Old 29th June 2009, 14:07   #1
desertfox's Avatar
Thanked: 549 Times
Default Jeep brake oil leaks
This is a frequent occurance in my CJ3B Jeep. Every two months or so, or rather every couple of times I go offroad, one of the break fluid lines develops a leak and the brakes fail.
Is there a modification that can be done to prevent this ?
As a precaution I am always carrying some brake fluid with me.
desertfox is offline   Reply With Quote
Old 29th June 2009, 16:42   #2
Thanked: 106,850 Times
Desertfox, your Jeep has a dangerous habit! How about overhauling the entire braking system, starting with fresh OEM quality plumbing for the brake lines? You'd get parts straight from Mahindra.
Old 29th June 2009, 16:59   #3
desertfox's Avatar
Thanked: 549 Times
I guess I will have to do that, is it a common problem with other Jeeps as well ?
Baleno(altura) steering oil leaks, car overheats on using ac, help required sukrit7 Technical Stuff 33 21st April 2010 10:59
Nokia 'leaks' pics and specs of its iPhone killer nishantgandhi Gadgets, Computers & Software 17 4th August 2009 12:20
BMW X6 M Leaks Ahead of New York Debut hanmust The International Automotive Scene 7 5th April 2009 21:03
European patent office leaks final preproduction Suzuki Kizashi sedan sketches sidindica The International Automotive Scene 9 12th September 2008 21:12
