Old 16th April 2009, 18:42   #1
Brutus's Avatar
Thanked: 45 Times
Default The Axle debate
Hi there,
i thougt i'll start an axle topic regarding what constitutes axle strength. I would need help with inputs from UBS Sir, Arka, Vinod, amongst others, and i know they would help. If anybody has any views, questions, answers, or a different logic, please do post so. I may be wrong, so please do correct me. And yes, please let us all try to keep this topic as clean as possible. And if you can,please do forgive me for any spelling mistakes.
Lets start from the contents of differential pumpkin housing:-
1) Crown or Ring:- This is probably the biggest feature that determines axle strength factors. Quite obviously, the bigger the ring, the more strength factor it has has. but another thing to note is the thinchness of both the teeth surface and the overall thickness of the ring itself. In the Ford 9" axle, even though it has a smaller ring than the seemingly more powerful Dana60, it has more a thick ring. Material strength is also a factor, but lets leave this aside since all axles, except custom made units, more or less use the same kind of materials. Also, all Ring/pinions under sudden torque loads go through a little torsional vibrations, and therefore they lose the strength in doing so, and this is when a great number of axle rings break. Some custom Ford 9" axles have these sort of plug to hold the crown on the opposite side of the ring where the pinion meshes.
2) Pinion:- This is probably the most undermined and neglected, yet the most important factor of axle strength. Naturally, both the thickness and length matter to the great extent, but also the bearing support. The Ford 9" pinion is fatter than the Dana60,70, and probably the 80 too. The GM axle though are known to have more thinkness.
Another factor here, caused by the torsional vibration, affects the pinion too, and axles like the ford 9", and much to my surprise even the Tata 407 has bearings on both sides of the pinion to counter this, whereas the other axles have the bearing just on one side(the input side).
3) Carrier housing:- The thichness of the carrier housing again makes a lot of difference. Since the outer thinkness of a facotry design cannot be changed since firstly, the inner dia. of the ring/crown has to be taken into consideration, and secondly it would interfare with the pinion rotation.
Also i point to note is that all Switchable locker types, like ARB, Ox and others, have to lose some amount of the housing wall thickness since the axtra mechanical for switching the locker take some space as well. This factor to quite some extent is countered by using a better material than the factory units(the factory units don't necessarily use the strongest materials available since neither is there a need to overbuild an axle, and they have to keep the overall cost factor down too).
I have seen photographs if lockable carrier housings breaking, especially an early example of a new pin type locker that broke right from the carrier housing where the ring is mounted. This the the reason why most of the factory locker options, used in military trucks, including the Unimog and the Tatra have a whole new axle design started from stratch, where the locker is locked from outside the carrier housing on the bearing side. For this, they use a much largewr side bearing on the side that the locking mechanism is mounted, with a larger dia. carrier bearing mounting surface, a bigger dia. locking sleeve and thinker teeth(though there are some examples, like the tempo trax do not, and the reason is that are generally designed with as few as possible modification from unlocked axles used for the same purpose, therefore are required to use as many similar parts).
4) Spider and Side gears:- The thickness and diameter of the side gears determines their strength, and the same goes for the Side gears. Also the number of spider gears inside the carrier housing also affects the strength factor. For i.e. both the Dana44 and the Jonga axle have the same dimensions, the almost same ring and pinion dia, the same axle shaft dia(though the jonga unit has slightly thicker shafts = 1.31"), but the jonga axle is the winner here since it has 4 spider gear instead of only 2 in the Dana44 axle, The aftermarket switchable locker versions of the Dana44 too have 4 spider gears.
Also i noted that the jonga side gears have the same outer dia. and about the same thinkness as the Tata 407 gears, and have the same number of teeth too. I could easily fit the 407 side gear inside the Jonga axle housing, but the innder dia., where the axle shaft fits is greater in the 407 due to its much thinker(1.51") shafts, and also the part of the side gear that rests with the carrier housing has a larger dia. than the Jongas.
5) Carrier side bearing mounting tube thinkness( don't remember whatever its called, please correct me) and Bearings:- Even though some of this has been covered above, i'll go into some details.
The side of the carrier housing that is tube shaped to mount the bearing is of quite importance. Firstly the entire load from the ring/pinion, through the side gears and into the axle shafts, is handles by the bearing, and therefore the greater surface that is offered to the bearing mounting, the more stronger it is. Literally, the more the dia. of the side tubes of the carrier, the more powerful the housing becomes.
