4x4 Technical Engines, Diff-locks, SPoA, Techniques and more
Thread Tools
Old 12th March 2009, 00:08   #16 (permalink)
harjeev's Avatar
Any idea if somebody has installed this setup in northern india especially in/ around NCR.
I am quite interested and would like to see it action?
__________________
  • 2007 Tata Safari 2.2 VTT 4x2
  • 2000 M&M MM550 XD 4x4
  • 1985 M&M CJ3B(RHD) 4x4
  • 1963 WILLYS CJ3B(LHD) 4x4 (In hibernation)
harjeev is offline   Reply With Quote
Old 12th March 2009, 00:16   #17 (permalink)
Originally Posted by khan_sultan View Post
He even mentioned that many Ford Endeavors sold by Lathangi get this setup done.
Interesting! The contact number on the alibaba website is what you used? Or do you have another one?
__________________
Enjoy your dictatorship! I'm outta here
Old 12th March 2009, 07:26   #18 (permalink)
Mpower's Avatar
They don't advise to put thesein the front, as for some reason there seems to be a wobble in few vehicles where they have put it. They want to investigate this and fully test it out before recommending it for the front of the vehicle. They don't want to recommend/sell for the front just for the sake of it.
When you replace a multileaf with monoleaf, you lose lateral stiffless which can lead to poor steering feel and high speed shake/wobble.
#2 consequences of leafspring breakage are lot more lethal up front in terms of safety
__________________
The difference between the men and the boys....................is the speed of their toys.
Old 12th March 2009, 11:05   #19 (permalink)
Sha
Sha's Avatar
Carbon fibre material comes in 1mm thickness, to make one leaf spring at least 10 strips(10mm ) are required to make one leaf spring, All the strips needed to join together using adhesive(depends upon manufacture what adhesive they use). Carbon fibre material are strong but the adhesive which they use is important any vacuum between strips can get cracked or damaged.
__________________
Civic 1.8V 2006 December done 57000 Km.
Swift Vxi(ABS) 2006 November done 44500 Km.
Gypsy 413W 2008 November
Sha is offline   Reply With Quote
Old 12th March 2009, 14:50   #20 (permalink)
swastikviji's Avatar
Originally Posted by Torqy View Post
How much does this cost? 11K per pair / per piece as swastikviji mentioned?
If this can soften the harsh ride of a Bolero, i'm interested. Hope the softness doesn't come with excess body roll.
-- Torqy
Hai
i paid 11.5k for a pair of rear set,i placed the order for My mm 550 its costed me 18k the set what they sent for 550 is not fitting, they sent a 540 set it seems ,they are replacing it within 20th of this month, fixing of spring for 550 within next OTR for this month end as planned, that time i exchange both the vehicles with our senior experts you can expect a detailed report from Mr.Khan by next month.
swastikviji is offline   Reply With Quote
Old 12th March 2009, 19:27   #21 (permalink)
headers's Avatar
In addition to above, the leaf appears to be of same thickness throughout.
Khan, can you check on that issue. The reason i ask you is Omnis come with a single rear leaf spring but are thicker in the center than the edges. And there have hardly been any Omni suspension issues AFAIK.
If it is the same thickness, i would go for it with a pinch of salt as we misuse the vehicle in OTRs.
Originally Posted by swastikviji View Post
Hai
Oh yeah, eargerly awaiting that test..Khan will take it through a couple of rocks to see whether they break! else here i come!
One more issue is that how do we "Re-camber" them?
__________________
Addicted to it - A 4L V8 producing 300+ horses and ...
Old 12th March 2009, 19:49   #22 (permalink)
khan_sultan's Avatar
From the video & info given by the person, these are thick at center (at axle) than the edges (frame mount)
We will get to test them at next OTR when Vijay has his vehicles ready.
From what I have heard -- it won't be required.
__________________
The best way to kill an idea is to take it to a meeting....
khan_sultan is offline   Reply With Quote
Old 12th March 2009, 21:59   #23 (permalink)
Video of the product in action looks promising. but the proof will come on testing it,actually driving it on the highway. There is body roll, but not more than stock as far as I can see on the video.
The video itself was atrocious
__________________
Old 12th March 2009, 22:12   #24 (permalink)
Sankar's Avatar
Yes it is thicker in the center and thinner and wider near the shackles. Long back another Tbhp member, Edmund, had these fibreglass leaf springs in his SS80. I too wanted to do a conversion on my SS80 and googled a lot on the Fibreglass leaf springs, these leafs are not as twist resistant as a conventional steel leaf spring, this could lead to a disadvantage in handling high speed corners, so i dropped the idea. For off roading high speed cornering isn't an issue and shouldn't be a problem.
Sankar is online now   Reply With Quote
Old 12th March 2009, 22:16   #25 (permalink)
@sankar- thats what I'm worried about. Our Endy sees a lot of high speed cornering, lane changing and sideways action.
Thicker anti roll bars to compensate for the fibre leaf springs, will that work?
Anyways, will wait till I try driving one of the endys with these springs.
__________________
Old 13th March 2009, 02:51   #26 (permalink)
Mpower's Avatar
U'll get a lot more twist at max atriculation in an OTR esp with sway bar disconnect.
High speed..you get Gs but not so much twisting.
Recambering is done with heat IIRC so it wont be possible with fiberglass.
Keep it away from hot exhaust pipes.
__________________
Old 24th March 2009, 11:00   #27 (permalink)
Gypsy-Boy's Avatar
Hai
Hi
How did the composites fare in the mini OTR?
Am sure there are lots of people waiting for your report on this.
GB
__________________
Oh God we thank you for
Mud
Rocks
and the rain to make trails challenging!!!
Gypsy-Boy is offline   Reply With Quote
Old 7th April 2009, 17:47   #28 (permalink)
Hi gypsy boy i am 100% satisfied with its performance but still i am not able to fix them in my mm 550 i use my 550 more in OTR then gypsy by Next weekend i fix them in Jeep
Originally Posted by Gypsy-Boy View Post
Hi
GB
__________________
The great pleasure in life is doing what people say you cannot do.....
Old 7th April 2009, 21:42   #29 (permalink)
Can you tell me what they did to the on road ride?
Is it softer? and what about body roll and handling?
I have an Endeavour that is crying out for a softer rear suspension.
Its 2WD and treated like a race car rather than an SUV
I would hate for a suspension component to break while i'm doing triple digit speeds.
__________________
Old 13th April 2009, 17:10   #30 (permalink)
Hi rippergo
its soft in gypsy the body roll and handling is good when we have a discussion with the dealer he told me that its not going to shear just like steel blades of OE the chances of splitting or cracking in very rare cases may happen still we can drive without major issues i just installed 1month back and drove my gypsy hardly 1200 kms and only one small OTR still need to check out how it behaves in long time any how he has promised me 1lakh kms or 1 year free replacement its ok to me-vijay.v
__________________
Thread Tools
single rear leaf on bolero & other SUVs?? croonneck Modifications & Accessories 24 9th May 2009 10:55
Softening ride by removal of leaf spring Mohnish Modifications & Accessories 11 22nd July 2008 20:23
Installing Springs Riki Technical Stuff 0 19th May 2008 15:24
Parabologic Leaf Spring Suspensions - are they good or bad? lalith_ka Technical Stuff 34 3rd March 2008 21:51
Happy Birthday Moral Fibre,Oral Fibre,MF Drive,Moral Forboid etc. payam Shifting gears 44 20th November 2007 10:58
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
