Old 11th July 2011, 16:11   #286
Thanked: 58 Times
Default Re: Composite Fibre Leaf Springs: Can they be used for off-roading?
I have a 550 with a hard-top, running on 245/75/R16 on steel army rims [heavy]. Looking to soften the suspension for my daily drive - what are some of the recommended options?
CFL / Gas shocks (which ones?) / [any other options]
P.S. has any one experienced the 'jolt' when one hits a concrete road, right after a set of paver blocks - and the difference between the two road patches is about ~2 inches - I'm sure the Mumbai folks know what I'm talking about
I wonder how CFLs behave in this situation?
lugnut is offline   Reply With Quote
Old 2nd November 2011, 20:35   #287
Thanked: 32 Times
Has anyone tried CFL in thar? Any recos
vnambiar is offline   Reply With Quote
Old 2nd November 2011, 21:46   #288
starter's Avatar
Thanked: 327 Times
Here you go..
http://www.team-bhp.com/forum/4x4-te...ml#post2564729 (Advice on fitting an air-conditioner in the Mahindra Thar)
Cheers,
Deepak
starter is online now   Reply With Quote
Old 3rd November 2011, 19:42   #289
Thanked: 32 Times
Links to AC fitment not composite fibre leaf spring
Old 3rd November 2011, 22:27   #290
4x4addict's Avatar
Thanked: 2,669 Times
@vnambiar:
Rajith has put CFL in his Thar and is very happy with the performance. There is a picture of the CFL in the same link that starter has posted above. See the pictures posted by Rajith about his AC install and there is a pic of the CFL.
4x4addict is offline   (1) Thanks Reply With Quote
Old 3rd November 2011, 23:06   #291
Thanked: 46 Times
@vnambiar:
I called the company to check the prices and they are quoting 30k for Bolero/Thar/Scorpio CFL Springs. Looks like they have tasted good success and seems they dont have any other competitor in this space.
Has anyone purchased these recently at a better price than 30k? I spoke to Rajith and he had purchased this more than a year back at quite a steal.
BlackRaven is offline   Reply With Quote
Old 4th November 2011, 09:31   #292
Rajith's Avatar
Thanked: 407 Times
Price of 30K is tooo high.
About Ride quality and handling is just superb.. no words to say, feel it..
Rajith is offline   Reply With Quote
Old 4th November 2011, 14:51   #293
raghu4222's Avatar
Thanked: 9 Times
not sure if this is useful, but check this out CFL for Thar | Facebook
I had discussed this with Vijay from swathik and planning to visit him for few of the add ons soon.
Raghu
raghu4222 is offline   Reply With Quote
Old 6th November 2011, 10:19   #294
Thanked: 32 Times
Got it, thanks for the link
Old 6th November 2011, 10:25   #295
Thanked: 32 Times
Would like to check out vehicle for ride quality, please do Msg me at 9900777844
Old 10th November 2011, 00:26   #296
shekaran's Avatar
Thanked: 63 Times
on my enquiry, the CFL's for MM540/550/Thar seems to cost around 26,000/- for the rear set. there is no front CFL for MM Jeeps, and front CFL's are available only for the Gypsy's.
Dear Samurai, Rajith, Swastikviji and all MM Jeep CFL users,
1. is the 26k price for the rear (mm540) alone justified ?
2. what are the benefits seen ? in slow speeds, does the jerking/rocking motion in MM Jeeps - reduced ? or absolutely nil ? pls share in detail your user experiences.
3. does the rear CFL really make the rear suspension like air suspensioned ? its too good to believe this, so pls clarify with your personal views.
4. on CFL fitment, what is the shackle type used ? silent block or grease type ?
5. how is the rear behaviour of the MM Jeep with 2 persons and with 4-5 pax ? any difference in the ride height, sagging like leaves etc.,.
Thanks in advance for all your info/tips/guidances.
Best Regards, Cheers.
shekaran is offline   Reply With Quote
Old 10th November 2011, 09:46   #297
Rajith's Avatar
Thanked: 407 Times
Shekarji here it goes..
** It was 18K in 2009.I brought it for 2wd Bol SLX & now using in THAR CRDe.
You plz work out the inflations & pack to 18K.
** Absolutely no jerks/Rocking.If Rear go hi than the OE level, so clutch shuttering observed (Bolero).
** Yes sir, im using 2 sets from 2008 in 4wd bol & then 2wd bol.For bol i was not happy due many tech issues.But for THAR CRDe, yes.Its like a Air suspension.
** Shackle is OE,Silent block in Bol SLX & THAR CRDe.
5. how is the rear behaviour of the MM Jeep with 2 persons and with 4-5 pax ? any difference in the ride height, sagging like leaves etc..
** Hieght reduces with load, more than normal steel springs.I rides 99% of the time single or with one more in the front, so doesnt matters me.But CFL is not load freindly due to loads rigid nature.But its a passenger freindly.No sagging.
For THAR its fantastic, For Bolero & Scorp i was not happy, will discuss about this later.
Rajith is offline   (1) Thanks Reply With Quote
Old 10th November 2011, 10:30   #298
SPIKE ARRESTOR's Avatar
Thanked: 809 Times
Please explain more about the part in bold above.
Passenger ~~ Load.
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 10th November 2011, 10:49   #299
Rajith's Avatar
Thanked: 407 Times
QUOTE=SPIKE ARRESTOR;2573197]Please explain more about the part in bold above.
spike when i fitted the cfl in my 4wd DI Turbo bolero and 2wd SLX bolero,rear height increased by 2.5 inches on both the sides, thus propeller shaft was comming out from the factory posistion and jerk was observed when boleros are in 3/4 clutch in stationary condition.If u load the vehicle, rear goes down to its original posistion ,jerk goes off. So inserted a 1/2 inch plate between the leaf & diff tubes to compensate the height.
Passenger ~~ Load.
Even though numericaly weight of passengers/load are same, flexiblity is there with people when vehicle hits speed breakers or potholes,but the a bag of sand or a rice wont move from its original position.Thus i have got my one set CFL damaged in a single driven bolero carring @ 300kgs of rice bags from native to blr which negotiaed thru bad roads & Ghats . No issues observed when loaded 7 people in total, except in the case of 235 tyres instead of 215, as 235 was scraping the wheel arches.
Spike[/quote]
Old 10th November 2011, 12:49   #300
Thanked: 809 Times
^^ That is surprising (7 people ~ 490) as compared to 300 kgs of load, agree with the weight movement but still.
Spike
Leaf Springs for Mahindra CL500/550 renjithv 4x4 Technical 2 3rd June 2011 10:36
OME Leaf Springs for the Gypsy satan 4x4 Technical 16 2nd June 2011 10:00
Amaron Optima Yellow Top: Can they be used for off-roading? swastikviji 4x4 Technical 40 13th December 2010 06:42
Torsion bar or leaf/coil springs. Which is better ? taurian2804 Technical Stuff 4 9th November 2009 11:07
Happy Birthday Moral Fibre,Oral Fibre,MF Drive,Moral Forboid etc. payam Shifting gears 44 20th November 2007 10:58
