Fibre Leaf Springs: Can they be used for off-roading?
In case of the conventional steel multi-leaf springs, one can vary the stiffness by adding or removing a leaf, according to the requirements. But this may be difficult to do with a composite leaf spring.
However, I wonder whether it could be possible to have an arrangement which I have thought of (depicted crudely below without the camber angles etc. by using Paintbrush to the best extent!) :
In case a softer ride is required, just move the shackles to the outer holes. Maybe longer shackles will be needed at the outer holes to maintain the ride height / bump stop clearances.
To go a step ahead, instead of the extra holes, one could also have a slot with suitable packing (to fill up the extra slot volume) to have the hinge point at any desired length, to offer a wide variety of spring rates.
Some thoughts on this would be welcome
mooza is offline   Reply With Quote
Old 11th February 2011, 12:15   #239
Paco's Avatar
Thanked: 19 Times
Has someone installed CFLs at the rear-end Ford Endy and has done Leh? How has been the drive. I intend to do the same this year (from Mumbai) with luggage in the rear and 4 healthy people in the car. If it works, i.e., the ride improves and the durability doesn't get impacted negatively, then I would like to look for it. How much would they cost and where could one get it in Mumbai?
Paco is offline   Reply With Quote
Old 2nd April 2011, 19:42   #240
Thanked: 113 Times
I am being quoted 14k for front and rear of Gypsy for a total of 28k by ARC here. That's a 40% increase over the 10k price quoted to Desmo in Aug 2010!!
I don't feel it is justified. What are the other options to improve suspension?
--ragul
Edit: just spoke to Dr. Pawar. The width of the leaf has increased to 5" from 2.5. And there is now a supporting plate for the CFLs and also a buffer/bush provided. This is for the rear.
The front is now 3", the max width possible. This change was made in the last 4 months. Another improvement he mentioned in an earlier call is that the leaves now handle stress in upwards and downward directions better (did he mean negative compression stress?). I am no mechanical engineer and a complete dud at all these things. So your elaborations or corrections on the above are welcome.
Ragul is offline   Reply With Quote
Leaf Springs for Mahindra CL500/550 renjithv 4x4 Technical 2 3rd June 2011 10:36
OME Leaf Springs for the Gypsy satan 4x4 Technical 16 2nd June 2011 10:00
Amaron Optima Yellow Top: Can they be used for off-roading? swastikviji 4x4 Technical 40 13th December 2010 06:42
Torsion bar or leaf/coil springs. Which is better ? taurian2804 Technical Stuff 4 9th November 2009 11:07
Happy Birthday Moral Fibre,Oral Fibre,MF Drive,Moral Forboid etc. payam Shifting gears 44 20th November 2007 10:58
