Old 13th May 2009, 11:55   #16
abhijeet080808's Avatar
Thanked: 276 Times
I am quite curious about this thing -
Originally Posted by dinar View Post
The issue mentioned by your mechanic is true with an marutis, if the battery earthing does not make contact with the body, as that is the only connection that remains between the electrical earth. You should get that checked.
AFAIK, the clutch is a purely mechanical device, so how does earthing come in the picture? And, how can it make the clutch hard? I am just confused!
abhijeet080808 is offline   Reply With Quote
Old 19th May 2009, 07:42   #17
headers's Avatar
Thanked: 464 Times
One can increase the leverage in the gearbox shaft to make the clutch softer..~!
Old 19th May 2009, 13:25   #18
headers's Avatar
Thanked: 464 Times
The clutch cable runs on a lubricated inner cover (sheath) that makes it light in feel. IFF, by improper earthing or welding connections, the clutch cable comes in contact, for some silly reason, then all the lubricating properties of the clutch cable becomes null and void making the clutch hard.
Old 19th May 2009, 13:39   #19
Thanked: 276 Times
That is something new for me! Maybe an electric short circuit happens and the clutch cable is used as ground. This can lead to the cable heating up and hence the lubes evaporate.
Old 19th May 2009, 17:24   #20
Thanked: 53 Times
@abhijeet080808, I have seen this happen with maruti, reason may be as you said the cable heats up , or may be the electrical charge decomposes the lub in the cable.
dinar is offline   Reply With Quote
MM540 2wd to MM540 4wd and Restoration Rajith 4x4 Vehicles 48 1st October 2015 23:45
'09 Maruti DZire : Steering too hard tripsme Technical Stuff 9 30th May 2012 13:06
Hard clutch shazikon Technical Stuff 8 27th November 2011 11:05
MM540-4WD wish list - what you really want in your MM540-4WD? DHABHAR.BEHRAM 4x4 Vehicles 299 7th January 2010 13:02
Do i rev my Alto too hard?! BUXX Technical Stuff 8 3rd February 2009 11:43
