Old 16th March 2009, 20:30   #46
mjothi's Avatar
Thanked: 216 Times
Wow, that was great. I think the service guys was right in mentioning if you need a Ladder
I remember seeing something similar to this in my recent visit to Thailand. The only difference I could remember is that it had a even bigger wheel protuding outside gypsy body. Sorry I have no pics.
So, now, is the front bumper coming back?
P.S. Seems Bay 15 is reservered for your Gyspy only !!
mjothi is offline   Reply With Quote
Old 16th March 2009, 20:49   #47
starter's Avatar
Thanked: 327 Times
Dear Khan,
It looks awesome, head reeling stuff!! Would love to see the new setup in action.
All the best with this project and hope to see your Gypsy on its new limbs soon (if shoes is for tyres).
Cheers,
Deepak
starter is online now   Reply With Quote
Old 16th March 2009, 23:12   #48
star_aqua's Avatar
Thanked: 89 Times
Khan sir, just a small observation. is the steering work done or needs to be done? shouldn't the angle needs to be reduced? or else a small bump can steer the wheel either way on high speeds.
star_aqua is offline   Reply With Quote
Old 17th March 2009, 00:16   #49
Thanked: 660 Times
hows the ride quality. Any news of the excessive body roll on highways?
Old 17th March 2009, 00:29   #50
dr_know's Avatar
awesome, the gypsy is looking great!!
dr_know is offline   Reply With Quote
Old 17th March 2009, 09:13   #51
khan_sultan's Avatar
Thanked: 3,872 Times
Originally Posted by star_aqua View Post
.... is the steering work done or needs to be done? shouldn't the angle needs to be reduced? or else a small bump can steer the wheel either way on high speeds.
Lots and lots of small small, but very important, work is still left. Steering, brake lines, DS spacers etc are still left to be done.
Still not complete sir. Don't know how it will be.
khan_sultan is offline   Reply With Quote
Old 17th March 2009, 09:28   #52
headers's Avatar
Thanked: 464 Times
Originally Posted by khan_sultan View Post
Thanks Vinod. It's surprising that the SPOA Gypsy did not articulate/flex. The culprit in my opinion could be the 'stock dampers' that would be used.
Shanavaz, that gypsy does not have its sway bar removed. Thats why it does not flex!
All the best!
Old 17th March 2009, 10:31   #53
spawnofsatan's Avatar
Thanked: 85 Times
Hey Shahnawaz, nice Gypsy, looks great. You should drive her down to bombay for a meet like last time. It was fun.
spawnofsatan is offline   Reply With Quote
Old 17th March 2009, 10:56   #54
JayD's Avatar
Thanked: 2,008 Times
I must say, that is one mean looking gypsy. Any plans for putting back the bumper?? It looks kinda incomplete without it.
Old 17th March 2009, 12:39   #55
shyammg's Avatar
Hi Shahnawaz, Nice job with the Spoa. Now the next project should be a Winch Bumper and a 1.6 or V6 Conversion!!
shyammg is offline   Reply With Quote
Old 17th March 2009, 13:30   #56
Thanked: 1,642 Times
Looks really mean now - an external roll-cage over the whole cabin would be really neat.
Can you get detachable stabilizer (or sway, as they call it here) bars? You dont want to be articulating with that height on a curve....
Steeroid is offline   Reply With Quote
Old 17th March 2009, 13:45   #57
mmmm.. I had thought of that and looked very closely at the pictures and then thought/assumed that the sway bar is removed.
If the sway bar is present, then as you mentioned, it will not flex as much.
Originally Posted by JayD View Post
...Any plans for putting back the bumper?? It looks kinda incomplete without it.
NO. no way a bumper is coming back again. I personally like that 'incomplete/rugged, don't mess with me mean' look without the bumper
Originally Posted by shyammg View Post
... Now the next project should be a Winch Bumper and a 1.6 or V6 Conversion!!
Maybe at a later stage -- both of these are way way down on my priority list right now.
Yes. sometime soon, I need to get roll cage done. Internal/external is something I have not yet decided on.
We don't get it here. Let's see what happens without it and then will decide on next steps.
Old 17th March 2009, 14:26   #58
Originally Posted by ex670c View Post
.... In case of a Z-Link attach the Steering Stabilizer on the Diff-Tube to the Longer Drag Link aka Balance Rod/Link
Arka,
Is this what you are suggesting? This has the 'additional' damper from diff-tube to the longer drag link.
Looks like that I will have to go for a z-link for the short term.
Old 17th March 2009, 15:04   #59
ex670c's Avatar
Thanked: 1,821 Times
Arka,
Hi Shahnawaz,
The proper method of putting the Stabilizer is on the Differential Tube and the Longer Drag Link/Balance Rod as this is directly connected to the Steering Knuckles and eliminates bump steer and decreases King pin and Tyre wear.
http://www.team-bhp.com/forum/4x4-of...upgrade-4.html
OEM Stabilizer are fitted on the Steering Drag Link because of ease of assembly.
The Stabilizer has to be parallel to the Balance Rod on at least one Axis, for optimum performance.
Arka
PS - have you considered a dropped pitman arm?
Old 17th March 2009, 15:32   #60
star_aqua's Avatar
Thanked: 89 Times
Shanawaz, this is what i was pointing to. i think that you are going according to how it has been done for jimmy/zuki in the last pic you posted. but i feel that kinda setup without dropped pitman arm will not be suitable for indian roads. if you run over a pothole, then you will see the steering drag towards left or right. I think the ball joint between the pitman arm and the steering drag link should be as nearer to the perch on the axle housing.
Arka, please correct if i am wrong!
Gypsy on Steroids: Lockers installed and tested now khan_sultan 4x4 Technical 192 26th June 2014 23:34
Gypsy on Steroids: Maxxis Trepador M8060 MT. Update Now on Yoko Geolander MT! khan_sultan 4x4 Technical 102 27th August 2010 16:46
A Pure Off-Road Spec Gypsy Build | SPoA, Lockers, Bumpers etc etc. swastikviji 4x4 Vehicles 81 16th July 2010 16:54
Gypsy on Steroids: Next Dose -- Short Chassis for reduced rear overhang khan_sultan 4x4 Technical 56 24th March 2009 12:39
