Old 14th April 2010, 17:50   #151
Jaggu's Avatar
Thanked: 8,684 Times
Thanks DKG, i think ill have to get myself to do this. My mech somehow doesn't seem too keen on this, he says the new springs are not good quality etc compared to the ones i have
This month is really packed and am not getting time to do anything apart from meetings and excels :((((
Old 15th April 2010, 20:31   #152
Thanked: 825 Times
Default New Idea (may be)
I havent gone thrugh all replies (short of time). Someone may have suggested it before,
Well here it is see the Jeep (cj etc) has a beauty of its own, it has a lot of part shareing in its range (the cj,fc,540),It is practically a meckano.
So the idea is to put the leaf springs OVER the axceles (Have you seen a FC model ?) Following needs to be taken care of
1) the prop shaft length
2) new leafspring stays (to be weilded on top of existing axcel housings
3) you may need widening of track (you can use the FC axcel housings )
4) flex. brake hose length (bet chassis & axcel housings)
5) finally 7.50 X 16 8ply tyres
there can be other aspects also but I tried to give you a basic idea
Sudarshan is offline   Reply With Quote
Old 1st May 2010, 23:18   #153
narendra.vw's Avatar
Thanked: 402 Times
If the diff is considered for GC, tyre is the only choice. If Engine or gear box belly considered for GC it can be done by increasing leaf spring porch height. Care should be taken while welding the porch (alignment )
narendra.vw is offline   Reply With Quote
Old 3rd May 2010, 18:16   #154
Thanked: 9 Times
Whatever you are adding (leaf or packing), you are adding below the main leaf, which remains the topmost leaf, right?
Sutripta
yeah thats true. im quite sure no one is adding extra leaves above the main leaf.
bushmaster is offline   Reply With Quote
Old 3rd May 2010, 18:29   #155
Thanked: 9 Times
i tried all this out on my jeep. best is to re camber the leaves and put a 3-4 inch longer shackle than the stock one. makes a lot of difference. shifting leaves on top sends the jeep too high and makes it un roadworthy in addition to changing virtually every part from drive shaft, brake hoses, anti roll bar connecting rods et al.
Old 10th May 2010, 21:19   #156
Thanked: 402 Times
Very true, I agree to your opinion about leaf spring on top of diff housing. Handling jeep without stabilizer rod on normal roads is hard.
For lengthy shackle care to be taken that, they should be strong enough to take
Twist and hard turning, also porch to be strengthened .
Old 23rd May 2011, 12:24   #157
gypsyFreak's Avatar
Thanked: 188 Times
Default Re: Composite Fibre Leaf Springs: Can they be used for off-roading?
Originally Posted by mooza View Post
Adding a leaf to the leaf spring maybe a safer and better option to stiffen the rear suspension, if stiffening is what is required to make the ride better (experts and users of the Endy please correct me if I am wrong).
I have added a leaf pair for the leaf springs of my Scorpio a couple of weeks ago, and this has helped reduce the swaying and excessive jumping. It cost me Rs. 1900/- including labour, at an FNG.
I do not know whether this will affect the warranty, though, if done somewhere other than the ASC.
Is there any increase the ground clearance after adding a new leaf. any changes to body roll?
gypsyFreak is offline   Reply With Quote
Old 23rd May 2011, 17:31   #158
mooza's Avatar
Thanked: 271 Times
^^ Yes, the body roll did go down.
Regarding GC, I think it depends on the camber given to the entire leaf set. More the camber provided to the leaf set, higher the GC.
If increased GC is all that is required, do not add any leaf, just increase the camber, IMO.
mooza is offline   Reply With Quote
Old 24th May 2011, 12:21   #159
Samurai's Avatar
Thanked: 15,767 Times
The leafs do not affect GC at all. The differential pumpkin stays where it is, no matter how much camber you give. You can give body lift with camber, but no GC improvement.
Old 24th May 2011, 20:38   #160
mooza's Avatar
Thanked: 271 Times
Oops yes, the differential would stay wherever it is, the body connected to the shackles would be the only thing getting some lift
Old 24th May 2011, 21:19   #161
headers's Avatar
Thanked: 464 Times
One can add extra leaf[ves] to the suspension along with re cambering to get a slight increase in GC - but only slight [say around 10-15mm]
Just re camber alone will not increase GC.
Remove the anti-roll bar and re camber to get more articulation out of a gypsy!
Old 24th May 2011, 22:31   #162
Samurai's Avatar
The diff housing is sitting on the wheels, un-sprung. How is adding the extra leaf going to lift the diff housing?
Samurai is offline   (1) Thanks Reply With Quote
Old 24th May 2011, 22:51   #163
Grace's Avatar
Thanked: 159 Times
unless the SPOA'd I suppose?
Grace is offline   Reply With Quote
Old 24th May 2011, 23:09   #164
Thanked: 2,395 Times
Axle remains where it is.
Sutripta
Old 24th May 2011, 23:12   #165
Samurai's Avatar
The axle is still on the same old wheels.
Optimum ground clearance of a Car? & how it is measured... skamb Technical Stuff 84 17th May 2017 22:36
Raising a Tata Marina's Ground Clearance vivek.singh.73 Modifications & Accessories 27 8th September 2013 21:43
Ground Clearance cartech Technical Stuff 35 10th November 2012 10:41
NHC ZX - Ground Clearance venkatrx The Indian Car Scene 17 30th July 2009 20:22
NHC Zx Ground Clearance and Ride quality mahesh4sure The Indian Car Scene 8 24th February 2006 11:39
