4x4 Technical Engines, Diff-locks, SPoA, Techniques and more
Thread Tools
Old 12th July 2009, 19:24   #61 (permalink)
khan_sultan's Avatar
Originally Posted by jyobeb View Post
The traction bar/ bam bar prevents axle wrap which is usually a negative effect of an SPOA conversion.
Oh you meant Traction Bar . Sure, it's on the card's and one fine day that also will be done.
__________________
The best way to kill an idea is to take it to a meeting....
khan_sultan is offline   Reply With Quote
Old 17th July 2009, 22:29   #62 (permalink)
Here are some pictures that show how the composite leaf springs flex during articulation. Must say that they performed nicely. (picture Courtesy: Rajesh/Shakir)
Actually, the flex is limited by my shocks. they bottom out quite soon and don't have much travel. Need to plan for longer shocks
Just look at how the front metal leafs of the driver side is nearly bent the other way...
From what I hear is that they have composite leafs for the front also now. They have done enough testing and are now confident of the performance in the front also. They are more stiffer than those at the back.
__________________
Old 18th July 2009, 07:03   #63 (permalink)
harjeev's Avatar
Khan Bhai
Nicely is a gross understatement!!!!
from the looks of it they preformed great!!! I mean look at it!!!
Now definitely my next big expense is bigger better tyres, SpOA and Comp Leaf's!!!
Congrats!!!
This actually should be called a monster gypsy
What size tyres are you running!!!
__________________
  • 2007 Tata Safari 2.2 VTT 4x2
  • 2000 M&M MM550 XD 4x4
  • 1985 M&M CJ3B(RHD) 4x4
  • 1963 WILLYS CJ3B(LHD) 4x4 (In hibernation)
harjeev is online now   Reply With Quote
Old 18th July 2009, 20:09   #64 (permalink)
How is the on-road ride comfort with the CF springs? Is there a marked improvement over the stock leafsprings?
__________________
to boldly go where no man ( or woman ) has gone before
Blue Thunder is offline   Reply With Quote
Old 18th July 2009, 22:32   #65 (permalink)
Originally Posted by harjeev View Post
....What size tyres are you running!!!
Am running 235/75/15
Oh, there is a day-night difference in the on-road ride comfort. The bone jarring ride of the gypsy is tamed to a HUGE extent.
I will be getting the CFLS for the front also now -- have heard that the front one's have been thoroughly tested and now available for installation
__________________
Old 19th July 2009, 21:32   #66 (permalink)
chandan's Avatar
A doubt: Will the load handling capacity remain the same ? I'm asking this because,I sometimes load upto a ton of stuff.
chandan is offline   Reply With Quote
Old 19th July 2009, 23:35   #67 (permalink)
star_aqua's Avatar
Nope. you need to specify the loading and they are going to fabricate according to. this will make the suspension hard when driven without load. but better than the leaf springs.
star_aqua is offline   Reply With Quote
Old 20th July 2009, 16:05   #68 (permalink)
Thumbs up
Originally Posted by khan_sultan View Post
...Oh, there is a day-night difference in the on-road ride comfort. The bone jarring ride of the gypsy is tamed to a HUGE extent...
This is wonderful news indeed...i need to plan for this upgrade now.
__________________
Old 20th July 2009, 17:52   #69 (permalink)
Parm's Avatar
i agree on the load in the vehicle to correspond with the CFLS to be ordered!
i can see Khan's gypsy has no rear seats and im sure his gypsy is only for OTRs and not for round the city trips!
so please mention the load capacity of your vehicle (Jeep, gypsy, Gurkha,etc) before you order the CFLS!
__________________
Go with the Flow.....Free Flow!
Parm is offline   Reply With Quote
Old 20th July 2009, 20:53   #70 (permalink)
swastikviji's Avatar
Hi Chandan
Regarding pay load, i tested with 8 people in my gypsy.
__________________
The great pleasure in life is doing what people say you cannot do.....
swastikviji is online now   Reply With Quote
Old 20th July 2009, 20:57   #71 (permalink)
Sha
Sha's Avatar
Originally Posted by swastikviji View Post
Hi Chandan
Add to this Vijay did Mini OTR also with 8 peoples.
__________________
Civic 1.8V 2006 December done 57000 Km.
Swift Vxi(ABS) 2006 November done 44500 Km.
Gypsy 413W 2008 November
Sha is offline   Reply With Quote
Old 20th July 2009, 21:08   #72 (permalink)
Hi Shakir,i forgot that day when we tested with 8 people you are also there am i correct ?
Now i am planning to fix these in front. waiting for khan sir to test it first.
__________________
Old 20th July 2009, 21:24   #73 (permalink)
Sha
Sha's Avatar
Yeah i was there. let Khan try first and do some Articulation Lesson on front leaf spring then you buy it.
__________________
Old 22nd July 2009, 11:01   #74 (permalink)
chandan's Avatar
Hi Chandan
That's reassuring.However,Id like some 540 owners with CFLS to comment.
Old 22nd July 2009, 12:29   #75 (permalink)
star_aqua's Avatar
Chandhan, SwastikViji is also the owner of a 550 with CFLS. My two cents. I have experienced driving his 550 with CFLS. had driven it with 6 people onboard. it gives the same feeling as if it is not loaded. there is a slight roll when you drive without load, but not to a great extent(feels like you are floating). initially it acts as if the suspension is weak, but becomes more rigid as you load.
Thread Tools
single rear leaf on bolero & other SUVs?? croonneck Modifications & Accessories 24 9th May 2009 10:55
Softening ride by removal of leaf spring Mohnish Modifications & Accessories 11 22nd July 2008 20:23
Installing Springs Riki Technical Stuff 0 19th May 2008 15:24
Parabologic Leaf Spring Suspensions - are they good or bad? lalith_ka Technical Stuff 34 3rd March 2008 21:51
Happy Birthday Moral Fibre,Oral Fibre,MF Drive,Moral Forboid etc. payam Shifting gears 44 20th November 2007 10:58
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
