Old 23rd March 2009, 20:56   #1
4x4addict's Avatar
Thanked: 2,669 Times
Default Armada Grand 4WD Modifications
I recently came across an Armada Grand 4WD for sale. I remember Arka mentioned a while back about an idea he had to cut the chasis to shorted the wheelbase to the MM550 wheelbase. This way you get an MM550 XDB with AC/PS/New Generation Chasis/Disc Brakes etc..
I read on the Munnar OTR thread that there was a 540 which was was on a shortened Armada chasis.
I would like to get opinions from the forum about the pros and cons of actually cutting the chasis in the middle to shorten the wheelbase. Is there a way to do it and still maintain the strength of the chasis.
4x4addict is offline   Reply With Quote
Old 24th March 2009, 00:22   #2
grounddesigns's Avatar
hi, its a good idea if you planning to make it short...the best way you can do is cut the frame in cross style and removing the unwanted size rejoin it by welding it either co2 or argon welding if not you can do regular electric welding with proper rod. then make a c channel plate more than a feet size and fit it from outer side facing inwards and either spot weld it or do nut-bolt or rivit system. i have done couple of jeeps it works fine.
grounddesigns is offline   Reply With Quote
Old 24th March 2009, 00:49   #3
Alfa_Kilo's Avatar
It is possibe to maintain the strength if the welding is done properly with some reinforcing members added. The tricky part ensuring that the 'new' chassis remains true, i.e. perfectly straight. Gas cutting and post weld distortions will make this very diffficult. Even if there is 0.5 degree of error, you will feel the vehicle crab on the road. I would not recommend playing around with the chassis.
Another problem is that Armada Grand/Bolero wheelbase NGCS vehicles have very poor front axle articulation.
You can get disc brakes installed on an older 540 with relative ease. The Classic, MM550XD and Armada are some of the pre-NGCS vehicles with servo assisted disc brakes.
Alfa_Kilo is offline   Reply With Quote
Old 24th March 2009, 11:35   #4
vinod_nookala's Avatar
Thanked: 416 Times
Hi tini,
I feel it is too much of a pain! Why dont you use it as a famility 4wd tourer? Do a good custom paint job, add 31 inch tyres, lower the diff ratio from 4.88 to 5.38. Armada grand has good NVH characterstics so it will be good on-off highway vehicle. You have MM540 Di turbo for your off road duty, make armada grand as a 4wd tourer.
vinod_nookala is offline   Reply With Quote
Old 24th March 2009, 11:40   #5
JayD's Avatar
Thanked: 2,008 Times
Considering that you are anyway chopping it, and that you already have a 540, why not make it a SWB?? Should be a hoot off road!
Old 24th March 2009, 12:19   #6
Thanked: 48 Times
I agree with you. Getting the Strength/chasis stiffness will not be a problem. Whereas unless proper fixtures with location pins/features are used before cutting the chasis, it will be a dicey and errors are bound to happen while re- joining
Suresh Stephen is offline   Reply With Quote
Old 24th March 2009, 19:58   #7
Thanked: 655 Times
Maybe I can help you by getting you a Grand chassis?
jyobeb is offline   Reply With Quote
Old 3rd April 2009, 19:46   #8
whicked wheels's Avatar
Thanked: 56 Times
Hi 4x4addict, why do you want to chop it why dont you try doing some thing like this (pictures), i too have found an armada 4x4 and ill be doing something like this.
whicked wheels is offline   (1) Thanks Reply With Quote
Old 5th April 2009, 01:20   #9
Parm's Avatar
Thanked: 611 Times
yeah rather than making it into a SWB or like 540/550, make it different family size 4x4.
here is one more option for you. this guy has done a good job and posted these two photos some where in this forum. hope this guy doesnt mind me posting these two photos here for inspiration to others.
Parm is offline   Reply With Quote
Old 5th April 2009, 01:30   #10
Parm's Avatar
Thanked: 611 Times
sorry i missed these two photos in my earlier reply! so here they are.
Old 5th April 2009, 17:58   #11
jeepster's Avatar
Thanked: 1,036 Times
Smile
hi 4x4addict
please if you buy it don't shorten it,you can make a good offroder having some bling & a little more practical then swb 550.
if you google offroad it will give you results containing more & more long wheel base jeep or you can go to any offroad forum ,you will be surprised to the number of lwb vehicles there..
as you know i have lwb mahindra which i will be doung similar modifications in future.
jeepster is offline   Reply With Quote
Old 5th April 2009, 18:12   #12
jeepster's Avatar
some pictures
Old 5th April 2009, 19:02   #13
Thanked: 23 Times
Jeepster whats that big metal thing on the roof for ? Is it just a roofrack , if yes then whats the use of it being hinged like that ?
bigman is offline   Reply With Quote
Old 6th April 2009, 09:08   #14
jeepster's Avatar
hi bigman
i think it is a roof rack but i dont know about its use.
may be its used for camping or otr or something like following .
Old 14th April 2009, 14:28   #15
Brutus's Avatar
Thanked: 45 Times
Hey , i think i figured it out, it hinged for Solar panels.
Brutus is offline   Reply With Quote
2000 Armada Grand 4WD svsantosh 4x4 Vehicles 217 14th January 2015 14:43
Mahindra Armada - 2WD to 4WD conversion possible? powertrain 4x4 Technical 48 15th October 2013 20:10
Armada Grand wildsdi5530 SUVs, MUVs & 4x4s 28 17th December 2010 07:40
Rolling Armada Grand Suresh Stephen 4x4 Technical 2 28th July 2010 14:36
Armada Grand 4wd or Bolero 4wd? VEA 4x4 Vehicles 38 25th July 2010 01:50
