Old 16th July 2014, 23:42   #91
desertfox's Avatar
Thanked: 527 Times
Default Re: A Winch Test
These winches are not designed for heavy prolonged use.
It is to pull out a stuck vehicle only. And in every case the stuck vehicle must assist with its own vehicle power, forward or backward as per case to get free.
These chinese winches will heat to the higher temperature ranges, definetely in about three to four minutes of use they get to 80 Deg C or even higher.
desertfox is offline   Reply With Quote
Old 2nd October 2017, 09:48   #92
Thanked: 7 Times
Got couple of heavy duty towing equipment from Stellas Intertraders. The address provided here: https://www.team-bhp.com/forum/4x4-t...4x4-india.html
4.75T capacity D-Shackles. It is really huge, compare it with the 5 rupee coin.
Attachment 404344
5T capacity tow strap.
Attachment 404345
Most of us generally use 3T shackles and tow straps. Here is a color code guide for the tow straps.
Attachment 404346
Hi is that a kinetic strap? Do we use Kinetic straps for recovery or tow straps? I was told tow straps are dangerous for recovery points.
Mosalf is offline   Reply With Quote
Old 2nd October 2017, 21:55   #93
Samurai's Avatar
Thanked: 14,530 Times
No, it was not a kinetic strap. Tow straps are cheaper, and it should not be jerked while towing.
Bed for Electric Winch For Safari jyobeb Modifications & Accessories 7 20th March 2007 14:12
For Sale : 12000lbs Electric Winch for JEEPs & 4WDs ex670c Shifting gears 2 13th March 2007 16:29
Motorized Winch and Jerry can fitment for mahindra classic moodswings Modifications & Accessories 5 23rd August 2006 22:18
Looking for a Winch for My Jeep CJ3B RAINMAKER Shifting gears 3 10th February 2005 18:37
