Old 30th December 2010, 21:17   #16
jeepster's Avatar
Thanked: 984 Times
Default Re: Mahindra Transfer Cases
Name:  bw_1350_transfer_case Small.jpg
BW 1350
Manufacturer: Borg Warner
Number of speeds: Two
High: 1:1
Low: 2.48:1
Case (or housing) material: Aluminum
Front output drive type: Chain (driver side drop)
Availability or aftermarket parts and support: Low
Rear yoke: Fixed
Planetary gear: Yes
Shifter type: Mechanical or electrical
Found in: '83-to-'93 Ford Ranger, '84-to-'90 Bronco II &
Explorer
is it possible to convert the electric shift to manual one?
jeepster is offline   Reply With Quote
Old 2nd January 2011, 20:02   #17
4x4addict's Avatar
Thanked: 2,513 Times
@jeepster:
The Thar has the BW T-Case with manual shifter. You can get the part numbers for Thar to convert.
4x4addict is offline   Reply With Quote
Old 12th February 2011, 12:54   #18
SPIKE ARRESTOR's Avatar
Thanked: 757 Times
^^ Tini, how do you plan to do that?
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 13th February 2011, 15:28   #19
4x4addict's Avatar
@spike. I didn't mean to convert an electric transfer case to a manual shifter. I meant swap the whole transfer case from electric to manual.
Old 13th February 2011, 18:21   #20
Thanked: 757 Times
Oh Ok, understood. Conversion (Electric to Mechanical) is not recommended for reliability reasons.
Spike
Old 30th August 2011, 11:34   #21
Thanked: 61 Times
Folks, my Armada Grand electronic 4x4 is no longer working. After shuttling 2-3 Mahindra workshops, a senior tech at India Garage finally tells me this is a ECU problem and that they do not have a spare to swap and check. More so its too expensive (20k+) to replace (and they do not have it available). I am keen to know few things
1. Can the ECM be dismantled and repaired by any auto-electrician ?
2. Any ECM available in the market, cheaper that keeps it going ??
3. How do i convert to manual (BA-10) with out spending a bomb (keen to know if a part from the Thar TC can be adapted) ?
charan is offline   Reply With Quote
Old 30th August 2011, 17:29   #22
jeepster's Avatar
Thanked: 984 Times
  • just like PC motherboards the ECM can be repaired but not many can do this. (depends on the part availability)
  • i dont know if we can buy a new custom ECM.
  • buy a manual borg warner, its shifter mechanism & install in your armada.
rgds,
Nikhil
BTW there is one manual borg warner + KMT90 for sell in Delhi.
Old 30th August 2011, 19:50   #23
headers's Avatar
Thanked: 457 Times
PM the BODA guys - There is a guy by name ramesh in bangalore who repairs ECUs. His charges are reasonable!!
Old 1st September 2011, 17:57   #24
swastikviji's Avatar
Thanked: 158 Times
Hi Vikram, I can give you ramesh number, as you mentioned he is reasonable, my only question how come a ECU in a armada grand, I am thinking Mahindra started using ECU only in Scorpio and bolero series,
swastikviji is offline   (1) Thanks Reply With Quote
Old 4th September 2011, 18:10   #25
sreejeshmp's Avatar
Thanked: 571 Times
Can anyone tell me Which Gearbox and transfer case came on the Mahindra Marshal Economy 4WD ?
sreejeshmp is offline   Reply With Quote
Old 4th September 2011, 18:21   #26
jeepster's Avatar
Thanked: 984 Times
All Electric shift Borgwarners have a ECU.
its for actuating the high & low ratios by Electro-magnetic coils.
it must be KMT90+T18 combination.
Old 4th September 2011, 20:33   #27
sreejeshmp's Avatar
Thanked: 571 Times
one 5 speed gearbox is for sale the dealer told me its a 5 speed gearbox with 4wd transfer case and it from Mahindra Marshal Economy. Do you know any M&M vehicle comes with 5 speed gearbox with manual BorgWarner transfer case (Except thar CRDe) ?
- Sreejesh
Old 4th September 2011, 20:56   #28
jeepster's Avatar
Thanked: 984 Times
- Sreejesh
IFAIK
Armada
  • KMT90 + BW Manual (i have lt )
Armada Grand
  • BA10 + BW Electric
Bolero
  • NGT520 + BW Electric
Scorpio
  • NGT530 + BW Electric
Sree and I had a lengthy discussion on the Transfer Cases. We compared some pictures of Sree's MM550 XDB Transmission/T-case along with Beboy's set and my own and this is what I have concluded/guessed. Experts please add your comments.
As far as I understand these are the transmission/transfer case combination Mahindra made.
1) Three Speed Gearbox with T-18 T-Case with twin levers.
2) Four Speed KMT90 with T-18 T-Case with twin levers.
3) Four Speed KMT90 with T-18 T-Case with single lever and U shaped shift pattern. Most common on recent MM540/MM550s
4)BA10 with Electric/Mechanical Borg Warner T-case. Used in Armada Grand and earlier Boleros.
5)BA10 with T-18 Transfer Case with single lever and straight line shift pattern. Used in MM550 XDB.
6)NGT530 with Electric Borg Warner T-Case. Scorpio 4WD/Newer Bolero 4WD and Camper 4WD.
7)NGT520 with T-18 Transfer Case with single lever and straight line shift. Used in Legend/Major/Invader/Bolero DI 4WD.
8)NGT530 with T-18 Transfer Case with single lever and straight line shift. Used in Thar (Guess).
the best person to answer is Spike.
rgds,
Nikhil
EDIT
ask the dealer if the TC is aluminum or cast iron.
or rear prop. shaft out put.
if its aluminum with with rear out put in line with GB then its BW.
if its iron & rear out put is in line with front out pout, then its t18.
jeepster is offline   (2) Thanks Reply With Quote
Old 5th September 2011, 10:16   #29
jeepster's Avatar
Thanked: 984 Times
a small correction.
there is motor for a actuating the high & low ratios.
& a Electro-magnetic coil is used to actuate the clutch in the Transfer case. (one used for ON FLY change from 4x2 to 4x4high without stopping the vehicle )
the ECU monitor's & control's following.
  • Shift motor
  • Synchronizer Clutch (the one explained above)
  • Speed Sensor
  • Selector Switch
  • Motor Position Switch
rgds,
Nikhil
thanks Raju bhai (Sudarshan vaidya) for the correction.
BTW conversion from electric to manual is not recommended for BorgWarner.
jeepster is offline   (1) Thanks Reply With Quote
Old 5th September 2011, 13:26   #30
headers's Avatar
Thanked: 457 Times
Why, I'm told the electric is not as positive as the manual one and failure rates are high!!
If above statement is not TRUE, then why did the THAR come with manual TC?
Curious cases of unethical dealerships Zappo Indian Car Dealerships 10 2nd March 2008 13:23
New traffic drive, 763 cases in four hours dadu Street Experiences 23 15th November 2007 11:05
