Old 4th June 2009, 12:06   #1
Gypsy-Boy's Avatar
Default Need help identifying this Carb
Hey guys
These are pics of the carb on my 413W.
I know it is not the original as there is an adapter plate between the carb and intake.
I was told that this is a Contessa carb.
Please help me identify it.
Manufacturer - Model
GB
Gypsy-Boy is offline   Reply With Quote
Old 4th June 2009, 12:09   #2
Gypsy-Boy's Avatar
Oops
missed the attachments
Old 4th June 2009, 12:40   #3
adheesh's Avatar
Thanked: 35 Times
Please post the photographs with the air cleaner removed. It seems to be a double barrel mikuni or webber.
Adheesh Parelkar
adheesh is offline   Reply With Quote
Old 4th June 2009, 13:33   #4
Gypsy-Boy's Avatar
Hi Adheesh
More pics - without the air filter
Old 4th June 2009, 15:02   #5
pjbiju's Avatar
Location: Karamattom, Aluva, Kotagiri, Yercaud, Hospet, Indore, Nashik, Pune (now)
Thanked: 465 Times
I jumped into the thread reading that you needed help in identifying a CRAB. But then realized my mistake.
And they (CRABS) do qualify as 4x4 equipped things that can actually even move sideways, right!!
Sorry, but cannot help you with the CARB.
pjbiju is offline   Reply With Quote
Old 4th June 2009, 16:00   #6
Thanked: 54 Times
it doesn't seem like the mikuni to me
techn0l0gist is offline   Reply With Quote
Old 4th June 2009, 22:42   #7
Thanked: 660 Times
Will this help. Something should be written somewhere. remove the whole thing and look.
Carburetor Factory - Illustrations
Old 5th June 2009, 00:57   #8
Ravveendrra's Avatar
Thanked: 406 Times
I think it is a Weber.
Cheers,
Ravveendrra is offline   Reply With Quote
Old 5th June 2009, 10:03   #9
Gypsy-Boy's Avatar
SirAlec - I had gone thru this site earlier when I was trying to id the carb, with no success.
If it helps - It does have an electronic choke.
Old 5th June 2009, 10:09   #10
anurag_p80's Avatar
Thanked: 7 Times
Certainly not a Solex. Maybe a Weber....
anurag_p80 is offline   Reply With Quote
Old 5th June 2009, 11:08   #11
manikjeet's Avatar
Thanked: 110 Times
its a hitachi carb which was used on the earlier contessa pre 94/93 models it help the engine make 88 bhp (1.8 Isuzu engine )
its also know as window wala carb in mechanic language and finding spares for it is not easy
my contessa has the same carb
manikjeet is offline   Reply With Quote
Old 5th June 2009, 11:15   #12
Rudra Sen's Avatar
Thanked: 4,290 Times
Originally Posted by manikjeet View Post
its a hitachi carb which was used on the earlier contessa pre 94/93 models it help the engine make 88 bhp (1.8 Isuzu engine)
And later on they changed that to Esteem's carb to get better fuel efficiency.
Old 5th June 2009, 11:39   #13
Gypsy-Boy's Avatar
Rudra - Thanks
Manikjeet - Thanks
Now gotta figure out how to get spares for it.
Or alternatively swap it for an esteem carb.
Any help for either would be appreciated
GB
Old 5th June 2009, 11:49   #14
Rudra Sen's Avatar
You'll find it at Shivajinagar gujri. Let me also check out with my previous mechanic if he has any.
Old 5th June 2009, 12:05   #15
adheesh's Avatar
Thanked: 35 Times
It is indeed a Hitachi. The HM Contessa as well as the earlier 118NE s also came with a double barrel Hitachi.I suppose the throttle body must be the same. An Indian company named Pacco makes parts as well as whole replicas of these carburetors. Check this link out for more information carburettor, carburetor, tps, throttle position sensor, throttle body, fuel rail manifold, fuel pumps, crankshaft, Yamaha, suzuki, kawasaki, honda carburettor
Adheesh Parelkar
Need help in identifying this Jeep? EDIT : It's a CL & MM Hybrid Driving_Nomad 4x4 Vehicles 12 28th June 2012 17:18
Need Help in Identifying this Jeep? EDIT : It's a fake Classic Acclero 4x4 Vehicles 15 25th January 2012 04:23
Need help on identifying KKK turbo from Tata Indigo techn0l0gist Technical Stuff 17 9th April 2010 09:06
Help required with identifying Background score... adit1329 Shifting gears 10 27th March 2006 19:46
