Old 14th July 2009, 17:31   #1
Gordon's Avatar
Thanked: 197 Times
Default HELP Required: 1988 Mahindra Jeep 540DP 2WD
Hi, a friends dad owns this in Goa. Wanted a few estimates/contacts/options regarding the following in Mumbai/Goa. He is open to second-hand parts too.
  • Steering - Marshal Steering
  • Seats - Bucket Seats (Contessa)
  • Suspension (Gabriel Shock Absorbers) - I guess the 540 has traditional leaf spring suspension. Needed prices and approximate conversion costs.
  • Seat Belts
Gordon is offline   Reply With Quote
Old 14th July 2009, 17:48   #2
Spitfire's Avatar
Thanked: 707 Times
Where in Goa?
Ask him to go to the shop opposite REAL's in Panaji near Azad Maidan.
There is shop and garage at the same place. He should stock MM 540 stuff.
All MM 540 parts are available in Goa. Other then the seats and stuff.
You mean only the steering wheel or the whole steering assembly?
Instead of trying to mount seats from a different car with mouting points to be fabricated. Use the original seat and make it better. Or go for the Bolero seats. I guess the mounting points are the same. They are not Bucket seats per se but better then the original MM540 seats.
You cannot take off the leaf springs and add shock absorber. The shock absorber is to give it a less bouncy ride then with just leaf springs. Without the leaves your Jeep is not going anywhere.
Presently the only viable options for a better ride (with leaf springs) is to go with composite fibre leaf spring. Look for Mr khan_sultan's post under technical section of 4x4 & Offroading.
Link -> http://www.team-bhp.com/forum/4x4-te...f-roading.html (Composite Fibre Leaf Springs: Can they be used for off-roading?)
  • Seat Belts
Get the ones from the Bolero.
Spitfire is offline   Reply With Quote
Old 14th July 2009, 18:34   #3
Gordon's Avatar
Thanked: 197 Times
Only steering wheel.
He wants bucket seats. Right now it has the stock seat. Will check for Bolero seats too.
Sorry for "MY" ignorance. Maybe he meant that. Said that he seen a lot of Mahindra jeeps with Gabriel shocks.
If possible, it'd be great if one could post approximate prices of new/second spares.
1988 Mahindra CJ 500D 4WD Diesel Jeep aravind kannan 4x4 Vehicles 19 24th February 2013 17:27
Yet another MM 540DP blueblooded 4x4 Vehicles 56 8th September 2012 20:33
My 540DP Restoration II (Very Short Thread) 53BHP 4x4 Vehicles 54 31st July 2012 14:53
My first JEEP - Mahindra MM540 2WD Trojan Test-Drives & Initial Ownership Reports 6 6th July 2012 17:00
Attempted off-roading with a 2WD Jeep Rough Square 4x4 Excursions 36 25th September 2008 23:11
