Old 8th April 2010, 16:28   #46
I recently bought a 2002 model MM540; the vehicle seemed to be in good condition until the AC was installed. Please read the below time line.
January 2010: Bought the vehicle (no AC), checked thoroughly by a mechanic and deemed to be in good condition. Temperature gauge constant at just below 80 deg mark, sometimes 85 - 90 deg in heavy traffic or when climbing a steep incline with 4X4 engaged.
February 2010: AC installed; everything seemed fine. After a couple of days though, started noticing the temperature needle dangerously close to the red mark. Switching off the AC makes the needle go back to just below 80 deg. However, after a couple of days, switching off the AC would result the needle to drop to 80 deg (not just below 80 deg mark). Noticed that radiator was losing water; obvious culprits were either loose hose connections or faulty radiator cap. Found out that radiator cap wasnít original but couldnít procure one; it seems that all spare part shops stock duplicate radiator caps worth just 25 bucks. Another strange thing noticed was that the temperature needle flicks back and forth between 80 deg and 100 deg when the clutch pedal is depressed and released. The obvious inference was that either the temperature gauge was faulty or there was some sort of a loose connection in its wires. Time was running short so decided to drive down the vehicle to Bangalore from Kerala without using the AC, and check with a good mechanic after reaching here.
AC details:
  • Sandem 507 condenser with Unicla blower (excellent cooling).
  • Condenser fitted in front of the radiator.
  • Electric fan fitted behind the condenser; the fan sucks in air through the condenser.
March 2010: Drove Vehicle to Bangalore, no problems encountered on the way. However, during the Ghats section (Nilambur Ė Gudalur), the engine temperature reached close to the red mark, but since the faulty temperature gauge problem still existed, while depressing the clutch pedal to change gear the temperature gauge needle flicked back to around 90 deg. Also, noticed that the exhaust was smoky so eased the accelerator pedal a little to reduce dumping unnecessary fuel into the cylinders, this bought down the temperature to 80 deg.
After a week, consulted a couple of mechanics here in Bangalore, all of them concurred that one problem could be the electric fan being installed behind the condenser. Their logic was that since the fan was sucking in air through the condenser, which is an obstruction, the fanís effectiveness is questionable. And moreover, the hot air that the fan sucks in is then released towards the radiator, where it gets sucked through by the radiator fan. Now, by placing the fan in front of the condenser, the fan tries to push the air past the condenser; some of the air goes through the condenser while the remaining goes around it towards the radiator. Therefore the radiator will get cooler air in front of it.
Replaced radiator cap with original one; no lose of coolant after that.
Mechanic confirmed that there was a loose connection in the electric wire to the temperature gauge.
April 2010: Vehicle given to workshop with following instructions:
  1. Install fan in front of the condenser.
  2. Overhaul radiator.
  3. Add a reservoir to the cooling system.
  4. Fix temperature gauge.
I got back the jeep yesterday evening. During the drive back home, the temperature hovered between 85 and 95 deg (AC in full blast). The needle indicated 95 deg (maybe 90 deg, canít differentiate) in bumper to bumper traffic. Once the traffic reduced and got a stretch of open road, the temperature started dropping to about 85 and stayed there (the temperature would eventually increase due to bumper to bumper traffic).
There seems to be obvious improvements, but is this enough, or is there more scope for improvement? If yes, what needs to be done.
I hope I have given enough information for all gurus out there to nail the problem. Hoping all of you guys reply.
akm225 is offline   Reply With Quote
Old 13th April 2010, 13:09   #47
DesertKing's Avatar
Thanked: 18 Times
Originally Posted by akm225 View Post
Does your Jeep have a thermostate switch?? If yes, it will never let the temperature go down to 80 deg.
DesertKing is offline   Reply With Quote
Old 13th April 2010, 19:47   #48
Hi DesertKing,
Thank you for replying.
No, my 540 doesn't have a thermostatic valve.
Old 14th May 2010, 16:14   #49
Tejas@perioimpl's Avatar
Thanked: 5,058 Times
I'm planning to do a couple of dashboard modifications to my classic and also have planned an AC install in the near future. The dashboard mod is basically extending the dash to have a center console extending all the way till the handbrake with a lockable compartment. I may relocate the handbrake to the right of the driver and free up more space (still considering this though).