Also, another factor is that the outer dia of the tube has to be taken into consideration since the inner dia of the tubes has to be fat enough for the axle shafts to pass through. the thicker the axle shaft, the thicker, the lessor will be the material placed between the inner and outer diz of the carrier housing tubes, therefore the outer dia of the tubes has to be compensated. (This is the biggest problem i'am facing by using Tata407 axles in the jonga axle housing. Since i have to increase the inner dia. of the tube to get the axle to pass through it, the material between the inner and outer dia. of the tubes is therefore now lessor than it initally was, and the overall strength of the carrier housing likewise diminished, beating the actual purpose of the mod. I have to use a bearing that has the same outer dia. as it originally was, but the inner dai. lhas to be the size of the bearing used in the 407 axle, but that too will desrease the overall bearing strength, but not to that great an extent as it was with the carrier tubes. another option is to put the axle or the differential pumpkin housing on the lathe, and remove material from the bearing area to make use of a larger outer dia bearing, but that decreases the carrier holding strength of the differential housing. Its always a matter of you lose some, and you win some, and here i think option no.2, of using a smaller but stronger material bearing is the solution).
The bearing as i said earlier, the bigger the difference between the inner and outer dia., the better and stronger it is.
6) The housing tube thinkness: Naturally, the biggest reason the big fat axle/differential housing of the trucks is more powerful than the jeeps is the thinckness of the tubes. This factor is the same regarding both the full-floating and semi-floating axles. There are some tubes that have the same outer dia. as each other, but the inner dai is smaller. The One with the smaller inner dia, has a stronger housing, but a smaller inner dia. also means a smaller dia. axle shaft, so the total strength facter depends on the total housing and axle strength combined. This is usually in case of Semi-flaoting axles and full-cloating axles of the same design, where the full-floaters have a smaller dia. and therefore weaker axle shaft than the semi-floaters, but that factor is counteracted, not necessarily in over all axle strenght as regards to off-roading, but surely in-case of load carrying.
7) Axle shaft thinkness:- Naturally here too the fatter the better, but there are so many new stronger materials in the market that smaller, thinner axle shafts made by them are still as stronger as the fatter ones.
An axle is basically designed to twist, when a big torque load is applied, and thus when you see a broken axle shaft, you would be axle to make out the twisting bends made on them just before it broke.
When an axle shaft is hmade, it is hardened only from the outer side and the inner portion is purposely kept soft, which makes more flexible to twisting forces. Depending on the main purpose the shaft is made for, this ratio of harned, thus strengthened versus flexibility is very precisely monitered.
Also regarding the max thickness of the axle, all axles are goosenecked, as in thinkness of the axle goes down right after the inner spline area and is gradually increased until the outer spline area. How much depends upon the axle. A full-floating axle has more of less the same thickness in at inner and outer splines even though they too are goosenecked. Whereas a semi-flaoting axle would be as much as one and half times as thick as the inner end(there are no outer slpines, except in a few axles. In the jeep Cj3b axle, its held on by a single carter pin at the outer and, so that makes it weaker than the other Dana44 semi-floaters).
Semi-floating Vs full-floating
In the semi-floating axle, there is just one bearing at the outer end to upport the axle shaft. Beyond the outer bearing at the axle tube, the axle shaft is on its own to counter both the weight of the vehicle, and the torque loads. Therefore a semi-flaoting axle shaft is a lot thinker toward the outer end then its inner end.
A full-flaoting axle has no bearing at the outer end of the axle tube. Rather the other end has a flange through which the axle shaft passes, and here the hub, which is supported by 2 bearings, is connected to the axle shaft. Now since the entire weight is on the hub bearing, the flange, and there on the axle housing, the axle shaft does not have to bear any of the load of the vehicle, which is passes ofn ot the axle housing to handle through the flange and the bearings. The only thing that the axle now has to handle is the torque load.
Now the main points here are:-
1) The axle shaft of a semi-floating axle is much more stronger than a full-floaters, thought the overall strenght of the full-floating axle might be much more. The holds true especially for the Dana44 type axle, excluding the Cj3B axle which have a carter pin.
2) The beaings of a full-floater last longer, since there are 2 brearing on each side to hold the weight rather than one is the semi-floater.
3) In case of the Semi floater, the weakest part is the outer part of the axle shaft, whereas in the full-floater its the bearings and the flange. On the jonag rear axle though, which is a semi-floater, its the axle holing nut, twhich have been known to come lose, throwing out the entire axle shaft on a moving vehicle.
