Old 24th June 2009, 18:12   #1
Default Gypsy Modifcations
A Big hello to all on this forum.
I just got a used Gypsy MG 410 HT, 93 Model and was getting it done for my use. I have a few questions :
1. I'm trying to get a 5 speed gearbox, probably a used MG 413 gearbox. I'm unable to locate any used ones in Bangalore. It would be great if someone gives me directions on how to find one.
2. The tires are no good and need to replace them, but don't want to spend too much on a new tires. Is any body aware of any used ones ? The tyre size is 205/70R15. Even if I go for new ones , will the 215 size fit on the stock rims?
Arunmudgal
arunmudgal is offline   Reply With Quote
Old 25th June 2009, 10:01   #2
Thanked: 226 Times
Arunmudgal,
Congratulations!
Getting the 5 speed gearbox of Gypsy King is difficult. I would suggest go for gearbox of baleno, esteem or isuzu and mate with gypsy engine. You can retain the 4 wd as it is because of divorced nature of the transfer gear box.
good luck
dwaraka is offline   Reply With Quote
Old 25th June 2009, 10:15   #3
GoSlow's Avatar
Thanked: 68 Times
Hi arunmudgal
Firstly, congrats on your new acquisition. Please post some pics.
1. The MG 410 gearbox is built for speed/torque of the 1.0L engine and works well with the 4x4 transfer case. If you do not wish to retain the 4x4 then it will be easier to swap it for another 5 speed box. But if you do want to retain the 4x4 then I am not sure how well the gear ratios on a Gypsy King or any other vehicle 5 speed box work with the current engine.
Just something to think about before you make any changes.
2. You should be able to get 2nd hand tyres from scrap tyre dealers. You could also try and contact TBhp gygpsy owners in your city to see if anyone has changed their tyres recently and may still have tread on the old ones as people usually go for bigger tyres without depleting the current ones fully. I have 215 (tubeless) on my gypsy and these are fitted on the stock rims. No problems so far.
Ankit
GoSlow is offline   Reply With Quote
Old 28th June 2009, 16:19   #4
MexXxentric's Avatar
Thanked: 11 Times
Default baleno & esteem's GB?
Originally Posted by dwaraka View Post
Arunmudgal,
Congratulations!
good luck
Yep, getting a Gypsy's GB will be difficult, but not impossible.
Baleno & esteem are FWD vehicles. so better leave that option.
If anyone want it, I can spare a Baleno G.B
I've driven an Isuzu diesel converted gypsy with isuzu G.B. The 1st gear was ultra low and it had 4 gears in effect ( 2 to 5)
MexXxentric is offline   Reply With Quote
Old 28th June 2009, 17:24   #5
COUGAR's Avatar
Thanked: 83 Times
215 tyres should fit. I think max size available for the rims are 235.
Do you really want 215's? Turnign the b**ch is a task even with the stock tyres!
COUGAR is offline   Reply With Quote
Old 8th July 2009, 00:28   #6
Thanked: 595 Times
can anyone photoshop the extended fenders on a Gypsy??, i want to see how they would look before i order them!!
i would pefer a front angle to actually see how they would look on a gypsy!
thanx in advance!
here is an example photo.
Parm is offline   Reply With Quote
Old 8th July 2009, 10:24   #7
jeepster's Avatar
Thanked: 984 Times
a rear side
a front side
more pictures here (Gypsy - Overhauled!!)
jeepster is offline   Reply With Quote
Gypsy vs Gypsy King prasygreat 4x4 Vehicles 90 15th April 2016 01:14
Gypsy Veterans Please help me... Is this a Gypsy King ?? Sabareesh 4x4 Vehicles 27 15th May 2010 01:17
Gypsy or Classic ? Now bought Gypsy pdev29 SUVs, MUVs & 4x4s 45 25th July 2008 11:19
Gypsy driving a Gypsy enygma Introduce yourself 6 29th June 2007 15:47
