Old 26th June 2013, 08:25   #346
ashutoshb's Avatar
Thanked: 647 Times
Default Re: Composite Fibre Leaf Springs: Can they be used for off-roading?
Thanks for your inputs, Samurai, headers!
You are right, the angle is in the opposite direction. Will speak to Carnation guys today.
Samurai, If you look at the first picture, the size looks the same to me.
Also, is there a default angle one should keep, like 90 degrees? Or is it different for different requirements?
ashutoshb is offline   (1) Thanks Reply With Quote
Old 26th June 2013, 08:51   #347
Samurai's Avatar
Thanked: 14,539 Times
I guess size was the wrong word to use. Even though the size looks same, they have very different cambering. Once installed, the angle at the shackle should look same as in my pic. That is the perfect angle.
Old 26th June 2013, 08:59   #348
ashutoshb's Avatar
Thanked: 647 Times
Will speak to Dr. Pawar about the cambering.
Originally Posted by slalom View Post
The vehicle is on a lift and the axle is suspended , in that case the spring is stretched and the shackle is angled inwards right ?
This is the current position:
Old 26th June 2013, 09:49   #349
Samurai's Avatar
They obviously gave the wrong CFL for your vehicle. You need a longer leaf with the right cambering.
Also, make sure the shackles are not tight around the leaf. There should be free movement. Since CFL is little wider at the end than the steel leaf, the OE shackle tends to restrict the movement. I switched from silent block to nipple type shackle to take care of it.
Old 26th June 2013, 10:41   #350
ashutoshb's Avatar
Thanked: 647 Times
@samurai, I am sad and confused.
Old 26th June 2013, 11:00   #351
Samurai's Avatar
It took me 2 months to get the CFL working correctly on my Jeep. Have a little patience.
http://www.team-bhp.com/forum/4x4-ve...ml#post1517469 (Mahindra CJ340 joins Team-BHP family)
Samurai is offline   (1) Thanks Reply With Quote
Old 26th June 2013, 11:11   #352
Thanked: 32 Times
Length of leaf does not look right, you need longer one for the vehicle. My shackles were free moving outwards.
vnambiar is offline   Reply With Quote
Old 26th June 2013, 11:22   #353
Blue Thunder's Avatar
Thanked: 330 Times
Lightbulb Re: Composite Fibre Leaf Springs: Can they be used for off-roading?
I have ordered a set of CFLs from Dr. Pawar. Does anyone know a competent garage in Delhi / NCR? Don't want to take risk, let someone experiment on my car.
From your signature and the pics you have posted of your car, it seems to be a Sumo Grande. I am curious to know why you decided to go for CFL springs for the Sumo Grande.
(One of the best features of the Sumo family of vehicles, in the face of all its shortcomings, is the parabolic leaf-springs at the rear. They are not the conventional semi-elliptic leaf springs. They offer ride-comfort on par with coil spring suspensions. So, sorry to say this but, even the best-matched CFL springs will NOT give a better ride than the existing parabolic springs, at best , it will match the existing ride comfort).
Ride comfort of coil springs better than parabolic springs better than semi-elliptic leaf springs.
Blue Thunder is offline   (1) Thanks Reply With Quote
Old 26th June 2013, 14:28   #354
ashutoshb's Avatar
Thanked: 647 Times
I was really unhappy with the ride. With only me in the car most of the times, the ride was a little bumpy.
I did read about CFLs, but somehow missed on the fact that parabolic leaf-springs, the ones which I already had, are equally capable.
Now that I have bought the CFLs and have them fitted, will try what best can be done.
Old 27th June 2013, 10:55   #355
ashutoshb's Avatar
Thanked: 647 Times
After seeing the photographs, Dr. Pawar says the suspension / springs of my 2011 Grande is different than the earlier versions.
Mine is 2011 Mk II. If this question would have been asked earlier, it would have saved me some time and trouble.
He has offered to replace the current CFls and fabricate new ones for me, free of charge.
I will continue to use the current ones and get the shackle position corrected in the meanwhile.
ashutoshb is offline   Reply With Quote
Old 20th February 2014, 09:56   #356
Rajith's Avatar
Thanked: 391 Times
Friends,
Please share your experiences with CFL on yours vehicles under different conditions..to have a proper idea for new person planning to instal.
Rajith is offline   Reply With Quote
Old 27th November 2016, 06:45   #357
Bump-Stop's Avatar
Thanked: 45 Times
Apologies on "bumping up" an old thread, but can someone please update on the present status of CFLs. Apparently they are now available in three formats: soft, rally and off road.
1. Is there any change or improvement in the reliability of CFLs for the front end?
2. Does the off road spec cater for additional stresses of winches and bumper?
3. Do these provide additional lift over stock springs? If so then how much?
Bump-Stop is offline   Reply With Quote
Old 27th November 2016, 07:41   #358
Thanked: 1,338 Times
Good questions: the reason I decided to not change my stock set up is for reliability. One leaf breaks, you can still get by. Not so on the CFL.
I too would love to have the ride of the car tamed for on road use, particularly at the rear. So, for a slightly different reason, I echo the above questions based on today's state of affairs for these.
Sawyer is online now   (1) Thanks Reply With Quote
Leaf Springs for Mahindra CL500/550 renjithv 4x4 Technical 2 3rd June 2011 10:36
OME Leaf Springs for the Gypsy satan 4x4 Technical 16 2nd June 2011 10:00
Amaron Optima Yellow Top: Can they be used for off-roading? swastikviji 4x4 Technical 40 13th December 2010 06:42
Torsion bar or leaf/coil springs. Which is better ? taurian2804 Technical Stuff 4 9th November 2009 11:07
Happy Birthday Moral Fibre,Oral Fibre,MF Drive,Moral Forboid etc. payam Shifting gears 44 20th November 2007 10:58
