Old 12th October 2010, 09:57   #106
pdev29's Avatar
Thanked: 258 Times
Originally Posted by krishnathanthri View Post
I feel 410W will be a better model for 416 conversion.
Apart from this you have to get king GB(with king clutch) + King Transfer case + Baleno Engine(with ECM, manifold) or only Baleno Engine and convert it to CARB.
Krishna Thanthri
TCASE could be retained. only the GB needs to be replaced.
pdev29 is offline   Reply With Quote
Old 12th October 2010, 10:08   #107
karizma9292's Avatar
Thanked: 210 Times
Originally Posted by MexXxentric View Post
Check for the cooling water outlet. it should be on the flywheel side of the engine block.
Baleno is front driven & so engine is cross mounted.
The same engine need to be mounted longitudinally in gypsy.
Thanks mexxentric , i will check that right away . bro your experience about your conversion has given me much more confidence .Thanks a lot . Had sent you a PM long time back regarding this but no reply . WHat is amount you spent for conversion excluding the engine & GB?
karizma9292 is offline   Reply With Quote
Old 12th October 2010, 11:07   #108
Thanked: 652 Times
Hello Sreejit, we are gald & excited to see your falcon flying on the road, i like that RX100 comparison it gives the excat feel you get on driving. I wish to have it test drive one day, did u tried any off road? post a lot more pics including the interiors, did you retained the A/C from the baleno? What you done to have the height increased? Many more questions i'll give you a call later.
CONGRAGULATIONS ...
Anil Vincent is offline   Reply With Quote
Old 12th October 2010, 11:26   #109
pdev29's Avatar
Thanked: 258 Times
@MexXxentric,
did you try to take her offroad?? try some extreme stuff but little slowly to check if your oil sump is touching hitting the diff or no. this is one common problem in conversion.
Old 12th October 2010, 11:30   #110
Thanked: 226 Times
Originally Posted by pdev29 View Post
@MexXxentric,
Devang,
Very good advice. when I fitted Isuzu engine, the mechanic with out being told (offcourse, I did not know to tell) had made alteration in the sump cover to avoid touching of differential.
dwaraka is offline   Reply With Quote
Old 12th October 2010, 23:58   #111
MexXxentric's Avatar
Thanked: 11 Times
Originally Posted by karizma9292 View Post
Had sent you a PM long time back regarding this but no replyon
Apologies...
I was not active in t-bhp for 3 months. meanwhile I got married
Today only I saw PM from you, devang and many other bhpians
CONGRAGULATIONS ...
Thanks Anil. U & Aneesh were of great support throughout the project.
you are most welcome to test Falcon.
Interiors are yet to be done. Even the AC unit.
Baleno's blower unit is way too bulky to be installed in Gypsy.
Iam retaining baleno's AC compressor.
Those recaros picked by me & Aneesh are yet to be installed.
Couldn't get time or a group to test falcon off the road.
For increasing height, the front leaves were re-cambered to balance the height of CFLs in rear.
@MexXxentric,
Dev,
I will keep this point in mind. Will do some trial before doing something extreme.
Falcon doesnt have the OE baleno sump. I've changed it to the G16A's sump( pictures & details are available in previous posts)
The new sump got oil storage area near the flywheel, not directly above the differential hub.
See the attached picture and do post your opinion.
I am using 410's transfer case only.
The engine& GB combo was installed maintaining OE position of Transfer case & GB mounting point.
Thanks bro. Glad to hear something like that. Actually many bhp-ians shredded their 416 dreams seeing my struggle.
Finding an electrician who can rebunch the ECM wiring & link baleno's engine parameter readings to gypsy's console is 'the key'
MexXxentric is offline   Reply With Quote
Old 13th October 2010, 10:11   #112
Thanked: 210 Times
Apologies...
No prob brother , Congrats on getting married , now i know why you were off Team-bhp for 3 months . Have a happy married life
My mech is a classic car restorer and successfully done a Toyota 2c conversion for a gypsy so he gave me the confidence that it can be done
Old 13th October 2010, 13:58   #113
Thanked: 652 Times
Default A.c
Compressor mounting is the most trickiest part as there is not much space to accomodate it inside the bay. Now you may go for the super king cooling coil & blower unit which will fit pefectly inside the gypsy dashboard with out any kind of alteration and you can use the original vents on the dash board also. With the kind of roof setup you have the passenger compartment will turn into a chiller room in minutes during peak summer also.
Have the interiors also done up quickly, so that you have a bit of luxury along with the power together. As good as (or even better than) any modern suv in todays market.
