Old 1st October 2010, 15:14   #211
Jaggu's Avatar
Thanked: 8,858 Times
What i understood was, there is a reason why steering arm is attached to the tie end arms, and at a certain angle. To retain these angles one needs to move the tie end arms also up. There are small small issues wrt handling which can come up if not adhered to this.
Might not be relevant in OTR's or even during our moderate driving speeds. But definitely can cause negative handling during spirited driving. This is what Khan was trying to explain using ackerman and pac mans
EDIT: Things like this
Old 2nd October 2010, 11:51   #212
headers's Avatar
Thanked: 464 Times
Infact, stock setup is superb for spirited driving and mild OTRs. That is why the gypsies were the preferred choice in most rallies in India until better vehicles came along!!
A gypsy in 2WD has amazing handling which few cars match! But SPOA and other mods done has a negative impact for the above!
Infact they are not to be compared at all!
Old 3rd October 2010, 16:50   #213
DirtyDan's Avatar
Thanked: 785 Times
It should be interesting to see what the near future holds for us with "fly-by-wire" steering technologies coming into the market. With no direct physical link between steering wheel and road wheels, it's a whole new cricket match, lift-wise.
Old 5th October 2010, 08:11   #214
headers's Avatar
Thanked: 464 Times
Yup Ken,
I saw a Mahindra Scorpio last Auto Expo with such a steering system.
Ofcourse could not drive one to know how it feels. But a whole lot of auto component vendors will go out of business
Old 5th October 2010, 21:47   #215
Thanked: 62 Times
I think Gypsy is still a preferred choice when it comes to rallies which have tough terrain. In this years Raid -de - himalaya, Moghul Rally, and Desert Storm, gypsy rules.
In recent times, people are trying with GV, etc. BUt the results are no where near the Gypsies.
wanderhermit is offline   Reply With Quote
Old 7th October 2010, 09:27   #216
offroad_maniac's Avatar
Thanked: 41 Times
Yup Ken,
Scorpio with fly by wire steering? What will be its benefits over normal mechanical steering setup? Any worst case scenarios?
Gypsies are King of Indian rallies. They are lighter, 4WD, they jump like crazy & still goes fast.
offroad_maniac is offline   Reply With Quote
Old 7th October 2010, 12:11   #217
headers's Avatar
Thanked: 464 Times
Benefits will be lesser manufacturing costs as a lot of parts need not be a part of the BOM.
One also includes more electronics to work with the car. Hence you can tune the sensitivity of the steering with the road speed.
Worst case scenario - simple: One can turn the steering wheel and the vehicle does not turn
Old 1st February 2011, 18:26   #218
trammway's Avatar
Thanked: 220 Times
Default Re: Bangalore Aavalakonda Annual OTR 2011 | Participants Report
Originally Posted by livyodream View Post
1. Rear CFL shattered into 2 piece.
Bring it on guys.
I guess you are talking about this CFL shattering event, IMHO CFL is not suggested for OTR environment. I may be wrong but what has happen to SwastikVijai's Gypsy shows that if you modify and/or add addtional weight to your vehicle than the capacity of the CFL there is no way you can alter and make it working for your mods.
Gypsy on Steroids -- The SPoA Project.  EDIT: Stage-2 Started now..-29012011001.jpg
Gypsy on Steroids -- The SPoA Project.  EDIT: Stage-2 Started now..-29012011.jpg
In other way, I also feel CFL cannot take the beat from hardcore(?) offroading events.
Not to forget the steel leaf springs inserted in the same gypsy also twisted on the same day. May be experts could through more light on that incident.
trammway is offline   Reply With Quote
Old 1st February 2011, 23:08   #219
swastikviji's Avatar
Thanked: 158 Times
Hi Siva,
My CFL Braking is not Because of Quality of CFL, I think its only because of my negligence, Khan told me to fix Traction bar when i fitted Crawlers in my Gypsy, i neglected it, now we know what is Axle wrap and How much Torque my gypsy is producing,
All this things i know very well, i done the same trial in same gypsy with 235 trepedors, once i replaced them with 31" tires my leafs gone to a toss, the reason behind my theory is after replacing CFL with Stock leafs by Arka, my gypsy completed only Robi's climb, immediately after that metal leafs also twisted,
Gypsy on Steroids -- The SPoA Project.  EDIT: Stage-2 Started now..-img_6810.jpg
swastikviji is offline   Reply With Quote
Old 1st February 2011, 23:26   #220
trammway's Avatar
Thanked: 220 Times
Originally Posted by swastikviji View Post
Hi Siva,
Viji Sir, I agree with you to an extent. However the point here is even if the stock leaf twisted we had an option to tow or move the vehicle, but in case of CFL it was broken into pieces requiring on the spot replacement.
I'm sure the traction bar solution is a fix, however considering the above point I have posted IMHO the steel leafs are superior and rigid compare to the CFL. Not to ignore CFL brings in some good cushion to the passenger inside the vehicle.
Old 2nd February 2011, 07:58   #221
svsantosh's Avatar
Thanked: 1,449 Times
Viji, doberman isnt SPOA'd right? Why does it need traction bar then? Could it be some other issue?
svsantosh is offline   Reply With Quote
Old 2nd February 2011, 08:10   #222
headers's Avatar
Thanked: 464 Times
It has Shackle lift and is running 4.9:1 crawler GB. Hence the strain on the drive-train is higher.
Old 2nd February 2011, 10:15   #223
Kandisa's Avatar
Thanked: 463 Times
Slightly OT: Is that the dog bone shackles fabricated by Swastikviji? Are these also responsible for additional strain on drivetrain apart from the crawler set?
Kandisa is offline   Reply With Quote
Old 2nd February 2011, 10:24   #224
ex670c's Avatar
Thanked: 1,838 Times
Default Gypsy
Hi Siva,
Hi Viji,
The Axle-Wrap is due to the Shackle Lift, further aggravated by the Crawlers Gears (More Torque) and Heavier Tyres (31")
Please do the following
i) Custom Leaf Pack (Military Wrap/Double Main Leaf)
ii) Traction Bar
You have a superb Gypsy, with the works, the suspension is 2 days work.
Arka
PS - Please, Please fit a full-size spare, enhances the looks, and is the last attention to detail.
Old 2nd February 2011, 10:46   #225
karizma9292's Avatar
Thanked: 210 Times
OFF TOPIC :
I agree with you headers sir . One question , my MG410 is undergoing a 1.6 conversion , shackle lift (same as Vijay sir's) and 235 size MTs . Does my gypsy need a traction bar?
karizma9292 is offline   Reply With Quote
Gypsy on Steroids: Lockers installed and tested now khan_sultan 4x4 Technical 192 26th June 2014 23:34
Gypsy on Steroids: Maxxis Trepador M8060 MT. Update Now on Yoko Geolander MT! khan_sultan 4x4 Technical 102 27th August 2010 16:46
A Pure Off-Road Spec Gypsy Build | SPoA, Lockers, Bumpers etc etc. swastikviji 4x4 Vehicles 81 16th July 2010 16:54
Gypsy on Steroids: Next Dose -- Short Chassis for reduced rear overhang khan_sultan 4x4 Technical 56 24th March 2009 12:39
