Old 11th August 2009, 22:03   #16
DKG
DKG's Avatar
Thanked: 361 Times
Another fact CJ3B lovers should note is that while it was originally offered as a option the 43/8 (5.38:1) differential is what goes well with the petrol and is ideal for offroad application. The standard unit had the 4.27:1 ratio unit. Apparently with diesel many cars got switched away from the 5.38
Apart from a little metal tag at a diff case bolt showing 43/8 I believe another way to tell what diff you have is to jackup the rear wheel, bring the air valve to 12 o'clock, mark the main drive shaft wrt pinion housing, rotate the wheel two revolutions and count the revolutions at the pinion. You should get 5.38 if that's what you have or 4.27 if you have the standard unit
The CJ3B fans recommend the 5.38 as an ideal match to the Hurricane. Some have addressed the lower speeds concern with a warn overdrive. Wonder if any of those drives made it to India. BTW the overdrive turns your gearbox into a six speeder from three
There's a very nice article explaining all this in detail at the CJ3B website
DKG is offline   Reply With Quote
Old 12th August 2009, 11:32   #17
Spitfire's Avatar
Thanked: 369 Times
Then M&M stood for Mahindra & Mohammed. How many of you knew that?
Guess where Mohammed went after Partition. He then became the Finance Minister.
Have a look here: Mahindra Corporate
This thread is going to get really confusing.
Spitfire is offline   Reply With Quote
Old 12th August 2009, 12:06   #18
Sabareesh's Avatar
Default Some gyaan on Mahindra
In 1967 Mahindra stretched the CJ3B by 10 inches making a "91" Wheel base JEEP. It was powered by the F4-134 Hurricane engine.
In 1974, Mahindra introduced the B275 International Harvester Co. Tractor engine on the CJ4A and called it the CJ500D.
By 1986, Mahindra designed the MM540 series which were essentially a CJ5 with Peugeot XDP 4.90 engine.
In 1999, Mahindra introduced the MDI3200 (B575) engine on the CJ500D and called it the CL500 & CL550.
In 2004 the MDI 3200TC was introduced on the CL550 which we know as the Mahindra MAJOR. This JEEP is still in production.
Now you can connect the missing links of CJ / CL 340 and Classic on this data.
Sabareesh is offline   (1) Thanks Reply With Quote
Old 12th August 2009, 12:20   #19
trammway's Avatar
Thanked: 32 Times
In 1967 Mahindra stretched the CJ3B by 10 inches making a "91" Wheel base JEEP. It was powered by the F4-134 Hurricane engine. (Nope This one was still 81 wheel base with RHD SWB Untill 1974 all of them were SWB 81" wheel base CJ3B models)
By 1990 Mahindra introduced XDP 4.90 engine into SWB CJ340 with the same CJ3B differential ratio
In 1996 Mahindra introduced Mahindra Classic aka. CL340 DP - Classic with first power assisted disc breaks for Jeeps in India and the differential ratio of MM540 and XDP 4.90 engine. This Jeep was considered a fine tuned version of all SWB
trammway is offline   Reply With Quote
Old 12th August 2009, 12:26   #20
Sabareesh's Avatar
If I am not mistaken, Mahindra had a Stretched 3B (CJ4A) with the hurricane engine as well. I am sure CJ500D was not the first 91 Wheelbase jeep from their stable. Were the CJ3B and CJ4A sold side by side from 1967 - 1974 ? When did the production of CJ3B with Hurricane engine stop ?
Someone please put some gyaan on this.
Sabareesh is offline   Reply With Quote
Old 12th August 2009, 13:07   #21
harjeev's Avatar
Thanked: 27 Times
I have a 1985 RHD CJ3B so I know it din't stop till that year and I have for sure seen 1988 model's CJ3B's in Mayapuri!!!
harjeev is offline   Reply With Quote
Old 12th August 2009, 14:27   #22
Sabareesh's Avatar
Those were for the Army, I think Mahindra produced CJ3Bs for the army till 90's. When did the production of CJ3B stop for Civilians ?
