Old 24th October 2011, 12:19   #241
Default Re: All questions for CJ 3B
@Fazal sir..which shocks?
@Soumya the part number that u give, is it same as the bolero ones?
docfreak is offline   Reply With Quote
Old 24th October 2011, 13:10   #242
fazalaliadil's Avatar
Thanked: 626 Times
docfreak,
Go for Bolero rear. 8.5", longest extension. I was refering to tail and turn lights for Soumya.
fazalaliadil is offline   Reply With Quote
Old 24th October 2011, 13:54   #243
SPIKE ARRESTOR's Avatar
Thanked: 862 Times
docfreak, sometime back I had given Jaggu a list of Shock Absorber options. Here is the link -
http://www.team-bhp.com/forum/4x4-ve...ml#post2221669 (Got Jeep! CJ3B Hurricane.)
It is the 9th one on the list.
Spike
SPIKE ARRESTOR is offline   (2) Thanks Reply With Quote
Old 24th October 2011, 17:39   #244
Shubz's Avatar
Thanked: 989 Times
Originally Posted by fazalaliadil View Post
Will do the needful, Soumya.
Sir even I need the larger red lens. Totally red without the orange circle at the center. Please let me know if its available.
Shubz is offline   Reply With Quote
Old 24th October 2011, 18:05   #245
Thanked: 626 Times
Shubz,
Will find out if only the lens is available or with the whole unit.
Old 24th October 2011, 18:10   #246
Shubz's Avatar
Thanked: 989 Times
Shubz,
Sure sir. Whole unit is also fine with me. Here is the pic of my existing tail lamp.
Docfreak - Sir - apologies for the hijack attempt!
Old 24th October 2011, 20:52   #247
Thanked: 2,438 Times
As far as water not boiling, i dont know, all i found was that the water level doesnt decrease after even say 100kms , there are no leakages, and THE HOSE IS COLLAPSED WHEN THE JEEP IS ON IDLE AND HOT, when i press the accelarator the hose again becomes normal till the time i rev and then goes back to the collapsed state.
When you rev the engine, what happens to the bottom hose?
The pressure cap OK? Or are you running without one?
Sutripta
Old 24th October 2011, 22:05   #248
Jaggu's Avatar
Thanked: 8,858 Times
This is not right? Is it? Something amiss in your water circulation circuit, me feels. Have you tried with the cap off, does this happen then also?
Originally Posted by SPIKE ARRESTOR View Post
Yup DwArF is running with these on all four wheels, i found them quite comfy but offering best travel on a stock CJ.
Old 24th October 2011, 22:16   #249
bblost's Avatar
Thanked: 7,010 Times
The fan blades dont bend, distance i shall measure.
The radiator is a copper 4 core, good one.
MOsquite grill is off
As far as water not boiling, i dont know, all i found was that the water level doesnt decrease after even say 100kms , there are no leakages, and THE HOSE IS COLLAPSED WHEN THE JEEP IS ON IDLE AND HOT, when i press the accelarator the hose again becomes normal till the time i rev and then goes back to the collapsed state. This happens only when the temp shows >100 consistently for some time.
You might want to read: http://www.team-bhp.com/forum/techni...blem-jeep.html if not already done so.
Old 26th October 2011, 13:29   #250
@ sutripta : i am running with a pressure cap, which fits snug and came with the radiator. The radiator itself is less than 6 months old. The bottom hose remains okay.
This issue is irking me and now the carb also is playing up, leaking fuel from the butterfly....At times i get so frustrated. Why cant the whole thing just work without a niggle for say 6 months at a go.
Old 26th October 2011, 14:29   #251
This is perplexing. I'd say your pressure cap is not working properly. Or your overflow tank (if you have one) is sealed tight.
Does the hose 'un'collapse itself if the pressure cap is removed. (Be very careful when doing it on a hot engine)
If the throttle spindle bore is worn out, it leaks air. Making it impossible to set proper idle. There used to be old time 'experts' who would remachine the carb. Wasn't necessary. All you needed was a new throttle spindle and two sealing washers.
If fuel is leaking out, it means fuel is being dumped on top of a closed throttle. Investigate from where. High chances it is from the bottom of the main fuel post. (The brass post into which you drop the emulsion tube, and screw in the air correction jet.) Which means somebody sometime had removed it. Is yours a proper M34 or a M32 converted to Jeep use?
It did. When new.
It's an (old) Jeep thing.
Sutripta
Sutripta is offline   (1) Thanks Reply With Quote
Old 26th October 2011, 17:46   #252
my overflow tank is perhaps sealed tight, as it never worked after installation. as in the radiator doesnt suck out and coolant from it even when empty, my mech says its due to absence of a thermostat.
The carb is a M34(jeep intended)
i didnt get what u explained about the spindle.
can u pls pm me ur number. i will surely disturb u.
thanks
sharat
Old 26th October 2011, 20:54   #253
There you go.
No.
How mechanically inclined/ adept are you?
Done.
thanks
sharat
Sutripta
Old 27th October 2011, 13:55   #254
Jaggu's Avatar
There will be an opening at the overflow tank cap, see if its open. It should be.
Carb leak- Are you running electric pump, then connect a return line. With mechanical pump also a return line will help avoid leaks and give you slightly better FE.
Old 27th October 2011, 17:29   #255
A return line essentially helps against vapour lock. Running two pumps in series, and then bleeding back pressure does not make sense to me. Though I know that is what is done!
The original Jeep Solex float vent was in the air horn. So if it overflows massively (float needle has lost control), you are right, fuel will be dumped on the throttle. But well before this happens, the vehicle runs like a pig. Or doesn't run at all.
In fact, inability to maintain float level (and its attendant problems) used to be one of the shortcomings of the Solex when used in extreme conditions on the Jeep. Not a problem in ordinary use.
Sutripta
Sutripta is offline   (2) Thanks Reply With Quote
The Playstation 2 Thread: Questions, tips, prices etc. Sheruken Gadgets, Computers & Software 320 6th January 2014 17:40
New Civic 1.8V AT. Questions questions... ImmortalZ Sedans 6 12th June 2008 09:49
Stupid questions with the smart answers 2fast2furious Shifting gears 12 23rd August 2004 14:33
Questions about participating in the Speedrun bhp Indian Motorsport 10 23rd July 2004 13:40
Some questions serious ones...? S350L-E240 Technical Stuff 33 7th May 2004 19:59
