Old 8th July 2011, 20:30   #46
jeepster's Avatar
Thanked: 1,036 Times
Default Re: Need advice:MM 550 BA 10 : 4x4 gear box direct Shift.
Originally Posted by SPIKE ARRESTOR View Post
BA10 GB can be easily converted to NGT530, there is a standard kit available for this, if anyone is interested let me know, I will share the part nos.
are you saying that BA10 can be converted in to NGT2520 literally ??
or BA10 can be swapped with NGT520??
jeepster is offline   Reply With Quote
Old 8th July 2011, 20:33   #47
SPIKE ARRESTOR's Avatar
Thanked: 809 Times
I never said that, did I? Please read my post carefully above.
SPIKE ARRESTOR is online now   Reply With Quote
Old 9th July 2011, 02:46   #48
AVR
AVR's Avatar
Thanked: 531 Times
Spike
Spike,
Please elaborate on this. Can you put up the part numbers? Costs possible too?
Adi
AVR is offline   Reply With Quote
Old 9th July 2011, 09:21   #49
Thanked: 58 Times
Have a question ...
As I'm learning more from the forum, for 4x4 and Mahindra vehicles, the nub of the matter is in the transfer case..
When in a scrap yard, how does one make out that it's a Borg Warner Transfer Case or the T18 transfer case?
I might be in the hunt soon after the rains
Thanks!
lugnut is offline   Reply With Quote
Old 9th July 2011, 09:41   #50
Thanked: 825 Times
Originally Posted by lugnut View Post
Have a question ...
my bit
1) Borg Warner ( B&W ) made of all aluminum
2) T 18 total iron casting
3) T 18 has a sheet metal plate/cover at the bottom ( B & W , doesn't have that )
4 ) AFAIK T 18 may have a parking brake drum on it ( old ones ) but in B&W not so ( AFAIK )
5) Please PM Mr. Jeepster for few pics , I don't have any
Sudarshan
Sudarshan is offline   Reply With Quote
Old 9th July 2011, 11:19   #51
jeepster's Avatar
Have a question ...
hi
the T18 is cast iron TC.
& will be covered in oil & dirt.
& the front & rear drive shaft output is on the lower side back to back.
the BORG WARNER TC is made of aluminum.
this will have the rear output directly behind the gear bos out put.
BTW there are two types of BW TC's one is mechanical shift (comes with Thar ) & electric shift (comes with bolero/scorpio).
please go trough following thread.
http://www.team-bhp.com/forum/4x4-te...ect-shift.html (Need advice:MM 550 BA 10 : 4x4 gear box direct Shift.)
http://www.team-bhp.com/forum/4x4-te...-possible.html
jeepster is offline   (2) Thanks Reply With Quote
Old 9th July 2011, 17:23   #52
Thanked: 809 Times
Originally Posted by AVR View Post
Spike,
Adi
AVR,
I don't know about the cost, can guide on what needs to be done and how.
For converting BA10 to NGT 530 on Scorpio (Gear drive models)- KIT -- 0703AD3410N (this includes gears / synchros / rails etc). Input gear assembly as per corresponding model will be required.
For converting BA10 to NGT 530 on Scorpio (Chain drive models)- KIT -- 0703AD3400N (this includes gears / synchros / rails etc). Input gear assembly as per corresponding model will be required.
NOTE 1. Gear and Chain drive had different gear ratios. GD was V3 and CD was V1. IIRC, difference between the two was only in the 2nd and 3rd gears.
NOTE 2. This is a skilled job, so it is highly recommended to be done at an authorized M&M service outlet. There is a detailed guideline on what needs to be done and how.
If in doubt get in touch with me.
Spike
SPIKE ARRESTOR is online now   (2) Thanks Reply With Quote
Old 12th July 2011, 13:49   #53
Rajith's Avatar
Thanked: 407 Times
I trust conversion kit of BA10 to NGT530 was devp in late 2006 or early 2007.I was offered the same for my bolero XDP3- BA10 combo due to meshing sound in gear box,later replaced with new NGT530 from the plant.
Rajith is offline   (1) Thanks Reply With Quote
Old 21st July 2012, 20:30   #54
dieselhead's Avatar
Thanked: 37 Times
hi
Need info on mating a NGT520 2WD with a T18.Please let me know the part no for the Adapter between NGT 520 and T18 plus any additional part(Input pinion or shaft).If I can source the required parts from any TBHP members for the conversion.Do I need to change the existing cross member for the KMT of replace with that of the NGT ?
dieselhead is offline   Reply With Quote
Spider Diesel Tuning Box VS. Pete's Tuning Box - Spider Box feedback on pg 2 Endeavour333 Modifications & Accessories 130 11th September 2017 01:24
The elusive MM540 / 550. EDIT: New Search for ex-Army 550 on page 9 IronWolf 4x4 Vehicles 146 13th February 2015 23:02
Cable Shift vs Direct Shift Gearboxes BlackPearl Technical Stuff 14 15th September 2013 13:35
Audi Direct Shift Gearbox (DSG) rgowani Technical Stuff 18 26th July 2013 22:37
