Old 21st March 2009, 16:47   #16
Well, Item 21 could spice things up a bit but CL340 owners and their parts may not like it.
hrag is offline   Reply With Quote
Old 21st March 2009, 17:29   #17
SS-Traveller's Avatar
Thanked: 11,631 Times
Originally Posted by Jaggu View Post
1: fuse
3: Dash light cover
4: Connector wire?
7: some shims, used in wheel side or axle?
9: bulb holder
10: F Brake pads
11: R Brake pads
12: Speedo cable
13: R Bulb
14: HL Bulb
15: Free wheel hub cover
17: Engine mounts?
19: Brake cylinders
20: Wheel bearing?
No 4x4 vehicle yet, but guess someone did a minor overhaul or cleaned up the garage now lol
Jaggu, I think your IDs are mostly correct.
1: Capsule fuses
2: 7" Lucas-type headlight beam adjusting screws
3 & 4: As above
5: Bearing outer collar - fits item 20.
6: Hub grease cap.
7: Non-standard item? Shim?
8: Hub plate?
9: Headlight bulb holder
10 & 11: F & R brake shoe liners
12: Speedometer cable
13 - 15: As above
16: Some kind of remote??
17: Engine mountings
18: Brake shoe cam? not a clear picture
19: Wheel cylinders
20: Wheel bearing
21: Differential-tube mounting gasket
How many marks do I get, Sir??
Old 22nd March 2009, 04:47   #18
Crazy_Eddy's Avatar
Thanked: 25 Times
Originally Posted by Ym-enjn View Post
Anyone wants to make a guess for no:18
At the risk of sounding stupid, is it a pen drive?
Crazy_Eddy is offline   Reply With Quote
Identify the parts razor4077 Technical Stuff 5 6th June 2011 13:06
Spare Parts - Sundar Auto Parts (Worli, Mumbai) aah78 Mumbai 1 9th June 2010 12:46
Tweeters - can you identify these RAC In-Car Entertainment 36 6th September 2008 13:53
Identify the Cars! Pferdestärke The International Automotive Scene 11 10th April 2004 18:30