Since i am planning the dashboard mod first, is it possible to just install a blower first and use it as a fan and do the AC install (compressor, etc) at a later date? This is important so that my dash can be sculpted around the blower.
Also, which blower is recommended?
Tejas@perioimpl is offline   Reply With Quote
Old 14th May 2010, 16:36   #50
Gypsy-Boy's Avatar
Superking - its one of the best blowers you can find!!
Am sure lotsa people here will say the same!!
Gypsy-Boy is offline   Reply With Quote
Old 14th May 2010, 20:52   #51
Jaggu's Avatar
Thanked: 7,654 Times
Superking or National, they have the best blowers. But i don't think it comes without the cooling coil assembly. Don't buy second hand stuff, buy a new one and wrap the coil inside with plastic so that dirt doesn't settle in till you complete the fitment of AC.
Key is finding the right size compressor, most often people install oversize compressor which are a drag on the engine and results in heating. For a classic put a 505 compressor with a plastic partition behind the front passenger area. Also remember to do good insulation at the firewall and the floor area. 507 might not really be required for such a small area.
Old 15th May 2010, 10:56   #52
This is the biggest issue. Insulation will take the brunt of water fording, monsoon leaks etc... Even after a day of slushing, one needs to jet clean the interiors as well and again this will completely rot the insulation. What to do about this?
Old 16th May 2010, 23:58   #53
Jaggu's Avatar
Have you seen the sound deadening and heat insulation patches on the floor of modern cars, just lift the carpet and check you will know what am talking about. Use it, you need to heat and stick it, lil expensive, but will take care of all your concern points.
Old 18th May 2010, 17:53   #54
sreerajunnithan's Avatar
I recollect we discussed about this last weekend, any pointers on where we will get this?
--Sree--
sreerajunnithan is offline   Reply With Quote
Old 18th May 2010, 19:43   #55
Jaggu's Avatar
Should be available with any of the big spare stockist in the city. Its not a fast moving part so might have to order and wait for it. This is a universal product only the shape of the patch will defer from vehicle to vehicle. Trouble will be to identify the biggest piece available, this can be then ordered and then cut and pasted based on the requirement.
Also i have heard that 3M has the product, so a quick check with 3M dealers might help.
Old 18th May 2010, 19:46   #56
What's the technical name of this thingy?
--Sree--
Old 18th May 2010, 20:01   #57
Jaggu's Avatar
I have no idea of the name, it should be sound deadening pitch or something of that sorts. Its used for sound deadening and heat insulation on floor panels of the chassis.
Old 18th May 2010, 20:57   #58
SPIKE ARRESTOR's Avatar
Thanked: 757 Times
Sreeraj, it is called as a "Melt sheet".
Good one Jaggu LOL!, yes what you have mentioned is right, its main function is dampening noise and vibrations.
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 18th May 2010, 21:27   #59
Jaggu's Avatar
aha and all this while you were just watching eh!! so how does it work for heat insulation?
Old 18th May 2010, 21:42   #60
Thanked: 757 Times
Hehehe, as I told you earlier it is basically a sound deadening material the only protection it provides from heat is because, it acts as a layer between the heat conducting surfaces. You would find "melt sheets" mostly in the passenger compartments where better NVH levels are required. Moreover, heat sources are less under the passenger compartment. A component which prevents a majority of those heat radiations is the "firewall" which has a material with good heat resistance.
Spike
For all those looking for MM550 Army Jeeps Randhawa 4x4 Vehicles 164 29th December 2015 14:57
MM550 Army 4x4 Jeeps 4x4addict 4x4 Vehicles 50 21st August 2014 14:57
Hi-speed and Low-speed jeeps? MalluDude 4x4 Technical 17 21st May 2012 14:17
Jeeps - Rust, Body decay and treatment lugnut 4x4 Technical 7 6th April 2010 20:13
And what about these two Jeeps?? overdose14 Modifications & Accessories 20 10th September 2008 21:01
