Old 6th April 2009, 15:09   #46
Brutus's Avatar
Thanked: 46 Times
One more thing, don't go for Toyota motors if off-roading is something you want to use the jeep for in future. Ofcourse they are the smoothest, and most responsive motors of the lot, but the problem is, not only are they harder to shoe-horn to other gearboxes(since the stock toyota xfercase cannot be used due to their opposite side of output for the axles), but they relay on beltdriven camshafts. Now there's nothing wrong with that, just that they have been known to snap under mis-use, and offroading involves just those kind of things. And since these mayapuri Toyota's are taken off thai taxi's after they have completed their life, these motors therefore generally have high mileage, but still carry onfor quite some time. These motors are then observed for their codition, and the bad ones are taken apart to be used as a parts bin for other motors.
Throughout, maximum effort is pressed on utilizing as minimum new parts as possible. Infact this goes for all mayapuri motors. So be cafeful of what you wish for.
Brutus is offline   Reply With Quote
Safari Engine in MM550/540 Bailee_Jatt_Boy 4x4 Technical 36 7th January 2010 15:13
MM 540 build mech.9n Modifications & Accessories 19 25th November 2007 12:26
mm 540 or the trax gurkha?? sanket12 SUVs, MUVs & 4x4s 13 22nd June 2007 12:19
Kottayam to B'lore on my MM 540 (22nd Aug) jango Travelogues 9 11th October 2006 21:09
Am pickin up this 540 (pics uploded) need suggestion jango SUVs, MUVs & 4x4s 8 21st July 2006 15:44
