Old 28th March 2009, 14:14   #16
nitrous's Avatar
Thanked: 283 Times
Originally Posted by Cloud_Chaser View Post
Out of curiosity I wanna ask the experts, for an Baleno Engine Swap to non MPFI Gypsy does the wiring needs to be changed? what about the ECM?
Yeah,its going to get very complicated.
I assume Mexxentric is going to go the carb way.
@ Mexx: Did you think about using the gearbox casing of the baleno?
Old 28th March 2009, 16:19   #17
MexXxentric's Avatar
Thanked: 11 Times
I am transplanting an MPFI 1.6 l engine only.
The wiring part is a bit challenging than the mechanical works.
But my mech. is quiet confident about the project.
The ECM and wiring (to sensors) will be removed and kept safe while the engine is being transplanted. It will be reconnected only at the fiinal stage.
Since the transplant is happening from a donor vehicle( not installing an engine procured alone.) , less hazels are expected.
After all we got a team of experts here na?
MexXxentric is offline   Reply With Quote
Old 29th March 2009, 16:37   #18
Thanked: 11 Times
Smile Updates.
The donor's engine ( 1.6l) is separated from G.B and taken out.
From rough measurements. the flywheel fits in the King's G.B bell housing.
(its going to be a bolt on fitting )
Now comes the clutch. Which clutch plate is advisable? Gypsy's or Baleno's
http://www.team-bhp.com/forum/techni...t-changed.html (Pics: How a baleno clutch got changed)
From this thread I understand that esteem's and baleno's clutch plates are interchangeable.
If its so, will baleno's clutch fit in the Gypsy King's power transmission shaft?
some photos of the donor.
I am still searching for the gear ratios of baleno's gear box.
Old 2nd April 2009, 09:46   #19
Thanked: 11 Times
Default Sorry
Friends,
I apologize for a mistake from my side.
The baleno's flywheel is a way bigger to be accommodated in Gypsy's gear box.
i've to use the 1.3l engine's flywheel & clutch plate.
Old 2nd April 2009, 13:10   #20
Blue Thunder's Avatar
Thanked: 330 Times
Exclamation
Originally Posted by MexXxentric View Post
...The baleno's flywheel is a way bigger to be accommodated in Gypsy's gear box.
Are you sure you can use the flywheel of the 1.3L engine on the Baleno engine? I think there could be problems.
The clutch may be the same on the Esteem and Baleno...they can be designed to operate on a range of power/torque values, but a flywheel may be less tolerant to changes in operating parameters.
Blue Thunder is offline   Reply With Quote
Old 4th April 2009, 03:28   #21
Thanked: 11 Times
In similar mods done in U.K, they have used the 1.3l engine's flywheel in 1.6l engine.
I guess that the rpm of the engine will be the stress parameter.
will a dynamic balancing of the flywheel solve the problem?
Old 4th April 2009, 18:04   #22
Thanked: 11 Times
Default Adapter plate drawing
Adapter plate drawing to mate G16 engine & G13 gearbox
Picasa Web Albums - Mexxxentric - Project MG 416
Old 5th April 2009, 16:27   #23
Jeeper's Avatar
Shall I jump in the forum for other way around concept as engineering point of view discussion will be vice versa.
I met with an accident and had to divert my fund of 4X4 unexpectedly for sedan and got an SX4. Now my accent is repaired and back in business.
After preface, lets talk business is it possible to convert SX4 4x2 to 4X4 if so I am interested??
The SX4 in foreign is famous and liked as 4x4 Hatch and the model in india the sedan is introduced as Suzuki Balano.
Jeeper is offline   Reply With Quote
Old 12th April 2009, 15:01   #24
Thanked: 11 Times
Default Can it Be Legally Endrosed?
Iam curious to know if its possible to get the engine change endrosed in R.C book?
I heard that there is one provision that permits Engine change ( an engine with different specifications) if the manufacturer of the vehicle is no longer producing the same engine.
In vintage cars this is generally done.
Any clue on this?
Old 17th April 2009, 16:42   #25
ilangop's Avatar
Thanked: 581 Times
Any clue on this?
Engine change can be endorsed in the RC book. As much I know, you need to produce a bill from where you had bought the engine. If you had taken it from scrap or from another vehicle, you can as well manage to produce a bill from any auto part trader by paying him for what ever will cost him as tax. Only thing to be observed is that you cannot record a change in engine and chassis simultaneously in the same occassion. There needs to be a gap of at least 6 months between the two. But dont worry about all there. Almost every agent will be able to do this for you.
BTW it is a fantastic job what you have been doing, and my best wishes for the successful completion of the same.
-Ilango.
ilangop is offline   Reply With Quote
Old 23rd April 2009, 00:41   #26
Thanked: 11 Times
Default some more picts
Post edited by the Team-BHP Support : Please do NOT use external picture hosts such as photobucket, imageshack etc. We advise you to read our board rules carefully, before proceeding any further.
The baleno heart.
the water outlet on the firewall side will be a brain teaser. Need ur inputs
Gypsy king's GearBox with Gypsy King's flywheel
King's gear box- another view
Baleno Gearbox
Closer view of baleno engine block
Baleno's Flywheel dimension
King's Flywheel dimension
Clutch cover assembly comparison
photos and description by Ashwin Raj (ashwar87) Thanks Ashwin
MexXxentric is offline   Reply With Quote Received Infraction
Old 2nd June 2009, 16:22   #27
rmonie's Avatar
Thanked: 43 Times
Default Updates?
Mexx, any further updates on this project? I am getting inspired!!
rmonie is offline   Reply With Quote
Old 5th June 2009, 06:55   #28
Thanked: 11 Times
Default :-(
The project is crawling because.
I couldn't find a nice Wide Track gypsy matching my expectations.( minimum rust and well maintained)
I just can't go ahead with
The current challenge is the lengthy water outlet. The assembly houses temperature sensor also
The current plan is to modify the part marked in red. The straight pipe will be cut short, threaded and a mandrel bent U pipe will be attached to save 5 cm of space.also, the new water outlet will be facing front of the vehicle.
The temperature sensor housing(marked green) will be kept undisturbed
Old 12th June 2009, 03:03   #29
Thanked: 11 Times
Default gotchaaaa gypsy...
1995 model wide track with alloys,ac & custom 2 seater soft top
Old 24th June 2009, 08:32   #30
rmonie's Avatar
Thanked: 43 Times
<Bump> Any progress? Congrats on the new acquisition!
Project Titan - Apple's rumored new Electric Car Project bharat.joshi The International Automotive Scene 30 5th December 2016 19:04
Help needed!! Car project.. barbar Shifting gears 12 19th March 2006 14:57
The Golden Quadrangle Project GreenHex The Indian Car Scene 17 28th September 2004 16:40
New Honda NSX (HSC) project is back on again. Sheruken The International Automotive Scene 3 15th July 2004 23:22
virtual project:old fiat into old mini cooper aadix The International Automotive Scene 3 25th April 2004 15:39
