Old 20th August 2011, 14:31   #91
V-16's Avatar
Thanked: 836 Times
Default Re: AC for MM550 (and Jeeps in general)
Originally Posted by madhkris View Post
Bumped into the thread now as am looking to install A/C in my MM 540. V-16 did you get to install the A/C unit? If yes can you please share some details of installation and some pics too.
Not yet but its on the cards later in the month. Getting other mechanical stuff sorted out first. Gearbox is being overhauled and then a check on the body mounts, then underbody and inner body anti corrosive spray, padding for the roll cage, customized soft top, lights, electricals, toggle switches and then the a/c. Should be done by the end of the month i hope. As soon as i do, will share the details and the report here for sure.
V-16 is offline   Reply With Quote
Old 20th August 2011, 16:57   #92
ashvar87's Avatar
Thanked: 146 Times
Dear Bigman,
I have fixed the A/c condenser just before the radiator with 12 inch straight leaf high Rpm COOLING FAN. i absolutely have no heating issues in bumper to bumper city traffic itself. It actually works perfect.
Please check the pictures below to have a clear idea of A/c installed in my 550.
regards,
ashwinraj
ashvar87 is offline   (1) Thanks Reply With Quote
Old 21st August 2011, 07:40   #93
madhkris's Avatar
Thanked: 70 Times
Thanks a lot for the pics Ashwin. Which brand of condenser have you used? What is the approx expenditure?
madhkris is offline   Reply With Quote
Old 21st August 2011, 09:44   #94
ashvar87's Avatar
Thanked: 146 Times
Madkris,
I actually forgot the make of the condenser, its a multi-flow aluminium condenser. U check for any good Multi-flow condenser which will fit inside your grill, use bigger condenser as possible.
I actually purchased a week old used A/c unit(Super king + sanden 507 with all fitments including condenser) for 15k, cooling fan 2k and 5.5k labour. totally 22k. I paid more for the unit since it was brand new. If u get one from scrap it will hardly cost you 5-6k for the unit alone
regards,
ashwinraj.
ashvar87 is offline   (2) Thanks Reply With Quote
Old 16th November 2011, 15:58   #95
Saptarshi B's Avatar
Thanked: 9 Times
Superking. I have never taken my blower speed above 2 (capacity till 4). In fact, I rarely take it over setting 1.
GTO, I have been through a few posts, but cannot yet get more details on installing a superking blower on a Sierra NA. Can you provide some details on a reliable mechanic for fitting (and procuring) a superking blower on a Tata Sierra
Approx costs and where should I buy the blower from.
Saptarshi B is offline   Reply With Quote
Old 16th November 2011, 16:09   #96
Thanked: 9 Times
Originally Posted by Jaggu View Post
Superking or National, they have the best blowers. But i don't think it comes without the cooling coil assembly. Don't buy second hand stuff, buy a new one and wrap the coil inside with plastic so that dirt doesn't settle in till you complete the fitment of AC.
Key is finding the right size compressor, most often people install oversize compressor which are a drag on the engine and results in heating. For a classic put a 505 compressor with a plastic partition behind the front passenger area. Also remember to do good insulation at the firewall and the floor area. 507 might not really be required for such a small area.
Jaggu, any idea on how much a Superking costs and where can I pick one in Mumbai (or Bangalore). I have to fit one on my Sierra NA
Old 16th November 2011, 22:05   #97
Jaggu's Avatar
Thanked: 7,225 Times
Unfortunately no idea of current prices. But should be within 5-7 k range.
Old 3rd November 2012, 20:44   #98
joethomasv's Avatar
Thanked: 180 Times
Default AC in Thar DI
Finally managed to fix an AC in my Thar DI. Here's some pics of the compressor bracket, if anyone is looking for ideas. I'll post detailed pictures of the install soon.
joethomasv is offline   Reply With Quote
Old 17th November 2012, 13:21   #99
joethomasv's Avatar
Thanked: 180 Times
I'm posting the pics of the AC install in my Thar DI. I haven't settled the bill yet but it will be between 35-40K. I need to get some insulation done for the canopy but even without it the AC works just fine. Covered around 1000 Kms after the install and no problems till now. Only issue is the reduced knee room for the passenger.
The condenser fan is fixed between the radiator and condenser. So in case it needs to be replaced, only the radiator has to be removed. Looks cleaner too. The temperature gauge reads the same as before so I guess it is working just fine.
joethomasv is offline   (2) Thanks Reply With Quote
Old 26th November 2012, 21:35   #100
Thanked: 17 Times
Dear Joethomasv, would fitting an ac void warranty? And can we fit older bolero dahboard instead of this blower unit in the footwell so as to keep the passenger legroom intact? Your ac fitment would make many people considering thar to go for thar di instead of the crde model. Probably the first thar di 4x4 with an ac, congrats.
BLACK1 is offline   Reply With Quote
Old 29th November 2012, 12:43   #101
joethomasv's Avatar
Thanked: 180 Times
Thanks BLACK1.
What warranty?
The bolero dash should fit just fine. That'll definitely fix the leg room issue. Tini has bought one for his Thar DI. I might get one too.
I had no intention of fitting an AC in it as it was meant only for farm use. But after 3k of use, I found myself using it more on-road than off it. It handles really well for a workhorse, and with a few sand bags in the back, ride is ok too. Also, better biceps, triceps and cholesterol levels.
joethomasv is offline   (1) Thanks Reply With Quote
Old 19th August 2015, 11:52   #102
ronk's Avatar
Thanked: 13 Times
It's interesting to note that a lot of the jeep conversations stopped by mid 2012!is it a sign that jeep fever is dying out or jeep modification has become more commonplace and easy to do with lesser doubts?
Anyways, I just got into jeeps this year with an old mm540 4wd, currently dead stock with HT.
Am keen on getting an AC fitted so that I drive this more often.
Looks like sanden+super king or national is the most popular and I am ok with it. Being in Bangalore I don't need a super chiller but I need something very reliable. Also I am keen on doing a bit of off roading and I don't want to affect the overall reliability of the vehicle.
Any tips on where to get a second hand compressor and blower in Bangalore and a good mech for the job?
ronk is offline   Reply With Quote
Old 22nd August 2015, 19:35   #103
khan_sultan's Avatar
Thanked: 2,951 Times
Contact @Jaggu. He knows a good person to do this. He had got done in Gypsy.
Link here (The Gypsy that started it all! ~ Spidey!)
In that post, there are details of his AC fitment.
khan_sultan is offline   Reply With Quote
Old 24th August 2015, 11:01   #104
Shubhendra's Avatar
Thanked: 1,177 Times
more than cooling inside the cabin you need to ensure cooling of engine. If you have XDP engine (as you mentioned its a stock 540), than please ensure your engine cooling mechanism is at its optimum best. Else you will have cooled cabin inside and over heated engine outside.
Shubhendra Singh
Shubhendra is online now   Reply With Quote
Old 26th August 2015, 08:17   #105
ronk's Avatar
Thanked: 13 Times
Thanks for the responses. Yup I did speak to Santosh and figured that I'll have to work on the vehicle cooling first
For all those looking for MM550 Army Jeeps Randhawa 4x4 Vehicles 164 29th December 2015 14:57
MM550 Army 4x4 Jeeps 4x4addict 4x4 Vehicles 50 21st August 2014 14:57
Hi-speed and Low-speed jeeps? MalluDude 4x4 Technical 17 21st May 2012 14:17
Jeeps - Rust, Body decay and treatment lugnut 4x4 Technical 7 6th April 2010 20:13
And what about these two Jeeps?? overdose14 Modifications & Accessories 20 10th September 2008 21:01
