Old 14th June 2012, 13:19   #61
gypsyFreak's Avatar
Thanked: 188 Times
Default Re: Bolero SLX 4x4 conversion project
Originally Posted by jeepster View Post
the Armada has front leaf spring suspension where in Bolero its indignant one.
for Armada its a bolt on job , but the bolero chassis has to be modified to fit the front live axle.
& this modification is not simple & reliable in long term.
so other option is swapping chassis with new 4x4 one from dealer or getting it from second hand market.
in first option you need money & lots of it.
the chassis---------------------60k (second hand 10K)
FFRA (left off set one)+OKBJ)---70K (second hand ? )
T-18---------------------------20K (second hand ? )
misc. parts --------------------40K+ (second hand ? )
labor ---------------------------?
(all fig are approx)
& if you get the second hand parts the problem of legality arises (chassis no. on RC book).
also chassis can be miss aligned too.
axles tubes can be bended ones.
& at last reliability is no where compared to factory one.
my advice will be sell bolero & get 4x4 Thar mdi or second hand 4x4 bolero/armada/invader/marshal. (all are available in box section chassis aka NGCS)
rgds,
Nikhil
EDIT:
+1 to Tini.
parts are rare & good mechanic is amost impossible. (at least in my locality)
How feasible is it to convert a Bolero DI 2wd to 4wd.
Since Bolero DI comes with rigid leaf suspension in front and rear only, does this require any chassis modifications or just adding a T18 TC to the NGT520 GB sufficient?
gypsyFreak is offline   Reply With Quote
Old 14th June 2012, 18:01   #62
jeepster's Avatar
Thanked: 984 Times
Originally Posted by gypsyFreak View Post
H
  • front AXLE assembly
  • GB + T18 (or BW TC)
  • if you use T18 a right offset FFRA (diff towards drivers side)
  • other mics parts like prop shaft, FWH, TC gear lever.
rgds,
Nikhil
BTW these are just AFAIK list.
i have not done such conversion.
jeepster is offline   Reply With Quote
Old 20th June 2012, 09:41   #63
whicked wheels's Avatar
Thanked: 56 Times
Hey nikil there is a marshal di 4x4 for sale the jeep is in good condition but he is asking 2.5 for it. As for booking a new bolero di turbo 4x4 it could be a long wait as there is no coordination between the company and the dealer just cancelled my booking as I was supposed to get the delivery in the end May when asked about it was told I will go into production in mid of June and the showroom did not even have a booking no for it from the company.
whicked wheels is offline   Reply With Quote
Bolero Load Carrier 4x4 conversion LKCRUISERS 4x4 Technical 10 2nd June 2011 10:23
Mahindra Bolero----- GLX to SLX jraj The Indian Car Scene 14 25th March 2010 10:51
Tata Sumo Victa GX Turbo OR Mahindra Bolero SLX Victa_OR_Bolero SUVs, MUVs & 4x4s 23 9th February 2010 20:48
Bolero Invader 4X2 to 4X4 Conversion inder_s1 4x4 Technical 19 29th November 2009 16:38
Bolero SLX -MDI 3200 Turbo --Underpowered!! ulytel Test-Drives & Initial Ownership Reports 6 18th August 2006 17:42
