Old 24th September 2009, 23:26   #16
Brutus's Avatar
Thanked: 45 Times
The problem with modern T-cases is that they all look the same except for some minute differences. the Toy t-case above is not the same as in the picture, although it might look the same. The main give away is that beboy's xfer-case has a front face shift (lever type), whereas the toy one posted has a top shift,much like a transmission gearshift.
Also if it has a right side front output, then it should also have a PTO plate on top of it.
If you could move the input wheel by hand, then could you please see what kind of revolutions are you getting in the input for each output revolution, both in high and low modes. The kind of ratios you get can help us find some clues to what vehicle it might belong to.
Brutus is offline   Reply With Quote
Old 25th September 2009, 00:07   #17
star_aqua's Avatar
Thanked: 89 Times
This is off a vehicle with differential offset to left. hence this can be one of the clues to narrow down the search.
star_aqua is offline   Reply With Quote
Old 25th September 2009, 11:56   #18
Brutus's Avatar
Thanked: 45 Times
Too many Variables, pal. There are loads of Xfer-cases out there with both side outputs. And the center rear output is something that has become universal now, especially since all the vehicles now come with independent suspension systems.
All i know is that it ain't any of the American makes, i mean it atleast does'nt look like any of them. That leaves us mostly German makes, or even better chances are of the Japanese makes, since their vehicle's powertrain is what mostly comes to India.
Fraud Transfer of Money from my Salary Account of PNB: Fought case & won ddriver Shifting gears 148 11th February 2015 13:05
Divorced Transfer Case conversion: T-18 or Borg Warner Sudarshan 4x4 Technical 4 9th March 2013 13:47
high and low ratios of the Fortuner transfer case? Harbir 4x4 Technical 1 29th August 2011 17:19
Gypsy Transfer Case Needed xavier.brittt 4x4 Technical 4 18th February 2011 13:41
Cant identify this transfer case whicked wheels 4x4 Technical 4 6th June 2010 23:14
