Old 11th June 2011, 02:48   #121
Default Re: Project MG 416 W
Thanks a lot Jeepster, It is very informative.
Vamsi.
vamsi_dvk is offline   Reply With Quote
Old 6th July 2011, 02:01   #122
MexXxentric's Avatar
Thanked: 11 Times
Vamsi.
for offroad use, it is not necessary to change the differentials & TC.
I still have not changed it on my 416
You can easily accommodate taller tyres in such a setup and compensate the lower final drive.
Installing taller tyres in a stock gypsy drivetrain(410 or 413) demands crawler gears to be installed to prevent loss of torque.
If u r planning to retain stock tyre size, options 3 & 4 are mandatory.
MexXxentric is offline   Reply With Quote
Old 11th July 2011, 22:34   #123
Twinn's Avatar
Thanked: 278 Times
Default Re: :-)
Originally Posted by MexXxentric View Post
On a drive from Erode to Kollam, Falcon returned 16kmp
I hope that this will 'improve' once I upsize my wheels
Experts please suggest tyre upgrade options.
One more reason why I want to go for the 1.6 conversion, just returned from a 2500 km drive, got a average of 9 km. BTW I have a 1.3 king carb with 235 rubbers
Neat engine bay you have there, so all the electrical glitches are over or are they dying down one by one?
Twinn is offline   Reply With Quote
Old 13th July 2011, 00:09   #124
Thanked: 11 Times
I had 215/75 shoes .
Thanks. Credit goes to ashvar87 & Karthik (the mech)
The VSS input to the ECM is null. So check engine light is on.
Otherwise 416 is doing good.
Will post Picts of phase 2 mods soon.
Cabin
Covered boot
Winch bumper
Rock sliders
& new paint coat.
Old 13th July 2011, 00:26   #125
Thanked: 52 Times
Replied your PM buddy.
Have more info for you Buddy.
In the BIG coupler attached to the rear of the meter, you will find a Brown Wire with Yellow stripe(Second/Third wire from one of the corners). Well this is the wire you are looking for.
Hope this helps you further.
autoholic is offline   Reply With Quote
Old 13th July 2011, 21:57   #126
Thanked: 11 Times
Thanks a lot bro....
I will get mpfi 413's combination meter & try it out.
Old 14th July 2011, 14:54   #127
Twinn's Avatar
Thanked: 278 Times
Cabin
Covered boot
Winch bumper
Rock sliders
& new paint coat.
So you mean your speedo is not working? VSS input if for that right? Posts the pics will keep us glued
Old 19th July 2011, 11:01   #128
Thanked: 11 Times
Speedo(410w's) is in working condition.
It doesn't have integrated VSS, hence can't give the VSS signal.
I need to get mpfi king's combination meter to fix this bug.
Will post Picts of new paint scheme and cabin soon.
I found an ac mechanic who agreed to mount condenser under the chassis.
Old 21st July 2011, 03:39   #129
Desmosedici's Avatar
Thanked: 408 Times
So Sree, did you also do a highway run like Allan had done? Whats the Top Speed you go to with the Falcon? Is there anything thats different between what you and Allan have done, asking this since i know you guys were in touch helping each other out.
Desmosedici is offline   Reply With Quote
Old 26th July 2011, 12:25   #130
IndrojitSircar's Avatar
Thanked: 113 Times
I sent you a PM asking for some help regarding the Baleno Engine you installed. Could please check to see if you recieved it?
What's the present status on the caR?
Old 27th July 2011, 00:42   #131
Thanked: 11 Times
I did test falcon on road. but not extensively as Alan did.
First gear is ultra low. I could easily take off from stand still in second gear & falcon briskly shifts to top gear. I can compare it to driving an RX100.
Relaxed cruising speed was 60kmph
Top speed was 120kmph. (without deducting speedo error)
Off the road the gear ratios were comfortable
I felt the need of taller tyres on highways to increase the final drive.by the time my vacation was over & i shelved the project.
I dont know if Alan did change his transfer case & axles ratios.
Alan had taller tyres & extended shackles. Falcon had stock suspension & tyres.
Both have FFE & performance filters. but done by different tuners.
Falcon's FFE is tuned for low end torque & I wanted to have a low note .So i guess its more restrictive than Alan's
VSS bug is yet to be fixed in Falcon. I am waiting for MASS to deliver King's meter console.
Initiated the second phase of project few months back.
Falcon was stripped to bare metal( tub off the chassis), tinkered & given anti rust coat.
1.5 inch body lift was done
Lockable cabin was fabricated
better seats were made
New paint coat ( pearl white + matte black)
Winch bumpers & rock sliders from swastik fabs are ready to be installed
31 inch tyres & new alloys are also in pipeline
Will post WIP pictures in detail.
At present FALCON looks like this
MexXxentric is offline   (2) Thanks Reply With Quote
Old 27th July 2011, 00:50   #132
Thanked: 408 Times
Cabin looks very neat from what i can see. Could you post more snaps of the whole vehicle, would help note the dimensions of the cabin you have prepared. plus i always wanted to ask you or allan regd the difference in the topspeed of both your vehicles.
Keep posting pics Sree, it keeps us glued.
Cheers,
Raj
Old 31st July 2011, 16:01   #133
Thanked: 113 Times
Are you using the Baleno Engine wiring and the Baleno ECU ? Also what are the instruments that you are using ? Using the 410 meters or using other meters ?
Old 1st August 2011, 18:56   #134
karizma9292's Avatar
Thanked: 209 Times
Its best if you use baleno wiring & ECU if you are going for a full baleno engine swap , or if you are just changing the baleno bottom to a stock MPFI 1.3 engine you can retain the original 1.3 wiring & ECU . 410 meter console can be used & if you are going in for a vehicle speed sensor (VSS) then you will have to use Gypsy MPFI meter console.
karizma9292 is offline   Reply With Quote
Old 1st August 2011, 22:49   #135
Thanked: 113 Times
The base car would be a 1.3 Carb and the Engine is a Euro III Baleno with ECU and wiring. There are problems with the cam position sensors apparently on many cars with the Baleno ECU and wiring & RPM fluctuation problem. Another way to go about it using the Gypsy Wiring and ECU along with the gypsy cam position sensor so that the meters work and also there are no problems in the RPM fluctuation.
Looking for more inputs.
Project Titan - Apple's rumored new Electric Car Project bharat.joshi The International Automotive Scene 30 5th December 2016 19:04
Help needed!! Car project.. barbar Shifting gears 12 19th March 2006 14:57
The Golden Quadrangle Project GreenHex The Indian Car Scene 17 28th September 2004 16:40
New Honda NSX (HSC) project is back on again. Sheruken The International Automotive Scene 3 15th July 2004 23:22
virtual project:old fiat into old mini cooper aadix The International Automotive Scene 3 25th April 2004 15:39
