Old 18th November 2011, 10:42   #31
Thanked: 27 Times
Default Re: New body shell for MM540
@Twinn
Thank you for the input. I did get to know about the availability of these tubs from Kerala shall enquire and find out. The local brands from Mangalore I came across didnít have a good finish and moreover 3 tubs I saw had damages due to bad transport handling and rust due to the wet weather as the tubs were not pre-coated. Please post a picture of your tub if possible.
Dear DB Sir,
Thank you very much for writing in detail; You have been very thoughtful for having designed the tub taking into consideration the requirement of non-NGCS vehicle owners too. From my observation I felt that there was some difference in the transmission shifter cover area floor/fire wall between the Thar DI and CRDe bodies. Hence thought that the DI body would be a closer match, please correct me if Iím wrong.
Itís an honour to have you on this forum helping all of us out. Further I will require your guidance for the restoration kindly oblige.
Warm Regards,
Chengappa.
Timson is offline   Reply With Quote
Old 18th November 2011, 16:25   #32
Thanked: 4,673 Times
Originally Posted by Timson View Post
Dear DB Sir - From my observation I felt that there was some difference in the transmission shifter cover area floor/fire wall between the Thar DI and CRDe bodies. Hence thought that the DI body would be a closer match, please correct me if Iím wrong. Warm Regards, Chengappa.
Dear Mr.Chengappa - the Thar DI uses the NGT520 transmission whereas the Thar CRDe uses the NGT530R transmission. There may be some minor differences in the floor cover which contains the cutout. I once again state that for one car, you can make local changes and finish it off, it is too minor to be of any consequence. I'll certainly guide you with the restoration.
Strictly for academic information - if you have to do the same "minor change" in production (Oh My Dear God Almighty! ), you will need to climb the mighty Himalaya Mountain rather than crush a molehill. It starts with a PPRF, goes through an FTR and ends with a PPAP. It is a good process in the interest of the product but it is too complicated to explain. I will not even try.
. HaHaHa.
Best regards,
Behram Dhabhar
DHABHAR.BEHRAM is offline   (1) Thanks Reply With Quote
Old 21st November 2011, 00:44   #33
twistwrist's Avatar
Thanked: 20 Times
Dear ALL,
I have been enquiring across various M&M dealerships for a MM-540 tub but all say it's not possible to procure one. I would like to know if a Thar DI tub will be suitable on a non-NGCS MM-540 chassis. Spike/DB Sir please throw some light.
Chengappa.
Chengappa,
kindly find some part nos of mahindra thar, could be helpful in ordering.
twistwrist is offline   (8) Thanks Reply With Quote
Old 22nd November 2011, 19:16   #34
Thanked: 27 Times
@twistwrist
Thank you very much for uploading the extract of the Thar parts catalogue. I did try a few days ago ordering for body shell part number Ď0101AAD00590Aí and the dealership quotes Rs.100k Yet to decide which way to head.
Chengappa.
Old 23rd November 2011, 10:09   #35
Dear twistwrist / chengappa / all - in picture 3, serial number 3, part number 0083003 is correct but drawing is wrong. Part as shown is fitted in Thar DI / MM540 army. For Thar CRDe, lower angle bracket is not fitted, as 0083003 goes in a round bracket welded to the rear extremities of the body shell. The design is different to get a close tolerancing in "Z" (vertical) direction for proper fitting of the canopy to prevent wrinkles / fluttering noise. The CRDe bracket incorporates dimples in it which locate 0083003. This is for your information.
Best regards,
Behram Dhabhar
DHABHAR.BEHRAM is offline   Reply With Quote
Old 23rd November 2011, 10:28   #36
Thanked: 822 Times
Where can I find a suitable body to replace my MM540's current one ( stretched Limo ) like this ,
Is there any alternative body available for this ??
Attaching an Official brochure of MM ( of My model of Jeep )
Sudarshan
P. S. Dear Behram Sir can you please guide me through this ??
Sudarshan is offline   (1) Thanks Reply With Quote
Old 23rd November 2011, 10:39   #37
Thanked: 28 Times
Attachment 846272
Sudarshan
Seeing the back ground and the pillars, guess this is shot in Mahindra Towers itself. No location rent, cost effective production.
kavesh55 is offline   Reply With Quote
Old 15th January 2013, 13:00   #38
Thanked: 37 Times
I was serching for entire new body for my cousins cl500 Di. found these in Indira motors , Calicut.
CL 500 body tub and other parts are made of 16 guage steel with some kind of sealent in all joints. finish was also good.
cost of tub was 16k and total cost including fenders, bonnet, grill and windshield frame came to 31K. bought it since it was way less time consuming and better finished than any tinker doing it in local work shop.
also found MM540/550 tubs in their stock yard made of 18 guage steel. price quoted was 30k. even this is available as part by part also.
IMO this is a way better option than goin for a complete body refurbish by any tinker . since these guys will never finish on time
thouht fo posting if some body is looking for an info.
cheers
toms_2191 is offline   (7) Thanks Reply With Quote
Old 17th February 2013, 22:28   #39
Jerrycan's Avatar
Thanked: 107 Times
cheers
Thanks for sharing the info bro. I was desperately looking for a 540 tub.
If it's not much trouble, can you PM the contact details, please :-)
Jerrycan is offline   Reply With Quote
Old 18th February 2013, 13:35   #40
Thanked: 37 Times
Anything for a jeep lover . check your PM
cheers..
toms_2191 is offline   Reply With Quote
Old 18th February 2013, 16:51   #41
Jerrycan's Avatar
Thanked: 107 Times
Thanks you Manu. I spoke to the guy. He seems to have shells in various thickness. Planning to pay him a visit this week.
Thanks again
regards
Old 20th February 2013, 19:06   #42
Thanked: 18 Times
Hi jerrycan, i have mentioned in other thread regarding army auctions that the dealer here has army 540 body shells with him.I have given his cel no. so you can enquire from him.An ex army body shell is any day better than a locally made one.
regards,
hps aulakh is offline   Reply With Quote
Old 22nd February 2013, 00:03   #43
Jerrycan's Avatar
Thanked: 107 Times
You are right Mr.Aulakh, army tubs are any day better. But the transit damage and cost of transportation is very high. I got a shell from Mayapuri, by the time it reached Coimbatore, it had dents all around.
Old 22nd February 2013, 07:56   #44
Thanked: 822 Times
Anyone knows about such shells available in & around Pune or Mumbai ??
My options are open ,if I like the workmanship I will certainly get one , OE or Non OE
Sudarshan
Sudarshan is offline   Reply With Quote
Old 22nd February 2013, 12:09   #45
AVR
AVR's Avatar
Thanked: 511 Times
Sudarshan
Sudarshan Bhai,
There's a place near Palanpur, Gujarat called Kanodar which is largely into body shells and rebuilding from ground up. That might be a good place to look for your Jeep body too. Next time you are in Ahmedabad, you can try making a trip there. It's a couple of hours away from here.
Cheers,
Adi
AVR is offline   (1) Thanks Reply With Quote
My MM540 4X4 Build: new shell, SOA, PS etc 4x4Roadie 4x4 Vehicles 41 28th October 2016 16:54
MM540 2wd to MM540 4wd and Restoration Rajith 4x4 Vehicles 48 1st October 2015 23:45
550 xd body shell on invader chassis sammyaulakh 4x4 Technical 6 19th July 2011 15:51
MM540-4WD wish list - what you really want in your MM540-4WD? DHABHAR.BEHRAM 4x4 Vehicles 299 7th January 2010 13:02