Old 12th August 2009, 15:17   #23
Torque-ative's Avatar
No no no, the CJ3B was stopped in 1968, along with Willys. After that Mahindra made CJ3B clones with international 3+1 engine, I am not too sure about this era. I don't think Hurricanes were made after 1968.
Which engine was fitted in the rare MM440,..was it not the hurricane petrol.
Arka's petrol CJ3B was a 1985 IIRC,..and this had the Hurrican petrol too.
Jammy Where art thou !!?
Torque-ative is offline   Reply With Quote
Old 12th August 2009, 15:33   #24
Samurai's Avatar
Thanked: 1,159 Times
Wapedia - Wiki: Willys Hurricane engine
Willys stopped making it in 1971. Did Mahindra continue to make it under license?
Old 12th August 2009, 15:46   #25
Sabareesh's Avatar
Mahindra continued to make CJ3Bs for the Indian Army till 1990s as they had the license from Chrysler. Since Arka's and Harjeev's JEEP are army disposals, they have the hurricane engine. The question that we have now is "When did Mahindra stop manufacturing CJ3Bs for the CIVILIAN MARKET in india ???"
They made it for the Army till 90s, I am not sure about Civilian models. Behram Sir, Arka, Jammy we need your inputs on this.
Help please.
Old 12th August 2009, 16:01   #26
joshguy's Avatar
Default confusion becoming more complicated
Hi Guys this thread has confused me.
I knew models MM 440,540,550 ,but never knew the differences in them. now what is this CJ3B & CL340 CJ340? are they different from MM 440,540,550 ?
What is the jeep used by COPs?
Am a lay man in this topic please explain in plain words rather that using sophisticated techie languages
joshguy is offline   Reply With Quote
Old 12th August 2009, 19:26   #27
harjeev's Avatar
Thanked: 27 Times
I think that the ones used by the cops should be CL500's or also known as the Major!!!
And CJ3B, CL340 and CJ340 are SWB jeeps whereas the Mm440 (petrol) MM540 & MM550 are LWB!!!
No I am talking with my limited knowledge so other will have to verify what Ive written???
But I think that we have deviated from the basic topic of the thread here which was
What are the mechanical differences in the CJ/CL 340 and the CJ3B!!! Leaving aside the engine
And will the Mahindra Workshops or specifically Mahindra Company owned workshop will be able to overhaul/ service the CJ3B's as its possible that the mechanics who now working there might have never worked on petrol engines???
Old 13th August 2009, 20:04   #28
joshguy's Avatar
thanks harjeev ,but am still confused
Old 14th August 2009, 10:45   #29
trammway's Avatar
Thanked: 32 Times
Ok here is my answer to your query. Some of the data may wrong as I consolidated from the internet after a long crawl.
The following models from Willys, Ford and Mahindra are called SWB (Short Wheel base i.e. 81inches wheel base)
1. Willys MA (Godevil L-Head 134 4 Cylinder 60bhp / 3spd T90 gearbox with T18 2 lever transfer case)
2. Willys MB (Godevil L-Head 134 4 Cylinder 60bhp / 3spd T90 gearbox with T18 2 lever transfer case)
3. Ford GPW (Godevil L-Head 134 4 Cylinder 60bhp / 3spd T90 gearbox with T18 2 lever transfer case)
4. Willy CJ2A (Godevil L-Head 134 4 Cylinder 60bhp / 3spd T90 gearbox with T18 2 lever transfer case)
5. Willys CJ3A (Godevil L-Head 134 4 Cylinder 60bhp / 3spd T90 gearbox with T18 2 2 lever lever transfer case)
