Old 23rd September 2009, 13:16   #1
Thanked: 655 Times
Default Divorced transfer case identification
Can anybody identify this divorced transfer case for me? It has no plate and has no stamped identification. It is a 2 lever type and is in good condition. It has an aluminium alloy body.
jyobeb is offline   Reply With Quote
Old 23rd September 2009, 17:58   #2
Thanked: 294 Times
I think it is 4WD drive case.
Old 23rd September 2009, 18:47   #3
Thanked: 655 Times
Brother, that is why it is in the 4WD section. This is a divorced type 4wd transfer case. The question is "what make and off what vehicle?"
Old 23rd September 2009, 19:15   #4
prabhuav's Avatar
Thanked: 112 Times
It is possibly a toyota
You sell?? I want
prabhuav is offline   Reply With Quote
Old 23rd September 2009, 19:20   #5
svsantosh's Avatar
Thanked: 1,444 Times
I dont know what were you thinking, but it was fun. Seriously innocence was there in your line.
jyobeb - could it be a TATA's?
svsantosh is offline   Reply With Quote
Old 23rd September 2009, 20:31   #6
ampere's Avatar
Thanked: 9,122 Times
New to this jargon. Can some one explain what is a divorced transfer case?
Old 24th September 2009, 10:29   #7
ex670c's Avatar
Thanked: 1,821 Times
Default Divorced T-Case.
Hi Beboy,
My Guess is transfer case belongs to a Toyota Land Cruiser.
Its not a TATA, as I have a 407 T-Case and the Tata designs are Styer-Oerlikon Type. (TMB & 407 have similar shift pattern 2H-4L)
What is a Divorced Transfer Case?
The T-Case is connected to the Main Gearbox by a propeller shaft.
This is a feature mainly is useful for Trucks above 1.5Ton Payload, as the Gearbox Mounts don't have to carry the additional weight of the T-Case.
Also allows for great flexibility in engine options, and retain 4WD system.
Dwarka can add the details here.
The following vehicles in INDIA use Divorced T-Case.
1) Maruti Gypsy
2) Trax Gurkha/4WD
3) Tata Mercedes Benz (TMB)
4) Tata LPTA Series 713
5) Ashok Leyland Stallion (ALS)
6) Shaktiman aka MAN630A
7) Tata 407
8) Swaraj 4WD (3500T)
9) Kraz 255b/260b
These are all I can think of Bikram Sandhu, can surely add more details.
Arka
Old 24th September 2009, 11:09   #8
vinod_nookala's Avatar
Thanked: 416 Times
Jyobeb & Arka,
How did you identify this to be a divorced transfer case? Can you guys eloberate for the benefit of one and all?
vinod_nookala is offline   Reply With Quote
Old 24th September 2009, 12:02   #9
Thanked: 655 Times
A divorced transfer case is separate from the gearbox (Gypsy) and not bolted on (TATA & Mahindra/ part of the casting(ISUZU)
Old 24th September 2009, 12:15   #10
Thanked: 416 Times
Does any one have the picture of under chassis of the Trax Gurkha? Will make things clear. Arka said the connection between the gear box and the T/C is through a shaft. I want to see that.
Old 24th September 2009, 12:24   #11
Gypsy-Boy's Avatar
As a addendum to Arka's post ...
A transfer case is the "second" gear box in 4X4 vehicles like the gypsy.
This does the duty of transferring power to the 2W and 4W drive
and also regulates the low and high gearing.
In some 4X4 vehicles this is incorporated into the gear box itself.
While some others have a separate T-case.
GB
Gypsy-Boy is offline   Reply With Quote
Old 24th September 2009, 12:54   #12
trammway's Avatar
Thanked: 220 Times
I've no idea too about the transfer case in question.
Just to clarify Vinod, here is the picture of divorced transfer case in Shaktiman recovery truck. See the arrow mark showing drive shaft that runs from main gear box to this transfer case.
trammway is offline   Reply With Quote
Old 24th September 2009, 13:48   #13
Thanked: 416 Times
Ah, now i got it...thanks siva:-)) Was thinking too complicated...i realised i know this heheh:-))
Old 24th September 2009, 16:10   #14
Brutus's Avatar
Thanked: 45 Times
I have a Trax Xfer case picture, but it doesn't look like that at all, besides the trax unit has a yoke output, not a flange one, and its got a right side front output, not a left one, with the PTO plate under the xfercase.
There are'nt many smaller xfercases with a pto output, and Toyota, ever since they moved to divorced units, mostly use heavyduty cases, but that does'nt mean this may not be a Toyota unit. Infact in all possibility it could be one, coz there are just so many different models used around the globe. Whats the physical size of the case??
Last edited by Brutus : 24th September 2009 at 16:13. Reason: left out a few things
Brutus is offline   Reply With Quote
Old 24th September 2009, 21:28   #15
JeepCaptain's Avatar
Thanked: 468 Times
Default Looks like Toyota Tcase
Hi jyobeb,
I think Arka is right .I did a google search and found this pic. The pic resembles the T-case you have shown.
Click on the link below and you will find more details
"OTT INDUSTRIES DIVORCED TOYOTA TRANSFERCASE"
OTT ALWAYS A SOLID CHOICE !!! --
JC
JeepCaptain is offline   Reply With Quote
Fraud Transfer of Money from my Salary Account of PNB: Fought case & won ddriver Shifting gears 148 11th February 2015 13:05
Divorced Transfer Case conversion: T-18 or Borg Warner Sudarshan 4x4 Technical 4 9th March 2013 13:47
high and low ratios of the Fortuner transfer case? Harbir 4x4 Technical 1 29th August 2011 17:19
Gypsy Transfer Case Needed xavier.brittt 4x4 Technical 4 18th February 2011 13:41
Cant identify this transfer case whicked wheels 4x4 Technical 4 6th June 2010 23:14
