Old 6th June 2009, 18:05   #16
whitemm550's Avatar
Thanked: 63 Times
thanks to Jyobeb, i could get another ECM, but the bad news is that with the new ecm, the problem persists, so i think that the ECm prob is ruled out, but then it leaves me a with a big question, THEN WHAT THE HELL IS THE PROBLEM? NEED HELP GUYS AND FAST.
i have already converted the Bolero into a manual 4x4, using a unique cantraption of cables, and that works, rather effectively, but i want the original to work, please
whitemm550 is offline   Reply With Quote
Old 9th July 2009, 19:27   #17
whitemm550's Avatar
Thanked: 63 Times
hey guys, please help me, the 4wd works fine, using my unique cable system, but can someone help me with Borgs warner system?
Old 10th July 2009, 01:20   #18
Ignazio's Avatar
Hi mate,
have you or your mechanic tryed to disconnect the motor from the transfer case and checked for regular rotation?
On the motor there are sliding contacts they maybe faulty, also as someone else suggested check the clutch switch.
I have the garage manual of my Tata, I'll have a look about diagnostic and error codes and let you know.
Ciao
Ignazio
Ignazio is offline   Reply With Quote
Old 10th July 2009, 13:25   #19
whitemm550's Avatar
Thanked: 63 Times
Originally Posted by Ignazio View Post
Hi mate,
Ciao
Ignazio
yeah, we have tried that too, the moter rurns on its own when disconnected from the transfer case, but moves only on 1 speed, the code shows moter fault, but i tried interchanging the moter, to no avail, i have also checked the clutch switch
Old 10th July 2009, 13:51   #20
Ignazio's Avatar
Originally Posted by whitemm550 View Post
...but moves only on 1 speed.... to no avail...
Hi Mate, can you describe a bit better the above?
a) It moves at 1 speed or only on 1 position?
b) Did you try with another motor or it is not available?
I'll try to find a picture of the motor sliding contacts and post it..
Ciao
Ignazio
Old 29th July 2009, 12:42   #21
whitemm550's Avatar
Thanked: 63 Times
Ciao
Ignazio
it moves only with 1 speed, it dosent move in 4WL position
i tries fitting it with another moter, and a different ECM also, but till the same result, and thanks for the intrest.
Old 29th July 2009, 19:14   #22
Thanked: 4,673 Times
Dear whitemm550 - please post some photographs of the "cable contraption", whatever that is. As far as electric shift is concerned, finally there is a motor which correctly locates the shifter shaft inside the transfer case. The electronic part is essentially an algorithm which selects results based on preset inputs. If these can be given manually, as far as the motor is not faulty, you should be able to get away by manually commanding the motor.
As all this may be latin and greek to some of you, yes, I do agree that the plain and simple lever is the best solution to engage and disengage 4 wheel drive.
Best regards,
Behram Dhabhar
DHABHAR.BEHRAM is offline   (1) Thanks Reply With Quote
Old 1st August 2009, 11:32   #23
Default he he he
now i have 3 options
1. sell my Bolero
2. find a lternate system without altering the Electric system
3. Go Manual
guys please Help
Ok how much are you selling it for?
dyer_made is offline   Reply With Quote
Old 24th August 2009, 08:55   #24
Thanked: 388 Times
How old is your Bolero ? Just a suggestion you can try taking it to some garage specializing in Safari they may be knowledgeable about Borg warner electric 4X4 and will be in position to trouble shoot replacing parts.
amitk26 is online now   Reply With Quote
Old 6th September 2009, 20:25   #25
headers's Avatar
Thanked: 459 Times
Any progress on the ECM problem? Can we convert the GB to a manual 4wd shift?
Old 7th September 2009, 17:47   #26
whitemm550's Avatar
Thanked: 63 Times
Amit. you know some one, can you help me with somebodies number please??
Old 25th November 2009, 19:23   #27
whitemm550's Avatar
Thanked: 63 Times
hey guys, please try and find aa guy to help me with the ECM problem of my Bolero 4x4, i am ready to drive down to Pune/ Bangalore/ Mumbai
Old 25th November 2009, 19:25   #28
whitemm550's Avatar
Thanked: 63 Times
Best regards,
Behram Dhabhar
sir i request you to kindly enlighten me on this issue. please
Old 25th November 2009, 19:34   #29
sreerajunnithan's Avatar
Dear whitemm550,
Send a PM to Suresh Stephen. He has done this modification in his Armada Grand, which has the same setup as your Bolero (Borg Warner Electric Shift)
He has done a 2 lever setup, and i have seen that personally.
--Sree--
sreerajunnithan is offline   Reply With Quote
Old 1st December 2009, 17:21   #30
whitemm550's Avatar
Thanked: 63 Times
thanks for the suggestion, but personally i would like to restore either the original set up. or i would love to change the transfer case to a Gypsy one and get the mod done, can any one help with that????
Bolero XDP Engine Vs Bolero DI Turbo Red Liner What Car? 34 30th September 2015 21:37
Bolero Invader 4X2 to 4X4 Conversion inder_s1 4x4 Technical 19 29th November 2009 16:38
Mahindra Bolero Invader 4x4 - To buy or not to buy ?? Sabareesh SUVs, MUVs & 4x4s 11 3rd October 2008 11:29
Honda City 1.3 Type 1, 1998 model. ECM, throttle body problem cbearun Technical Stuff 4 9th April 2008 10:11
