Old 20th March 2009, 12:19   #1
Ym-enjn's Avatar
Thanked: 55 Times
Default Identify these parts.
Lets see how many of us know our Jeeps inside out. These are few parts from CL340. Identify them.
PS: You can add your stock of parts in the same thread but do number the parts before adding images.
Ym-enjn is offline   Reply With Quote
Old 20th March 2009, 12:20   #2
Spitfire's Avatar
Thanked: 707 Times
What does the winner get?
Spitfire is offline   Reply With Quote
Old 20th March 2009, 12:38   #3
Thanked: 35 Times
Attachment 113882
Ym-enjn: I could only hazard a guess (or 3). The coiled-python is a speedo cable, the 4 non-blonde segments above it- brake linings, next is a hand-brake light switch on the left.
netchef is offline   Reply With Quote
Old 20th March 2009, 12:47   #4
Alfa_Kilo's Avatar
So you are changing the front flanges. Are the front halfshafts OK?
Alfa_Kilo is offline   Reply With Quote
Old 20th March 2009, 12:51   #5
esteem_lover's Avatar
Thanked: 451 Times
Coiled python is the clutch cable methinks.
Old 20th March 2009, 12:53   #6
trammway's Avatar
Thanked: 220 Times
1. The four items(No.19) on the right side is Break cylinders
2. The four items(No.10) on the middle row is Break liners
3. The 2 solid items(No.15) on the 2nd row from right side is either engine beds or main gearbox beds.
4. (No.8 & No.7)circular plates seems to be steering knuckle kit part
5. (No.21) The shim used in either knuckle or with the king pin setup
6. (No.14) is headlight halogen bulb
7. (No.13) is the Indicator bulb from front assy. (Same bulb used for Indicators and Parking)
8. (No.1) is fuses not sure what amp but used in electrical setup.
I think i can identify other parts too, but not really able to recollect the technical terms.
I have undergone the same part changes couple of months ago. See it in my blog, if you want further information it is written over there.
trammway is offline   Reply With Quote
Old 20th March 2009, 14:13   #7
Thanked: 35 Times
esteem_lover: Ah. Quite possible.
Old 20th March 2009, 14:16   #8
I know "Item" 21. That is Katrina Kaif, isn't it?
hrag is offline   Reply With Quote
Old 20th March 2009, 14:42   #9
chandan's Avatar
Thanked: 46 Times
Good one Hrishi & 20 is A.R Rahman
chandan is offline   Reply With Quote
Old 20th March 2009, 15:04   #10
Ym-enjn's Avatar
Thanked: 55 Times
Anyone wants to make a guess for no:18
Old 20th March 2009, 15:07   #11
siddartha's Avatar
Thanked: 24 Times
this i very much expected from you .
siddartha is offline   Reply With Quote
Old 20th March 2009, 15:14   #12
Jaggu's Avatar
Thanked: 8,686 Times
1: fuse
3: Dash light cover
4: Connector wire?
7: some shims, used in wheel side or axle?
9: bulb holder
10: F Brake pads
11: R Brake pads
12: Speedo cable
13: R Bulb
14: HL Bulb
15: Free wheel hub cover
17: Engine mounts?
19: Brake cylinders
20: Wheel bearing?
No 4x4 vehicle yet, but guess someone did a minor overhaul or cleaned up the garage now lol
Old 20th March 2009, 23:52   #13
sreerajunnithan's Avatar
lol!!! Yes very much expected from this truck driver
--Sree--
sreerajunnithan is offline   Reply With Quote
Old 21st March 2009, 06:01   #14
harjeev's Avatar
Thanked: 256 Times
I think that this thread will be quite an useful guide for anyone to identify any parts. Thanks to all the experts sitting amongst us.
I myself will post a couple of pics later today, some parts I was not able to identify...
Also just as a suggestion, along with the parts if we are able to give an approx cost of the a new part, it will help fellow Bhpians to have an idea, on how much to pay...
harjeev is offline   Reply With Quote
Old 21st March 2009, 14:56   #15
siddartha's Avatar
Thanked: 24 Times
--Sree--
atleast he wasnt trying to identify "item" no 21 's parts!
Identify the parts razor4077 Technical Stuff 5 6th June 2011 13:06
Spare Parts - Sundar Auto Parts (Worli, Mumbai) aah78 Mumbai 1 9th June 2010 12:46
Tweeters - can you identify these RAC In-Car Entertainment 36 6th September 2008 13:53
Identify the Cars! Pferdestärke The International Automotive Scene 11 10th April 2004 18:30
