Old 30th May 2009, 17:12   #1
MexXxentric's Avatar
Thanked: 11 Times
Question Performance Clutch for MG 413 Gypsy
Friends,
Can you please enlighten on the clutch plates used on the Pepped up Gypsies?
Sree
MexXxentric is offline   Reply With Quote
Old 31st May 2009, 21:20   #2
shyammg's Avatar
Hi Mexxxentric, Most of the really hotted up INRC and Raid Gypsies use Exedy Clutches, Stage 2 I think.
Shyam
shyammg is offline   Reply With Quote
Old 2nd June 2009, 11:28   #3
Thanked: 7 Times
Shyam
Hi all,
Sorry to divulge a bit from what's being discussed on the thread, but I also think these questions will help alot of people decide.
  1. What are the pros and cons of using performance clutches?
  2. What other parts need to be up-graded to prevent failure? (Clutch spring(s), actuation mechanism, pressure plate, push-rod)
  3. When does it become necessary to up-grade the clutch?
I would definitely like this information before changing the OE clutch to a performance one. Anyone with experience, please share it with us.
'72 Bullet is offline   Reply With Quote
Old 5th June 2009, 07:07   #4
Thanked: 11 Times
Originally Posted by '72 Bullet View Post
Hi all,
answer to question 3
-I need it because the new engine will be producing more torque and power, which an OE clutch can't handle.
Old 5th June 2009, 10:29   #5
DirtyDan's Avatar
Thanked: 785 Times
Uh, huh. So you purchased a new engine without knowing whether you could obtain a clutch to match? Maybe you should start at the beginning of the story. You are more likely to find members who can help you if you do.
Old 10th June 2009, 10:38   #6
pdev29's Avatar
Thanked: 258 Times
there are clutch plates available for gypsies, these are basically for hardcore offroaders so it can take more abuse.. i think you can use that.. it should cost around 15k. one of the members. satan (Neville) has one for his gypsy.
pdev29 is offline   Reply With Quote
Old 10th June 2009, 14:27   #7
Gypsy-Boy's Avatar
I agree with Dan here.
Do post what engine you are changing to, it will be easier to solve your problem with this info.
Right now any solutions given may not help.
GB
Gypsy-Boy is offline   Reply With Quote
Old 10th June 2009, 15:17   #8
S@~+#0$#'s Avatar
Thanked: 37 Times
Mexxentric, tell us more about your engine and planned mods. How do you plan to increase the torque of the 1.3 engine?
Since the title of the thread says "Performance Clutch for MG413", I am guessing that it will be the original Gypsy engine souped up. At the most, it might be a Baleno 1.6L engine. If this is the case, the same peformance clutch can be used in both Suzuki 1.3L and 1.6L applications. Clamping provided by Exedy Stage 2 should suffice. Anybody have the Product Code for this?
S@~+#0$# is offline   Reply With Quote
Old 11th June 2009, 09:46   #9
Gypsy-Boy's Avatar
As per my understanding, one cannot mod the engine to increase the torque.
The torque increase has to be done via the gear box.
Any engine mods like FFE, CAI, Porting etc will result in an increase in BHP.
Though to be honest, I feel that for OTR and street use (especially Gypsy) an increase in power will be sufficient.
GB
Old 15th June 2009, 11:36   #10
Thanked: 7 Times
Default Torque..
Hey Gypsy-boy,
You do actually increase torque with most mods.
Torque is a multiple of the force experienced at the top of the piston. So whenever we modify the vehicle to run better and burn more fuel, along with power, torque increases as well.
Power by the way is a multiple of torque and speed <read rpm>
Old 28th June 2009, 16:49   #11
Thanked: 11 Times
Default sorry for late reply...
Sorry guys,
I was off the topic for a few days.
DD & Gypsy boy,
The "story" is up here
http://www.team-bhp.com/forum/4x4-te...-mg-416-w.html (Project MG 416 W)
The engine is 1590cc, mpfi Baleno block pumping out 91 bhp@5500rpm & 130.5N-m@3000rpm.
I've purchased the engine( actually a whole car ) and started the project after doing a bit reading and confirming the availability of bolt on parts in some other part of the globe.
Pertoworks(US) after market clutch plate for Suzuki Samurai was the one in my mind.
But my objective is to use locally available spares as far as possible.
I posted in the banner of MG 413-
-because I've King's GB and flywheel mated to the 1.6 engine.
- and to get lead to a tried and tested product rather than a speculated one; more 413s are there than 416s.
My application include mild offroading and some rough speeding.
I need a clutch that can stand that abuse without slipping even in 4L.
Gypsy boy, contrary to your understanding OTR needs low end torque.
The concept you have is regarding "torque on wheels" (which we increase considerably by shifting to 4L)
what is the approximate price of Exedy Stage 2 clutch assembly?
From where can I outsource it?
As of now, I am installing King's OE clutch.
Swift D-Clutch/Gear Problem : Competent Motors unable to solve the clutch shudder Eddy Technical Stuff 48 8th September 2013 23:03
Using clutch and designing clutch... The Wolf 4x4 Technical 55 9th May 2011 11:50
Problem with Clutch - Clutch cylinder replaced! Hats off to Talera Motors! Chevy_lover Technical Stuff 0 24th September 2008 14:13
Which is the right Sequence Clutch-Brake Or Brake-Clutch ankura12 Technical Stuff 2 9th July 2007 10:02
wet clutch vs dry clutch and slippers clutches devsus Motorbikes 7 16th May 2006 10:08
