Old 2nd February 2011, 10:53   #226
headers's Avatar
Thanked: 459 Times
Default Re: Bangalore Aavalakonda Annual OTR 2011 | Participants Report
Originally Posted by karizma9292 View Post
One question , my MG410 is undergoing a 1.6 conversion , shackle lift (same as Vijay sir's) and 235 size MTs . Does my gypsy need a traction bar?
Your gypsy will require a traction bar if the prop shaft angle changes more than 3 - 5 degrees!
Old 2nd February 2011, 11:14   #227
karizma9292's Avatar
Thanked: 209 Times
Sir thanks for the reply whether i need a traction bar or not .
Now the traction bar is added in the list of mods . Any other mods i should do to have safe running ?
karizma9292 is offline   Reply With Quote
Old 2nd February 2011, 11:55   #228
ex670c's Avatar
Thanked: 1,799 Times
Hi Vikram,
You are in your "UNCLE" est form.
Don't you think it should be differential pinion angle or just if the differential pitches more than stock.
Arka
Old 2nd February 2011, 13:27   #229
Jaggu's Avatar
Thanked: 7,676 Times
Viji, doberman isnt SPOA'd right? Why does it need traction bar then? Could it be some other issue?
More due to crawler gear ratio and as below.
Originally Posted by ex670c View Post
The Axle-Wrap is due to the Shackle Lift, further aggravated by the Crawlers Gears (More Torque) and Heavier Tyres (31")
OFF TOPIC :
I agree with you headers sir . One question , my MG410 is undergoing a 1.6 conversion , shackle lift (same as Vijay sir's) and 235 size MTs . Does my gypsy need a traction bar?
Nope you don't need a traction bar, is what i feel. Allen is running heavier tires also without any issues.
Old 2nd February 2011, 13:52   #230
headers's Avatar
Thanked: 459 Times
You are right-it is differential pinion angle SIR! I was in a hurry and did not type it all!!
Sir, we actually dont know whether he has had any problem. He has his own workshop to set things right - right?
Last edited by Jaggu : 2nd February 2011 at 15:22. Reason: Removing the engineer remark. Hope you can understand. Thanks
Old 2nd February 2011, 14:25   #231
Thanked: 209 Times
Vikram sir and Jaggu sir now im confused .
Please help me soon .
Old 2nd February 2011, 14:40   #232
Thanked: 226 Times
Does the spacer and outward facing wheels increase width of the vehicle? If yes, Allen has spacers and largers wheels with outward facing wheels and gives better manuering.
I may be wrong.
Dwarak
dwaraka is offline   Reply With Quote
Old 2nd February 2011, 15:01   #233
Jaggu's Avatar
EDIT: Moved it here coz its more relevant;
Karizma, you can check here (Gypsy on Steroids -- The SPoA Project. EDIT: Stage-2 Started now..) to understand more.
What is with this Sir thingie?? When did we all become so nostalgic about the brits???
Anyways as far as i know, Allen never had any spring issues. Allen is here, so he can clarify. I personally dont think the torque differential from a 1.3 to 1.6 will cause such an issue.
Even with crawlers in high gear the spring, axle etc are safe.
Right and wrong, Allen iirc has custom rims built to accommodate the bigger tyres.
Anyways where are you Allen!!!
Old 2nd February 2011, 15:36   #234
Thanked: 63 Times
Default Re: Gypsy on Steroids -- The SPoA Project. EDIT: Stage-2 Started now..
to all the sirs,
sorry have been a bit busy restoring vintage vehicles
here goes.
my 1.6 is running on stock 410 differentials
custom shackle lift with a rear comfort design
heres my suggestions
if anyones going spoa (whatever the engine be) please get a traction bar
for a gypsy running a 1.3 and just a shackle lift without crawlers your stock suspension will do just fine
karizma this is for u
for a gypsy running a 1.6 and only a shackle lift and whatever tyres (235 or 31x10.5)(no crawler gears)
you do not need a traction bar
but please reinforce your springs
i have personally added 2 extra springs on each setup
i have never faced any issues with my suspension till date
vikram if i did i would have updated my thread and warned others about the same
dwarka sir, im running fused alloys without spacers giving me my needed offset
i do not recommend spacers for gypsy's at all
have seen lots of axles break with them
including my green delhi gypsy
regards,
Allan
xtreme power is offline   Reply With Quote
Old 2nd February 2011, 17:14   #235
headers's Avatar
Thanked: 459 Times
Nevermind Allan, its good to know your inputs for the experts here to decide..
My POV is if one changes the wheel CL, then the load points get disturbed and this aint good for "my" off road style of driving. [I gotta be careful with what i post and where ]
Old 2nd February 2011, 18:52   #236
Thanked: 209 Times
Allan thanks a lot for the help , since my tyres are 235/75-R15 should i add 2 extra leafs or just 1 is enough . Reinforcement of springs is needed for all 4 wheels or just the rear .
Old 2nd February 2011, 23:00   #237
Thanked: 63 Times
id suggest two
this basically makes the entire setup more rigid which will prevent ur axle from wrapping to some extent
there is another method which i had tried on orangie
that is turning the whole axle and diff and rewelding the leaf spring perches
karizma, all four please
also your transfer case mounts are gonna act up cause of the added torque generated
i think vikram has a solution for this :-)
Last edited by Jaggu : 3rd February 2011 at 10:32. Reason: Back to back post, please EDIT the original post instead. Thanks
Old 3rd February 2011, 10:30   #238
Thanked: 209 Times
id suggest two
OK done . But that would make the ride harsh right .
You mean i have to beef up the T-case mounts . Vikram sir your inputs please for the T-case.
Old 3rd February 2011, 12:38   #239
Thanked: 226 Times
to all the sirs,
here goes.
regards,
Allan
Thanks for clarifying Allan. I have setup of 1.8 ltr Isuzu engine and gearbox mated to Gypsy (not King) T-case. Suspension has two extra blades added and dog shackle mounted. Mine is Wide chassis 1ltr gypsy chassis. Will I have any issues with the present setup?
Dwarak
Old 3rd February 2011, 15:06   #240
Thanked: 63 Times
Dwarak
dwaraka sir,
perfect suspension setup imho
id love to come down someday and try the engine gearbox combo someday
Gypsy on Steroids: Lockers installed and tested now khan_sultan 4x4 Technical 192 26th June 2014 23:34
Gypsy on Steroids: Maxxis Trepador M8060 MT. Update Now on Yoko Geolander MT! khan_sultan 4x4 Technical 102 27th August 2010 16:46
A Pure Off-Road Spec Gypsy Build | SPoA, Lockers, Bumpers etc etc. swastikviji 4x4 Vehicles 81 16th July 2010 16:54
Gypsy on Steroids: Next Dose -- Short Chassis for reduced rear overhang khan_sultan 4x4 Technical 56 24th March 2009 12:39
