| 4x4 Technical Engines, Diff-locks, SPoA, Techniques and more |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Dec 2007 Location: Gurgaon, Delhi NCR
| Team BHP members from Chennai, does the facility to manufacture Solex carburettors still exist there ? Can someone help me source a new or used / restored Solex carburettor to sit on the Hurricane engine of my petrol CJ3B Jeep please ? What about the Indian equivalent called PEICO, has anybody used this make ? Do they work fine ? Would love to get some information on these ascpects.
__________________ Driving to the future |
| | #3 (permalink) |
| BHPian | If you give me a month's time (normally I need that much to visit certain places), I can check with few people here. I got a original TVS Lucas delco (Injector) for one of our TBHPian, may be same place i can check for you.
__________________ My Bikes: yamaha-rd-350 rajdoot-gts & jawa-250 My Jeep: mahindraclassic My Travel: camera-friendly |
| | #5 (permalink) |
| Distinguished - BHPian ![]() | The new carburettors are no longer being manufactured (stopped in 1999). However you can get SOLEX service kits for the M34PBIC. Otherwise you can use the KPACCO & PTM kits in the Original Solex Carburettor. Regards, Arka
__________________ JEEPers speak - Engage Mind, before opening Mouth!!!!! |
| | #6 (permalink) |
| Distinguished - BHPian ![]() | Some details from the CJ3B page Solex Carb Notes on The CJ3B Page Solex Carb Tips on The CJ3B Page From my experience I would suggest 1) Increase the idle speed to 600-700rpm as a) increase oil pressure b) lesser chances of flooding and backfire c) better descent control (12kgm@900rpm) 2) As Mr. Behram Dhabar strongly suggests, put a return line from the carb to the fuel line. The advantage a) reduces flooding b) increases Fuel Economy c) improves carb life (float/lever & gasket/packing kit) Also change main jet size between 127.5 to 140 Regards, Arka
| | #7 (permalink) | |
| BHPian | Quote:
The solex carb from an Amby will work on the 3B, but not with the best results. Anyway, I could not even find a new 32mm Amby carb in Bangalore, let alone the 34mm that came with the 3B. I had issues with used carbs, and finally on the 4th try have one that works! Jammy has ordered a new 34mm one for me. I don't know where he is getting it from, but he may be able to get you one too. The other obvious person that can help you is Mr. UBS. If not a new one he can probably get you a used, but tuned up carb.
__________________ Ganesh Banavar The form matters not if the function minds it, else, the heart takes over! | |
| | #8 (permalink) |
| I would love to get hold of a new / used Sloex 34 mm carb. ex670c, your suggestions have been noted with great interest. Are there any pictures / more details of the return pipe line to the fuel line. Also I would like to purchase a service kit complete with float, jets and packing for this Cj3B carburettor. Can you help me with this please ? They are not available in Delhi, only the local made Pieco one is available. Our friend Rabindra Singh has been lucky in his hunt. He has a solex service kit complete in a tin box manufactured in the 1960s I guess, he got it from the old Jeep dealer in Jodhpur, Rajasthan. I hope V 16 can find a carburettor for me. Just tell me how much and where to send the money it can be shipped by courier. Best regards, Shahid Note - How about going further ? Can a petrol engine fuel injection system be installed on this Huricane engine ?
__________________ Driving to the future Last edited by desertfox : 15th June 2009 at 14:12. |
| | #9 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
Below the fuel Inlet there is a Brass Screw, the return line can be fitted there. Regards, Arka
__________________ JEEPers speak - Engage Mind, before opening Mouth!!!!! | |
| | #10 (permalink) | |
| BHPian | Quote:
Even the Solex Carb diagram does not mention that this Brass Screw can also be used as a return line. Am glad you confirmed. @Shahid: I have posted a picture in the above-mentioned post. It is not very clear, but may give an idea though. The picture is from gbanavar's Jeep.
__________________ Cheers Santhosh Last edited by S@~+#0$# : 15th June 2009 at 15:57. | |
| | #11 (permalink) |
| BHPian Join Date: Jul 2007 Location: MUMBAI
| Dear Desertfox - you can use any Solex carburettor body as long as you maintain the metering elements as required by the F4134 engine. The main jet is size 140, the venturi is 24 mm. Both are separately available. If you use a 22 mm venturi, you may gain a little driveability but you will suffer in fuel consumption. So please do not tear your hair out searching for a Jeep Solex. Dear Arka - in order to incorporate a return line in case of a car fitted with the Solex carburettor, you need a brass "tee" connector with BLG 3 specification corrugation or bulge for an 8 mm pipe (5/16 inch). These are available at shops which sell hydraulic line parts. Then you dismantle a "160" size idler petrol jet from a scrapped old Solex carburettor, tap the centre leg of the tee to M6*1.0 thread and insert the jet in it. This acts as a restrictor / orifice. If this is not done, most of the petrol will go back and the engine will starve. If the orifice size is too small, it is as good as not having a return line at all. Connect the fuel outlet from the pump to the tee, connect the other end to the carburettor and connect the orifice to the return line which you will have to fabricate upto the tank. Mount the tee on the side of the carburettor very near to its entry point so as to keep the last pipe length to a minimum. You can fabricate a simple bracket for this purpose. Just for your information, it took me around 3 months of evaluation of the system on the engine dynamometer and then on the car to optimize the orifice size. I have full database. Also, adding a return line does not improve fuel consumption, it only reduces fuel temperature by 10 degrees, the most effect is during hill climbing. Best regards, Behram Dhabhar |
| Thread Tools | |
Similar Threads | ||||
| Carburettor mod for Padmini-S1 | Intrepid | Modifications & Accessories | 17 | 2nd November 2009 12:58 |
| Injector and carburettor cleaner for my Swift ! | siddhu_engg24 | Modifications & Accessories | 6 | 10th November 2008 10:14 |
| Petrol leak from Carburettor - Mach 500 | Ketan | Technical Stuff | 5 | 12th July 2007 14:19 |
| How does one find a vaccum leak in a carburettor? | techn0l0gist | Technical Stuff | 1 | 14th January 2007 00:54 |
| Solex fiat jets | topend_hooligan | Modifications & Accessories | 1 | 1st February 2006 09:49 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
