Old 26th April 2010, 19:32   #196
fazalaliadil's Avatar
Thanked: 624 Times
Khan Sahab,
Your Gypsy will never stops to evolve.
Thank god you did not sell it off on April 1st as planned.
fazalaliadil is offline   Reply With Quote
Old 26th April 2010, 23:01   #197
swastikviji's Avatar
Thanked: 158 Times
Originally Posted by khan_sultan View Post
PS: Thanks to swastikviji who found a good fabricator to get this made as per our design. Without his help, this (+ bumper + t-case guard) would not have been possible
Khan Sir we have to thank for Sreenivas who is the best in all aspects, he is showing same interest just like us and enjoying the mod, first thing your research is benefited a lot of us, before spidey even i doesn't know what is lockers.
swastikviji is offline   Reply With Quote
Old 27th April 2010, 10:21   #198
Jaggu's Avatar
Thanked: 7,692 Times
OT:
Couldn't be simpler than that :-)
You can say that again, make plate do some welding and then mark the holes and tighten bolts, so very simple
Do you really think any rock will touch this?
But hey design and execution is superb! 3 cheers to you, Viji and the rest involved in making and fitting.
Old 2nd May 2010, 18:47   #199
Thanked: 136 Times
Khan,
Saw Spidy on Friday & wanted to have a closer look along with you, but work got in the way!
Spidy is amazing! With the new front work, it has got a meaner attitude!
Reckon you are planning of a winch; so are you planning to put in a hard cover cabin? I am sure the cloth cover of the front cabin is getting to be a security issue.
HappyWheels is offline   Reply With Quote
Old 29th May 2010, 17:54   #200
khan_sultan's Avatar
Thanked: 3,467 Times
One of the pending items in the SPoA modification had been the steering setup. With the lift, the angle of the draglink had become acute and it was putting in lots of stress on the rod-ends.
Here is a picture of the angle of the draglink.
After much searching, even some failed attempts at fabricating parts, I managed to get hold of mercedes steering control arms. The merc arms will bolt on to the brake caliper pin and provide a point for making a X-over steering setup.
After much thought, I decided to do a X-over rather than a Hi-Steer.
Here is Viji holding the Merc arms :-)
This is one setup that we tried: The rod-ends from bottom, but this was touching the leafs on lock to lock (Right turn)
Gypsy on Steroids -- The SPoA Project.  EDIT: Stage-2 Started now..-img0245a.jpg
So, we then redid the merc end to make the draglink rod-end to be from top.
Gypsy on Steroids -- The SPoA Project.  EDIT: Stage-2 Started now..-img0247a.jpg
Gypsy on Steroids -- The SPoA Project.  EDIT: Stage-2 Started now..-img0248a.jpg
Gypsy on Steroids -- The SPoA Project.  EDIT: Stage-2 Started now..-img0250a.jpg
Oh yes, forgot to mention then a Gypsy draglink is not adjustable and is rigid. So had to get it fabricated to take in a adjustable rod-end joint.
Lots of days & several iterations later, the steering works like a charm. have driven it just a few kms but can feel that it is on the right track now
Here is a comparison picture showing the angle:
Gypsy on Steroids -- The SPoA Project.  EDIT: Stage-2 Started now..-final.jpg
Oh yes, here is the Gypsy getting a well deserved scrub:
Gypsy on Steroids -- The SPoA Project.  EDIT: Stage-2 Started now..-img0253a.jpg
Gypsy on Steroids -- The SPoA Project.  EDIT: Stage-2 Started now..-img0254a.jpg
khan_sultan is offline   Reply With Quote
Old 29th May 2010, 21:05   #201
Thanked: 136 Times
Good to see Spidey getting a long over-due betterment!
And, nice seats. When did you get them done?
And looks like all the sticker's at the rear door had been removed. Is it?
Old 29th May 2010, 21:45   #202
ladak.imran's Avatar
New steering setup looks great!
I'll be waiting to hear more about the way she handles now..
Goodluck!
Can't wait to take a ride in your vehicle during EXAMMs and AKC!
ladak.imran is offline   Reply With Quote
Old 30th May 2010, 23:28   #203
Jaggu's Avatar
Khan saab that link thing looks to be a simple but brilliant mod job and nice seats, custom made eh?
Spidey steers, need to change the L to R link ends and it will be really tight. Main difference is the turn in's, now it's superb and great feel on road. Actually you can feel the uneven roads on the steering now
Old 15th June 2010, 15:45   #204
pdev29's Avatar
Thanked: 258 Times
Khan,
very interesting project, too tempted to try this.
hatts of to your R&D, your mechanics.
i think you should get the following stuff too.
1) front axel wrap
2) roll cage
3) underbody protection
these things will make it a hardcore offroad machine.
pdev29 is offline   Reply With Quote
Old 23rd September 2010, 21:00   #205
V-16's Avatar
Thanked: 848 Times
What to say Khan. I sat in the monster during Exxam and was pleasantly surprised to find the ride at the rear also very very comfortable.
Can you email me the blueprints please as am taking notes to shamelessly copy this design when i have a gypsy of my own??
Kudos to the whole team.
V-16 is offline   Reply With Quote
Old 30th September 2010, 12:17   #206
pdev29's Avatar
Thanked: 258 Times
can anyone put it in simple language whats the difference between Hi-Steer and X Over saw the setup got the idea but still not clear on this.
Old 30th September 2010, 12:32   #207
Hi-Steer: Both the draglink/tie-rod are moved up and are just like OE setup but just higher. Will create an impact on the 'ackerman angle'
X-Over: Only the tie-rod (the angular rod from steering/pitman arm to draglink) is moved up. The rod connecting the two knuckle arms remains where it was. In this the tie-rod needs to be removed from drag-link and made as an independent rod. This brings the angle of the link as close to OE as possible. Things to note: Since the drag-link & tie-rod are now independent, you will face a lot more bump-steer and steering feedback will be lot more/vibrations felt.
Here is the pictorial representation:
Hi-Steer
X-Over (Also known as half hi-steer)
khan_sultan is offline   (2) Thanks Reply With Quote
Old 30th September 2010, 13:10   #208
pdev29's Avatar
Thanked: 258 Times
i dont understand the point of moving the rod connecting the two knuckle arms ??? any particular reason.
here is the pic of what i have done in my monstar.
I have fabricated and extened the steering link.
let me know your inputs on this.
Old 30th September 2010, 13:36   #209
Getting the setup as close to OE/stock as possible. All angles with this will be nearly like that of a OE vehicle.
Not clear in the picture, but I think what you have done is fabricated a custom drop pitman arm which lowers the angle of your rod and makes it as parallel to ground as possible. That should also work fine.
All such mods would have some +/- aspects on the steering setup so nothing much too worry about . Just enjoy and have fun.!!!
Old 1st October 2010, 10:57   #210
pdev29's Avatar
Thanked: 258 Times
for your first point :
khan this rod angle is not chaning in any case so why to touch this?? x over setup seems more practical to me.
you got it right for my vehicle, i have just extended it.
Gypsy on Steroids: Lockers installed and tested now khan_sultan 4x4 Technical 192 26th June 2014 23:34
Gypsy on Steroids: Maxxis Trepador M8060 MT. Update Now on Yoko Geolander MT! khan_sultan 4x4 Technical 102 27th August 2010 16:46
A Pure Off-Road Spec Gypsy Build | SPoA, Lockers, Bumpers etc etc. swastikviji 4x4 Vehicles 81 16th July 2010 16:54
Gypsy on Steroids: Next Dose -- Short Chassis for reduced rear overhang khan_sultan 4x4 Technical 56 24th March 2009 12:39
