Old 9th December 2010, 11:42   #151
ex670c's Avatar
Thanked: 1,799 Times
Default Re: Suggestions For A Robust Fusebox Replacement
Originally Posted by genesis View Post
A bit tired with electricals conking out every now and then especially with fuses getting loose/blowing up.
Would welcome suggestions for a robust fusebox replacement with 'proper' plug in fuses.
Are any particular vehicle types more recommended than the others?
Hi Soumya,
Instead of mounting the Fuse Box vertical, why don't you try mounting it Horizontally, or just rotate the Fuse Box so the Fuse are Parallel or at a slight angle to the Ground .
Arka
Old 11th December 2010, 17:03   #152
genesis's Avatar
Thanked: 295 Times
Originally Posted by ex670c View Post
Hi Soumya,
Arka
Thanks Arka.
Also this is one of your rare posts without any acronyms or technical terms .
I appreciate that even more!
genesis is offline   Reply With Quote
Old 12th December 2010, 17:03   #153
Default Re: All questions for CJ 3B
arka,
how does the orientation of the fuse box make any difference?
mine is vertical and no issues as yet, the fusebox is a lift off from the major, all slots have fuses not wires and yes it works well.
sharat
docfreak is offline   Reply With Quote
Old 13th December 2010, 10:24   #154
ex670c's Avatar
Default Vibration
Originally Posted by docfreak View Post
arka,
sharat
Hi Docfreak, The Orientation of the Fuse Box/Fuse will make a difference. The Fuse (Cylindrical) is vertical in the Clip Type holder, it can get loose with vibration. If the Fuse if parallel to the ground, the vibrations will not loosen the fuse. If it is slightly angled, the fuse box will not retain water. Regards, Arka
Old 14th December 2010, 14:17   #155
simple hard learnt lessons. it seems.
hats off to u boss.
can you help me in sourcing a overdrive?
Old 14th December 2010, 18:07   #156
ex670c's Avatar
Default Ffe
hats off to u boss.
Hi DocFreak,
You better ask REDMM340, Gaurev Prabhakar about the overdrive purchase and installation.
I would suggest you try out a free-flow exhaust, it definitely improves the rev-ability of the F4-134.
Arka
Old 15th December 2010, 07:47   #157
SPIKE ARRESTOR's Avatar
Thanked: 757 Times
What if instead of a cartridge type fuse, a blade type fuse is used?
+1, Siva aka Trammway also!
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 15th December 2010, 08:11   #158
genesis's Avatar
Thanked: 295 Times
Spike
@Spike:Which Mahindra model can I borrow a blade type fuse box from.
Old 15th December 2010, 11:18   #159
free flows on a hurricane, what a racket it would make........
i was thinking of putting in a CAI as well.
any other ways by which without giving up the gear ratios i can attain better speeds? currently i do 70 with ease on my ndms
Old 15th December 2010, 12:18   #160
Jaggu's Avatar
Thanked: 7,658 Times
Hope you pray when you apply brakes! Get decent tyres and then to improve top speed try the overdrive ratio, which will be most effective. If you change the diff ratio, then you will lose out on terrain munching capability. This is my opinion.
Old 15th December 2010, 12:26   #161
ex670c's Avatar
Hi Doc Freak,
You can change the 3Speed to the Low Ratio T-90, and then Change the Diff-Ratio to 4.88 .
If the FFE is well designed it will not make a racket, but the characteristic growl is amplified.
Arka
http://www.team-bhp.com/forum/4x4-ve...t-violent.html (Silent, But Violent)
Old 15th December 2010, 20:26   #162
Thanked: 757 Times
Boleros as well as Scorpio use blade type fuses in various circuitry. The old cartridge type fuse extinct on M&M models AFAIK.
Spike
PS- Fuse elements (the small rectangular dabba type) are also used.
Old 15th December 2010, 22:04   #163
arka how will the t90 make any difference? the top and lowest gear ratios are same, only the second is divided into the second and third right?
it brakes well at 70, no issues on that front.maybe i am just used to it now.
the diffs swap i have been planning on. any specific do's/dont's??
Old 16th December 2010, 10:40   #164
ex670c's Avatar
Hi Doc Freak,
T-90
1st 2.798:1
2nd 1.551:1
3rd 1.000:1
Rev 3.798:1
Lower Ratio T-90 (optional) (FJ Van/CJ4/CJ4A)
1st 3.339:1
2nd 1.851:1
3rd 1.000:1
Rev 4.531:1
T-Case Ratio is 2.46:1 for.
the 4.88:1 will make a difference by improving Top Speed or Reducing Engine RPM at the same Speed, improving FE.
To Compensate for the Higher Diff-Ratio, if you go in for a Low Ratio T90, you will improve its off-road ability, or not Loose to much in 1st & 2nd gear.
http://www.team-bhp.com/forum/4x4-te...ml#post1752537 (Best alternative to the T-90 tranny?)
Arka
Old 16th December 2010, 14:31   #165
gsferrari's Avatar
Thanked: 131 Times
Arka...looks like crawling/climbing is best in Reverse gear
gsferrari is offline   Reply With Quote
The Playstation 2 Thread: Questions, tips, prices etc. Sheruken Gadgets, Computers & Software 320 6th January 2014 17:40
New Civic 1.8V AT. Questions questions... ImmortalZ Sedans 6 12th June 2008 09:49
Stupid questions with the smart answers 2fast2furious Shifting gears 12 23rd August 2004 14:33
Questions about participating in the Speedrun bhp Indian Motorsport 10 23rd July 2004 13:40
Some questions serious ones...? S350L-E240 Technical Stuff 33 7th May 2004 19:59
