Old 20th November 2009, 14:26   #1
siddartha's Avatar
Thanked: 24 Times
saw this on a mahindra jeep used for lifting submersible pump sets.
Last edited by bblost : 20th November 2009 at 14:41. Reason: back 2 back posts, use edit when posting within 20 mins. Thanks.
siddartha is offline   Reply With Quote
Old 20th November 2009, 14:38   #2
Sha
Sha's Avatar
So what idea is runing in the mind siddu.
Sha is offline   Reply With Quote
Old 20th November 2009, 15:47   #3
siddartha's Avatar
Thanked: 24 Times
maybe the jeepers can use this idea , seems like a very cheap alternative to the hi lift jack.
Old 20th November 2009, 19:18   #4
svsantosh's Avatar
Thanked: 1,444 Times
You bet... What better than a built in, theft free - HLJ. But, its only for your jeep and can help NONE else!!!. Let me research more into it
svsantosh is offline   Reply With Quote
Old 20th November 2009, 19:34   #5
Sankar's Avatar
Thanked: 4,656 Times
This can be found on similar rigs used for borewell jobs. Ones that do drilling have four such jacks on all ends, used to stabilise the rig. This particular jeep must have atleast two similar jacks on its rear.
Old 20th November 2009, 20:06   #6
ksethuram's Avatar
Well it will stay on until it is mechanically operated. If you fit in a motorised hydraulic operated pump i am sure it will be nicked sooner or later.
I especially like the part of "its only for your jeep and can help NONE else!!!"..
ksethuram is offline   Reply With Quote
Old 20th November 2009, 21:13   #7
trammway's Avatar
Thanked: 220 Times
With this kind of setup not only the jeep installed can only use, also it can lift the only the place it is fitted. Hence leaving us offroader no use with it.
The hi-lift jack comes handy in any situation and the applications are wider and you can lift most part of the jeep.
trammway is offline   Reply With Quote
Helmet Visor Screw Lost! Cant Find a new one rahulsingh007 Ride Safe 14 27th December 2017 13:08
Weird Problem after Spoiler install. Screw stuck in the trunk lid aseem Technical Stuff 12 31st January 2012 12:06
RE Classic 500 - A screw that ripped my engine case siddharth_menon Motorbikes 30 20th January 2012 12:36
Air screw adjustment on carb zen gopa99 Technical Stuff 6 30th June 2009 20:06
shogun's air screw setting Rice_tuner Motorbikes 4 18th September 2005 13:07