Old 13th October 2010, 18:34   #114
Thanked: 56 Times
Brother, I am planning a MG416W myself. So looking for a donor car first . I hav a couple of queries for you
1. Can the donor car's wiring harness be utilised in the gypsy ? If not completely then upto what extent?
2. What should be a good price for a 2000 baleno with CNG 95000km done? I guess you bought a similar donor.
Sumit
autoholic is offline   Reply With Quote
Old 13th October 2010, 21:25   #115
Thanked: 11 Times
Good luck bro. do a lot of googling & that will help a lot.
Falcon already had superking-sanden combo.
After installing a BIG radiator, I am left with the option to have under body mounted condenser.
Most AC technicians are reluctant to do this. I need to find the right guy to get it done. searching patiently....
Can we fix superking blower( which use R12) with the baleno compressor designed for R134a?
Sumit
All the best bro..
1. Yes wiring harness can be completely used. In my 416, we relocated the thermostat & ECT assembly & so the specific strand had to be spliced.
Rest all were re-bunched.
2.No idea regarding the market as I am working abroad. My donor was a totalled baleno.
Old 14th October 2010, 11:04   #116
Thanked: 1,082 Times
R134a uses higher pressure than R12. If the blower (I assume you are talking of the blower+condenser assembly) is metallic, which it normally is, then higher pressure would not matter. In fact when I upgraded my Esteem AC from R12 to R143, all rubber pipes and compressor were changed, leaving the old metal pipe and the condenser/blower unit. I could have retained the compressor also, but changed it as it would give me at least 5-10 years of service! The only difference in compressors, according to the AC dealer, is that there is special oil filled in compressor for R134, along with different rubber seals, otherwise both the compressors are same.
Old 15th October 2010, 00:28   #117
Thanked: 11 Times
So basically its a change in plumbing. Good news for me.
the technician mentioned that the thermostat also need change & quoted and additional cost for this mod.
Its hight time to dig for AC related threads
Old 15th October 2010, 10:54   #118
Apart from other things what you have to change/replace; is the gas and the moisture absorber, called the "bottle' by AC mechanics; every time the AC plumbing is opened. My AC shop has advanced machinery, which extracts and stores the gas when servicing the AC. In your case, if the engine is salvaged then normally the AC line is just disconnected, requiring new gas and moisture trap. Regarding the thermostat, it is normally within the condenser (inside unit). The Baleno original unit is quite good and if available can be used as it is.
Please note that if you put a larger inside unit to give more cooling, then the out side unit, the heat exchanger, should also be upgraded, else the AC will not cool enough due to insufficient heat extraction (that is one of the reasons why my Esteem's old heat exchanger was replaced by new efficient one, when I changed from R12 to R134.
Old 6th June 2011, 01:08   #119
Default Re: Project MG 416 W
Even after going through entire thread I am still canfused. Is it that if the doner vehicle is a MG410W, for the G16B swap is it required to change the following:
1. G16B Engin.( wiring Harnes, ECM).
2. King Gear box.
3.T Case, from King.
4. F/R Differentials, from king.
1 and 2 are the obvious, is it required to change 3 and4. Experts pleas comment.
Thanks,
Vamsi.
vamsi_dvk is offline   Reply With Quote
Old 6th June 2011, 09:49   #120
jeepster's Avatar
Thanked: 1,036 Times
2. King Gear box.
yes
the transfer case is little different from 410.
MG410W TC
HI :1.578
LOW :2.511
MG413W TC
HI :1.409
LOW:2.268
differential ratios
MG410 & 410W 4.10:1
MG413 3.73:1
also the king's axles are wider than 410's axle so it will be more stable on road.
MG410 1210mm front and 1220 mm rear.
MG410W / MG413 a 1300mm front and 1310mm rear.
source:
http://www.team-bhp.com/forum/4x4-te...ar-ratios.html (Gypsy Gear ratios)
http://www.team-bhp.com/forum/4x4-ve...ml#post1133852
rgds,
Nikhil
jeepster is offline   (1) Thanks Reply With Quote
Project Titan - Apple's rumored new Electric Car Project bharat.joshi The International Automotive Scene 30 5th December 2016 19:04
Help needed!! Car project.. barbar Shifting gears 12 19th March 2006 14:57
The Golden Quadrangle Project GreenHex The Indian Car Scene 17 28th September 2004 16:40
New Honda NSX (HSC) project is back on again. Sheruken The International Automotive Scene 3 15th July 2004 23:22
virtual project:old fiat into old mini cooper aadix The International Automotive Scene 3 25th April 2004 15:39