Anything else you want to put down here guys.
Brutus is offline   (1) Thanks Reply With Quote
Old 16th April 2009, 19:23   #2
Brutus's Avatar
Thanked: 45 Times
Standard Vs Reverse rotation axles: Some vehicles in the U.S. came with reverse rotation axles in the front(i think only in the Dana44 and Dana60's from the factory, though there are some aftermarket reverse rotation Ford 9" too). The crown/pinion of these axles cannot be interchanged with same type of axles used at the rear. Generally the teeth of the crown/pinion are designed keeping the rear drive in mind, and these are used in the front too. The motion they follow in the front is not what they were desinded to do, so they are therefore considered weaker then the same axles used at the rear. To counter this the reverse rotation crown pinions were made, where the teeth are cut in an angle to the opposite of whats used at the rear.
High Pinion axles: Some axles came with a pinion place higher in the pumpkin to increase the height of the drive-shafts to protect them from damage. These type of axles generally use the reverse rotation crown/pinion at the rear.
Portal Axles: Some axles are so designed that the end of the axles(the hubs) have another set of drive gears, which increase the height of the vehicle. Not only that, since the last torque reduction takes at these gears, the rest of the parts of the axle can be designed to bear a lighter load, enabling the use of smaller, thinner axles and asmaller crown/pinion. The crown/pinion and the portal drive gears together constitute the overall drive ratio. The crown/pinion hence can be made with lessor teeth and more thickness, therefore stronger. The problem with these axles is that they generally increase the center og gravity, and also the overall housing strength becomes weaker, especially at the hus, and the front bearings. There have been reports of the portal drive gears shearing when the whell lands after a jump, although there are aftermarket gears to counter the problem. Since there is no way to desplace the heat produced at the hubs, these axles have been known to overhaet suring speed runs, so they are used in mostly low-speed heavy duty vehicles. Examples include the Tatra trucks, Unimog, Shaktimann(originally man), Haflinger, Volvo c303, etc,etc.
The inner axles of this axle(from the differentials to the partal gears) can be both semi-floating or full-floating, thought generally they are semi-floating only. The outer axles, also called stub axles in this case, too are both, with semi-floaters usually coming in axles that are designed to be used with the central tire inflation system.The most powerful and the lightest of these axles as far as off-roading is concerned are made by portel-tek axles, which is generally based on the Ford9", with everse rotation high pinion differential, Volvo C303 derived portal gears, and unit bearing hubs from the ford trucks.
Old 17th April 2009, 08:15   #3
Thanked: 4,673 Times
Dear Brutus - you have started a good thread. This will benefit everybody. Thanks.
Best regards,
Behram Dhabhar
DHABHAR.BEHRAM is offline   Reply With Quote
Old 17th April 2009, 08:56   #4
Samurai's Avatar
Thanked: 14,541 Times
You left out the most professionally qualified person here and he answers first.
Brutus, this is an excellent thread you started. However, it would be even better if you can provide photos for each item, lots of us don't know what a crown or a pinion looks like.
Old 17th April 2009, 11:06   #5
ex670c's Avatar
Thanked: 1,799 Times
Default Spider Gears - Dana 44
Hi Bikram,
AFAIK the Dana 44 always had 4 Spider gears. (2 Side & 2 Pinion)
I have seen M&M Dana 44 Diffs from the early 60's CJ3Bs, 70s CJ500D, FJ150, 80s FFRA (Commanders) MM540s, 90s Armada, 2000's Bolero Series, Major Series 3.92 and Down
All of them have 4 Spider Gears inside the Differential Carrier.
They however are of 3 types
10 Spline - FFFront Axle, Semi Floating RA
19 Spline - FFFA, FFRA, SFRA
30 Spline - SFRA
Arka
Old 17th April 2009, 13:17   #6
Brutus's Avatar
Thanked: 45 Times
Haha, thats nice Samurai. Maybe your right, i should get some photos too.
Arka, i may be wrong but the dana44 carrier housings i've seen have these 2 huge hollows on each side, and theres a pin that holds 2 spider gears.
Its something like this, or am i wrong again?
Now i got it, your confusing the side gears with the spider set too. The 4 gears your refering to is 2 spider and 2 side gears, all fittted inside the carrier housing.No problem, even i got confused by it.
