Old 18th May 2010, 22:00   #61
joshguy's Avatar
Thanked: 92 Times
everything is fine,but how do you prevent the cool air escaping from the CABIN?
that too for jeeps with soft top
joshguy is offline   Reply With Quote
Old 18th May 2010, 22:29   #62
Jaggu's Avatar
Thanked: 7,674 Times
You can use the flexible thermocol packing inside the soft tops, for insulation as well as reducing air gaps/holes. Only issue is then your soft top kinda becomes permanent soft top. But more than the escaping air, the heat is the problem. I have seen some great work with soft tops where there is absolutely no water leaks which works well to hold the air conditioned air inside also.
@Spike: You mean the pad kinda material? But those wont work coz they get soaked and can hold water, so rusting issue.
Old 18th May 2010, 22:43   #63
sreerajunnithan's Avatar
I have that Blanket kinda looking materiel on my firewall, but i still feels the heat inside.
--Sree--
sreerajunnithan is offline   Reply With Quote
Old 18th May 2010, 22:55   #64
SPIKE ARRESTOR's Avatar
Thanked: 757 Times
The melt sheets which I mentioned gets baked (and hence sticks onto the floor) in the paint shop, moreover they get sprayed by coat of paint/primer, so no question of rusting. Will try to post pic tomorrow then it will be clear.
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 18th May 2010, 23:09   #65
Jaggu's Avatar
Yup i know its melted and pasted (one on the floor) and had mentioned this to Sree also. Yup info on something similar for heat proofing would be great and thats what lot of people are searching around for.
Old 19th May 2010, 10:04   #66
Gypsy-Boy's Avatar
with Jaggu
People who are not looking at fitting A/C will also be interested in this.
So knowledgeable gurus - impart info!!!
GB
Gypsy-Boy is offline   Reply With Quote
Old 19th May 2010, 11:29   #67
Tejas@perioimpl's Avatar
Thanked: 5,058 Times
But this will block my very important drainage holes. And won't it absorb water during fording and cleaning and enhance the rusting process because it's not being done in the workshop?
Tejas@perioimpl is offline   Reply With Quote
Old 19th May 2010, 12:35   #68
Jaggu's Avatar
arre Tejas you can retain the holes and even add rubber stopper to retain the drainage holes. And no they dont absorb water, am 100% sure.
Old 19th May 2010, 21:36   #69
joshguy's Avatar
Thanked: 92 Times
I can only think of Arjunrudra's orangie restored by allan when it comes to softtop with AC.
It was good but still AC will escape and will require two ppl to put it on once removed
BTW will the power of XDP drop if AC is on?
Old 4th April 2011, 20:23   #70
Grace's Avatar
Thanked: 159 Times
Default Re: AC for MM550 (and Jeeps in general)
Does the discussion stop here? Did anyone finally use this melt sheet in their jeeps? Users , please share your experiences,need for all my jeeps too:-)
Warm Regards
Grace is offline   Reply With Quote
Old 11th May 2011, 12:44   #71
dmaheshkumar's Avatar
Thanked: 18 Times
What is the temperature when you switched on the AC in your jeep.How many litres of coolant you have used.
Becoz my Ambassador is crossing 100 inside the cities when i switched on the AC.I am looking for a solution to solve this problem.
dmaheshkumar is offline   Reply With Quote
Old 17th May 2011, 11:53   #72
Hi dmaheshkumar,
My jeep had similar over heating issues, especially when driving in the city.
Do you have an extra electric fan to push air through the condenser towards the radiator? An electric fan will definitely help in cooling.
Does your radiator loose too much water after a driving stint? Check whether the tubes connecting to the radiator are well connected.
Also check whether your fuel mixture is correct; my jeep had been running too rich, which was the reason why it was overheating.
akm225 is offline   Reply With Quote
Old 24th May 2011, 12:44   #73
Thanked: 18 Times
I have an electric fan in front of the condensor and it was working fine.The water level will also be in the correct level.I think the culprit will be the Temperature union switch.
I plan to fit the pricol Temperature union and the corresponding meter.
Old 26th May 2011, 13:33   #74
Thanked: 58 Times
Have a look at this :
http://www.team-bhp.com/forum/4x4-te...-clutch-4.html (Using clutch and designing clutch...)
I've tried this - and it works!
lugnut is offline   Reply With Quote
Old 26th May 2011, 14:02   #75
Thanked: 58 Times
This may help out some of y'all - My setup (Jeep):
It's equipped with a Sandem compressor, Unicla blower -
For all those looking for MM550 Army Jeeps Randhawa 4x4 Vehicles 164 29th December 2015 14:57
MM550 Army 4x4 Jeeps 4x4addict 4x4 Vehicles 50 21st August 2014 14:57
Hi-speed and Low-speed jeeps? MalluDude 4x4 Technical 17 21st May 2012 14:17
Jeeps - Rust, Body decay and treatment lugnut 4x4 Technical 7 6th April 2010 20:13
And what about these two Jeeps?? overdose14 Modifications & Accessories 20 10th September 2008 21:01