6. Willys M38 (Godevil L-Head 134 4 Cylinder 60bhp / 3spd T90 gearbox with T18 2 lever transfer case)
7. Willys CJ3B (Hurricane F-Head 134 4 Cylinder 72bhp / 3spd T90 gearbox with T18 2 lever transfer case)
8. Willys CJ4 (Hurricane F-Head 134 4 Cylinder 72bhp / 3spd T90 gearbox with T18 2 lever transfer case) - only one jeep was made under this name and sold to factory employee, so don't search for this model
7. Mahindra CJ3B (Hurricane F-Head 134 4 Cylinder 72bhp / 3spd T90 gearbox with T18 2 lever transfer case)
8. Kaiser CJ5 (Hurricane F-Head 134 4 Cylinder 72bhp / 3spd T90 gearbox with T18 2 lever transfer case)
9. Mahindra CJ340 (Peugeot XDP 4.90 2112cc 4 Cylinder 62bhp / 4spd KMT90 gearbox with T18 2 lever transfer case)
10. Mahindra CL340 DP (Peugeot XDP 4.90 2112cc 4 Cylinder 62bhp / 4spd KMT90 gearbox with T18 2 lever transfer case)
11. Mahindra CL340 DP -Classic (Peugeot XDP 4.90 2112cc 4 Cylinder 62bhp / 4spd KMT90 gearbox with T18 single lever transfer case)
The following models Mahindra are called MWB (Medium Wheel base i.e.91inches wheel base)
1. CJ4A (Hurricane F-Head 134 4 Cylinder 72bhp / 3spd T90 gearbox with T18 2 lever transfer case)
2. CJ500D (International Harvester B275 2350CC 38BHP / 3spd T90 gearbox with T18 2 lever transfer case)
3. MM440 (Hurricane F-Head 134 4 Cylinder 72bhp / 3spd T90 gearbox with T18 2 lever transfer case)
4. MM540 DP (Peugeot XDP 4.90 2112cc 4 Cylinder 62bhp / 4spd KMT90 gearbox with T18 2 lever transfer case)
5. MM540 XD (Peugeot XD3P 4 Cylinder 2456CC 72BHP/ 4spd KMT90 gearbox with T18 single lever transfer case)
6. MM550 ISZ - ([COLOR=black]1.8L Isuzu PETROL ENGINE / [/COLOR]5 spd BA10 with borgwarner single lever transfer case))
7. MM550 XDB (Peugeot XD3P 4 Cylinder 2456CC 72 / 5 spd BA10 with borgwarner single lever transfer case)
8. MM550 XD (Peugeot XD3P 4 Cylinder 2456CC 72-76BHP / 4spd KMT90 gearbox with T18 single lever transfer case)
9. CJ500DI - (International Engine aka. MDI3000 ????? )
10. CL500 MDI /CL550 MDI - (International Harvester B575 2650cc 59BHP / 5spd BA10 gearbox with borgwarner single lever or Electric transfer case)
11. CL550DI TC - (MDI 3200TC 2650cc 68BHP / 5spd BA10 / NGT520 gearbox with borgwarner single lever or Electric transfer case)
Old 14th August 2009, 10:55   #30
svsantosh's Avatar
Thanked: 184 Times
Question
Engine - Made by M&M (Designed by Peugeot and licensed to M&M)
Gearbox - Who made this? What is KMT?
Transfer case - Who made this? dana, spice, dana-spicer, M&M, BorgWarner?
Edit -
The CJ3B Axles had the famous Dana/spicer axles right? Who made the axles on the CJ340? Are they same as the CJ3B ones? Or did M&M make new ones for a diesel engined SWB?
svsantosh is offline   Reply With Quote
1990 M&M Cj340 svsantosh 4x4 Vehicles 508 18th April 2012 19:15
Differences between Army & Civilian Versions Live To Jive 4x4 Vehicles 38 13th October 2010 11:16
Mechanical fuel pump for Hurricane Motor (CJ3B) diesel_maniac 4x4 Technical 14 19th April 2010 03:30
'59 CJ3B with XDP 4.90: Mechanical lessons underway - Phase 1 Red Liner 4x4 Vehicles 10 7th January 2010 07:56
A Pajero, Gypsies, CJ3B, Classic & MM540 go off-roading, stream crossings & cooking khan_sultan 4x4 Excursions 38 10th December 2008 02:52
Copyright ©2000 - 2012, Team-BHP.com