Take care,
Bikram
Brutus is offline   Reply With Quote
Old 17th April 2009, 13:33   #7
ex670c's Avatar
Default Dana 44
Thats a Dana 44 Carrier (New model)
The Pin aka Pinion Shaft.
Old 17th April 2009, 13:37   #8
Brutus's Avatar
Thanked: 45 Times
Maybe the reason why we call them different names is that your using the Indian terminology, and i am using the american one.
Old 17th April 2009, 14:14   #9
ex670c's Avatar
Default 4 Pinion Carrier.
4) Spider and Side gears:- ....i.e. both the Dana44 and the Jonga axle have the same dimensions, the almost same ring and pinion dia, the same axle shaft dia(though the jonga unit has slightly thicker shafts = 1.31"), but the jonga axle is the winner here since it has 4 spider gear instead of only 2 in the Dana44 axle, The aftermarket switchable locker versions of the Dana44 too have 4 spider gears.
2 Side Gear + 2 Pinion = 4 Pinion Differential Carrier. (i.e Dana44)
Please elaborate How the JONGA P60 Carrier Assembly is stronger, and how many pinions are there in the carrier assembly.
Arka
PS - I'm OK with Desi or American names.
Old 17th April 2009, 16:20   #10
Brutus's Avatar
Thanked: 45 Times
No, actually i think i'am wrong in useing american terminology, but it's not my fault since everything i would see and learn and i would then go check on the net, and as you know, only the crazy americans(sorry Dan) go all the way to describe how everything works, and thats why i only got to learn what to call them the american way. I have a really hard time explianing things to mechanic since they don't understand that terminology. Imagine this, i went to a shop to buy a set of valves, this is what happened.
Shop-owner:- How can i help you?
Me :- I am looking for a set of valves and valve guides for the petrol jeep.
Shop-owner:- What?
Me :- Valve.
Shop-owner:- Whats that? (and then i explain it to him)
Shop-owner:- Oh! So you'r here for Waol
Me :- Eh??
Shop-owner:- Waol and Waol guide.
Me :- Yes, whatever it is, i want them
I am not joking, this is what really happened. I don't know how they pronounce them all over India, but here in punjab, they're Waol.
Anyways, as you know, the main stress from the crown/pinion is transfered to the side gears by the route of the spiders, or pinion gears through the cross pin. The jonga has 4 of these to transfer the torque while the Dana44, by virtue of its design, has only 2 for the job, each one of them being roughly the size of the jeep pinion/spider. This disadvantage is offset to a great extent by the aftermarket Dana44 locking gears, which have 4 of the spider/pinion gears.
Old 18th April 2009, 16:44   #11
Brutus's Avatar
Thanked: 45 Times
Guys, anybody interested in how user locked Diff-locks of all different kinds and makes work?
Old 18th April 2009, 17:47   #12
4x4addict's Avatar
Thanked: 2,513 Times
There is already a thread in the 4WD section on Diff Locks/LSDs.
http://www.team-bhp.com/forum/4x4-of...ks-vs-lsd.html
4x4addict is offline   Reply With Quote
Old 18th April 2009, 18:00   #13
Brutus's Avatar
Thanked: 45 Times
You got me wrong 4x4addict. I'am not talking about the differences between the Automatic lockers vs the manual ones, but rather how the internal components of a few types of manual lockers opperate, like the difference between the pin lockers, spline lockers, the Carrier interal lockers, and carrier external lockers, inrespective of if they use a cable, hydrallic, or pneumatic type mechanisms to activate the lockers.
Cheers!
Old 19th April 2009, 15:58   #14
DirtyDan's Avatar
Thanked: 747 Times
Cheers!
I would be interested in knowing. But I need pictures else my limited intellect goes migrain and I get cranky.
Old 19th April 2009, 17:52   #15
Brutus's Avatar
Thanked: 45 Times
You got it Dan, give me a little time to compile everything up, and then i'll put it up.
Evolving my OHC - debate on pricing di1in Modifications & Accessories 64 20th December 2009 22:15
Debate: WAI and fuel efficiency di1in Modifications & Accessories 11 20th August 2009 20:03
A Debate: Myths about Car Audio frankmehta In-Car Entertainment 21 14th May 2009 13:42
SCOOP! Tata's One Lac Car - REAL PICTURE! And a debate on its suitability and impact. Steeroid The Indian Car Scene 292 4th February 2008 02:45
