4x4 Technical Engines, Diff-locks, SPoA, Techniques and more
LinkBack Thread Tools
Old 28th July 2009, 13:35   #1 (permalink)
nikhil1300's Avatar
Default Carburetter blacking for gypsy
Has anyone faced this problem of carburetter blacking.Well i sent my Gypsy to RNS for cleanig of spark plug and the carburetter and i get a call from them that it is not possible to clean my cab because of blacking as i was running on lpg for some time and then changed to petrol.So i asked them what to do ,so they told me to replace my cab(are they taking me for a ride) and the amount was 25000+lab+tax,so i told them not to do anything and send the car back.So they just replaced the plugs and sent the car back
Experts on the forum pls advice what is the next step,should i go in for a second opinion(where)if i have to change my cab which other cab(model) can fit on my car,or where else can i get my cab cleaned?i am from bangalore
nikhil1300 is offline   Reply With Quote
Old 28th July 2009, 13:58   #2 (permalink)
Gypsy-Boy's Avatar
Hey nikhil
Post some pics of the carb with the air filter removed
GB
__________________
Oh God we thank you for
Mud
Rocks
and the rain to make trails challenging!!!
Gypsy-Boy is offline   Reply With Quote
Old 28th July 2009, 16:53   #3 (permalink)
swastikviji's Avatar
Hi Nikhil.
The original Aisin carb costs you 22K Never go for it ,almost all gypsy's from 97 to 99 has carb problem ok.
swastikviji is offline   Reply With Quote
Old 28th July 2009, 17:45   #4 (permalink)
gd1418's Avatar
Soak the carb in DOT3 brake oil for sometime and then try cleaning with the brake oil itself.
__________________
Royal Enfield Bullet 1962
All Black 1998 Safari 4x4
All Black 2004 Scorpio GLx
Old 30th July 2009, 08:39   #5 (permalink)
nikhil1300's Avatar
thanks alot gd1418 and swastikviji will try it out and get back and in the mean time will try and post the snaps
Old 30th July 2009, 12:48   #6 (permalink)
MexXxentric's Avatar
Default waxed out?
Bro,
I think that your carb. has accumulated a lot of wax that comes along with LPG.
Its a common problem associated with prolonged LPG.
You might be one of the experts who would even do cold start in LPG itself.
My cousin brother was one of the kind and he landed with a crank shaft stuffed with wax, blocking the lube oil flow.
Solution for your carb. issue
Get 2-3 cans of WD-40 and Bath your carb. with it, force the cleaner though every holes in the carb. and finish off with brush scrub. A local mechanic will be the suitable person to do this labour intensive task.
Make sure that its done in a well ventilated area. WD-40 fumes are not worth inhaling.
Pickling the same in brake fluid or kerosene also might serve as a cost effective solution.
__________________
Palio Sport
Maruti Gypsy (undergoing transplant)
MexXxentric is offline   Reply With Quote
Old 30th July 2009, 14:33   #7 (permalink)
nikhil1300's Avatar
hey thanks guys i just got the carb cleaned from a local mech he socked the whole carb in pegasoil(white petrol)for about 30min ,drained out the white petrol and pressure washed it with normal petrol brush few parts with plastic brush stuff like the jet etc fit it back and whoola ready to go zoom,zoom, zoom thank you all for the lovely inputs.
Thread Tools
Gypsy Veterans Please help me... Is this a Gypsy King ?? Sabareesh 4x4 Vehicles 26 11th February 2010 17:39
Gypsy vs Gypsy King prasygreat The Indian Car Scene 67 8th December 2009 14:13
Will Gypsy King's front Differential Hub/ Casing fit for a Gypsy Gypsy_roadies SUVs, MUVs & 4x4s 3 16th March 2009 16:23
Gypsy or Classic ? Now bought Gypsy pdev29 SUVs, MUVs & 4x4s 45 25th July 2008 11:19
Gypsy driving a Gypsy enygma Introduce yourself 6 29th June 2007 15:47
Powered by vBulletin
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2000 - 2010, Team-BHP.com
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652
