Old 24th March 2009, 16:32   #1
MexXxentric's Avatar
Thanked: 11 Times
Question Project MG 416 W
Hellow Friends,
I am planning to unleash my dream project. - MG 416 W
The target is to install a Baleno's 1.6 liter engine in Gypsy King ,and retaining the 4x4 of course.
Experts, please advise me on the feasibility of the project, expected bottle necks and problems, hardware requirement, legal issues, approximate cost involved, etc etc.
MexXxentric is offline   Reply With Quote
Old 24th March 2009, 18:36   #2
Thanked: 103,639 Times
These threads would be great places to start:
1. Swapping with a 1.6 engine (Gypsy engine swapping with Baleno 1.6L engine ?)
2. Gypsy options (Engine options for Gypsy.)
Old 24th March 2009, 18:44   #3
Brutus's Avatar
Thanked: 45 Times
Saw an Army rally gypsy same days ago at the Sjoba rally,chandigarh, and it had just this sort of an arrangement. The driver was Capt.Amrinder Brar, and i think he is rated at No.06 in the Indian rally circuits. Also another famous rallyist, Sunny Sidhu is rumoured to have this arrangement in his factory sponsored Gypsy.
There are kits available abroad to mate the 1.6 to the factory gearbox, but since these rally vehicles were basically factory sponsored, it is highly likely that Maruti made their own in-house kits.
Infact, taking about Gypsy motor mods, there is a kit for available to mate the fiat/volks 1.9/1.9td motor to the gypsy gearbox. This is the same motor as was used in the previous generation fiat palios(India's last yr and ealier versions) and also the scoda octivia. If someone's come out with a kit to plant a coal burner where originally an 85Kgs(only) motor was to take command, means that the 1.9Td motor is amongst the lightest diesel motors available. I say this because the Toyota 2CT motor, that people in India generally build into a contraption weights 210kgs.
Brutus is offline   Reply With Quote
Old 26th March 2009, 13:40   #4
Thanked: 11 Times
Smile Some Interesting Links
I've been googling for the topic and i came across some interesting case-studies of the similar type of conversion done in UK.
The links are
Swapping 1300 cc engine to 1600 cc in my Samurai
this tells about a 1.6 liter ( 8valve ) carb. engine swap. I guess that its a G16a engine.
G16a into a samurai - Suzuki Forums: Suzuki Forum Site
The second link is more informative.
From the above links the challenges in the conversion will be
1. Mating the G.B to the the engine ( with or without using adapter plate? )
2. Which flywheel & clutch plate should i use ( 1.3 Gypsy King's or 1.6 Baleno's)
3. Mounting the engine. What all changes are required in the engine foundation
4. to close the hood due to Height of the engine ( should i go for body lift?)
5. The front axle hitting the Oil pan of the 1.6 engine. ( I am not interested in SOA or similar works)
6. Radiator installation ( as 1.6 is a transverse engine )
7. How to handle the extra weight of the engine?
Old 26th March 2009, 14:47   #5
IronWolf's Avatar
Thanked: 36 Times
There is one Black Gypsy which is in Mumbai. Check the Mumbai OTR posts. It faired quite well at the OTR. Monstrous sound as well.
IronWolf is offline   Reply With Quote
Old 26th March 2009, 15:21   #6
Thanked: 11 Times
Talking Specs. needed
Friends got a 2001 Baleno Lxi (side impact accident vehicle with almost intact engine bay)
can anyone enlighten on the engine specs.?
Google cant help me in this :-(
What all components can be transplanted to Gypsy?
I plan to take the following
Engine with flywheel &starter,
Alternator,
P.S pump,
AC ( atleast compressor)
Fuel filter and Pump.
Brake booster ( will it be an over kill?)
Windscreen washer unit
LPG Kit ( yeah the baleno had LPG kit on it )
Petrol tank ( to serve as a secondary tank)
Front Seats ( if its ergonomically safe)
Again awaiting your suggestions.
Old 26th March 2009, 16:04   #7
nitrous's Avatar
Thanked: 285 Times
There's one in bangalore as well.
Old 26th March 2009, 16:28   #8
pdev29's Avatar
Thanked: 258 Times
guys we have got 3-4 MG416 in my group, its a simple and reliable mod.
you will fall in love with the gypsy after this swap.
All you need is gypsy king, if you have gypsy 1.0 then you will have to get the 1.3 gearbox.
there is a pic of black 416 in one of my offroad season thread.. check it out
pdev29 is offline   Reply With Quote
Old 26th March 2009, 16:32   #9
nitrous's Avatar
Thanked: 285 Times
Are they carburetted or fuel injected, Pdev?
Old 26th March 2009, 16:49   #10
Thanked: 11 Times
Thanks PdeV, can i have some under the hood pictures or the contact info of the 416's owners? It will help me a lot.
I've outsourced the engine as well as king's G.B ( Ashwar87 outsourced them for me. )
My mechanic is suggesting to go with 1.3's Flywheel in the 1.6 engine so that it will fit inside the King's Gear box. But Iam a bit confused.
Which starter motor should be used? 1.3's or 1.6's ??
Old 26th March 2009, 19:43   #11
ashvar87's Avatar
Thanked: 146 Times
hi friends,
i just want to add few more doubts with what mexxentric has stated above, reg the clutch plates,is that good to go in for a after market "HIGH PERFORMANCE CLUTCH PLATES".
ashvar87 is offline   Reply With Quote
Old 26th March 2009, 23:09   #12
Thanked: 247 Times
Can I ask how much the gypsy gearbox cost you?
@ pdev - can you please tell us about the baleno engine swap for gypsy in detail.
1. Does it sits on the stock mounts or new mounts have to fabricate?
2. Does the engine mates directly with gypsy gearbox or does one needs an adapter plate.
3. Does oil sump sits above the differential or its clear? Any other issue of front differential clearance during extreme articulation?
4. What about clutch, flywheel, starter motor?
cheers
vishwas
vishwaschettri is offline   Reply With Quote
Old 27th March 2009, 12:40   #13
Thanked: 11 Times
Got the G.B alone for 12k(excluding transportation from chennai)
I wanted the flywheel & 1.3 starter, but couldn't get it. :-(
Old 27th March 2009, 16:09   #14
ashvar87's Avatar
Thanked: 146 Times
no worries i have one 1.3's starter motor.
Old 28th March 2009, 14:00   #15
Thanked: 31 Times
Out of curiosity I wanna ask the experts, for an Baleno Engine Swap to non MPFI Gypsy does the wiring needs to be changed? what about the ECM?
Cloud_Chaser is offline   Reply With Quote
Project Titan - Apple's rumored new Electric Car Project bharat.joshi The International Automotive Scene 30 5th December 2016 19:04
Help needed!! Car project.. barbar Shifting gears 12 19th March 2006 14:57
The Golden Quadrangle Project GreenHex The Indian Car Scene 17 28th September 2004 16:40
New Honda NSX (HSC) project is back on again. Sheruken The International Automotive Scene 3 15th July 2004 23:22
virtual project:old fiat into old mini cooper aadix The International Automotive Scene 3 25th April 2004 15:39
