Old 17th July 2009, 12:25   #31
vinod_nookala's Avatar
Thanked: 416 Times
Default Are the transfercases interchangeable?
Originally Posted by jyobeb View Post
absolutely sure. My gearbox is a NGT530.
Your transfer case will be a direct bolt on. Take my word for it. Been there done that and spent one hell of a lot of money too.
I have a BA10 link system, an electic transfer case, a KMt90 gearbox and a whole lot of parts left behind to show for it.
Jyobeb,
I had some idea that T18 came fitted with NGT 520 gear box. Never knew this happened to BA 10 as well. Now charging 50k plus premium for 4wd for a T18 is a day light robbery in new M&M vehicle. Anyway iam told all new M&M vehicles come with brogwarner transfer cases right from Major (manual) to Scorpio (electric). Only few pickup versions have T18 running in them now.
vinod_nookala is offline   Reply With Quote
Old 22nd July 2009, 17:06   #32
Thanked: 655 Times
This is for Sreeraj and Swastikviji.
I did a conversion of a link type 4WD BA10 jeep into a direct shift BA10 with 4WD.
We basically bought a BA10 direct shift gearbox and removed the rear housing and replaced it with the rear housing of the Link type gearbox and fitted the T18 transfer case to the direct shift gearbox.
One of the links on the gearbox is on the rear housing and has to be removed and a dummy put in place to block the hole. After that its all a straight forward fit.
Need advice:MM 550 BA 10 : 4x4  gear box direct Shift.-2wd-ba10-direct-shift-rear-housing-removed.jpg
Need advice:MM 550 BA 10 : 4x4  gear box direct Shift.-2wd-ba10-direct-shift-rear-housing-removed-side-top-view.jpg
Need advice:MM 550 BA 10 : 4x4  gear box direct Shift.-ba10-wd-drive-adapter-rear-housing.jpg
Need advice:MM 550 BA 10 : 4x4  gear box direct Shift.-ba10-wd-drive-adapter-rear-housing-view-2.jpg
Need advice:MM 550 BA 10 : 4x4  gear box direct Shift.-ba-10-2wd-rear-housing-4wd-rear-housing-drive-shaft-end.jpg
Need advice:MM 550 BA 10 : 4x4  gear box direct Shift.-ba-10-2wd-rear-housing-4wd-rear-housing-gearbox-side.jpg
Need advice:MM 550 BA 10 : 4x4  gear box direct Shift.-ba-10-2wd-rear-housing-4wd-rear-housing-gearbox-side-2.jpg
Need advice:MM 550 BA 10 : 4x4  gear box direct Shift.-t18-transfer-case-4wd-adapter-housing.jpg
Need advice:MM 550 BA 10 : 4x4  gear box direct Shift.-t18-transfer-case-4wd-adapter-housing-3.jpg
Need advice:MM 550 BA 10 : 4x4  gear box direct Shift.-t18-transfer-case-4wd-adapter-housing-4.jpg
jyobeb is offline   Reply With Quote
Old 22nd July 2009, 22:26   #33
swastikviji's Avatar
Thanked: 158 Times
Thanks a lot Jyobeb. My savings Drained ,i am going to continue with the old setup for time being.
swastikviji is offline   Reply With Quote
Old 23rd July 2009, 10:54   #34
sreerajunnithan's Avatar
I thought it's NGT530!!!!
--Sree--
sreerajunnithan is offline   Reply With Quote
Old 23rd July 2009, 14:44   #35
Thanked: 655 Times
This was done for my friend last week. My gearbox is an NGT530.
Old 23rd July 2009, 18:20   #36
Alfa_Kilo's Avatar
@Jyobeb
Does the TCase input gear from the main GB have a dog clutch for the PTO?
Alfa_Kilo is offline   Reply With Quote
Old 23rd July 2009, 18:46   #37
Thanked: 655 Times
Originally Posted by Alfa_Kilo View Post
@Jyobeb
No, but it looked like it was possible to fit a PTO with a little ingenuity.
Old 2nd August 2009, 21:40   #38
Thanked: 9 Times
Hi viji what is the cost of new full shifter assembly.
sashas is offline   Reply With Quote
Old 3rd August 2009, 00:00   #39
Thanked: 158 Times
Hi Sachin,
I don't know !!! i tried my level best to get a new shifter assembly its not available. i replaced all plastic bushes to metal bushes now its working better.
Old 3rd August 2009, 22:35   #40
Thanked: 9 Times
Where can i get this metal bush..
Old 4th August 2009, 00:34   #41
Thanked: 158 Times
Hi Sachin,
Any Lathe fellow can do it, my lathe fellow told me that he is making bushes with bi metal, its more durable than brass bushes. it can't be made as a standard for all linkages, because of wear, if you can't do it their you send me the linkages i arrange it here.
Old 20th February 2011, 00:22   #42
dieselhead's Avatar
Thanked: 37 Times
Default Re: Need advice:MM 550 BA 10 : 4x4 gear box direct Shift.
Thanks for the info Jyobeb...Please help me find a 2wd BA10 and the 4wd adapter for the T18. Where can I source them from for my 2000 and 2001 MM 550s (ex army) ?
dieselhead is offline   Reply With Quote
Old 20th February 2011, 10:51   #43
Thanked: 655 Times
2WD Ba10 gearboxes are very easily available, whereas the 4WD adapter plate is impossible to procure. I think that we should just ask "jeepgeorge", to cast us a few sets!
Old 23rd February 2011, 19:25   #44
headers's Avatar
Thanked: 464 Times
@Guys/Beboy
Wonderful information though I am bumping into this thread late..
Can anyone think of reducing the gear shift throws in the KMT 90?
It would then be an amazing gearbox.
I'm told BA10 is a short life gearbox [read flimsy not robust] and NGT 520/530 4WD are hard to find..
Old 8th July 2011, 20:22   #45
SPIKE ARRESTOR's Avatar
Thanked: 809 Times
BA10 GB can be easily converted to NGT530, there is a standard kit available for this, if anyone is interested let me know, I will share the part nos.
Spike
SPIKE ARRESTOR is online now   Reply With Quote
Spider Diesel Tuning Box VS. Pete's Tuning Box - Spider Box feedback on pg 2 Endeavour333 Modifications & Accessories 130 11th September 2017 01:24
The elusive MM540 / 550. EDIT: New Search for ex-Army 550 on page 9 IronWolf 4x4 Vehicles 146 13th February 2015 23:02
Cable Shift vs Direct Shift Gearboxes BlackPearl Technical Stuff 14 15th September 2013 13:35
Audi Direct Shift Gearbox (DSG) rgowani Technical Stuff 18 26th July 2013 22:37
