Old 24th November 2009, 11:01   #16
Thanked: 4,673 Times
Dear all - yes, that's Sudhir Kashyap. We went "somewhere" sometime back. You can see the date in the photograph. And yes, the Scorpio climbed upto this point in 4WD low but we had to use the winch to come down as the angle was quite steep, not as much as seen in the photograph but still steep. It took us 30 minutes just to come down. You can see it being winched down. By the way, what do you see inside the rear door?
Best regards,
Behram Dhabhar
DHABHAR.BEHRAM is offline   Reply With Quote
Old 24th November 2009, 11:19   #17
fk7
fk7's Avatar
Thanked: 134 Times
Dear all - By the way, what do you see inside the rear door?
Best regards,
Behram Dhabhar
Hi Sir,
Let me guess, its a roll bar/cage.
Am I right?
firoz
fk7 is offline   Reply With Quote
Old 24th November 2009, 11:19   #18
vinod_nookala's Avatar
Thanked: 411 Times
Default Whats behind?
Best regards,
Behram Dhabhar
I certainly dont see rear seats in there. Vehicle is a little lowered as if there is something heavy behind, no, rear is not articulating. The question is what was being carried in scorpio rear??
Pic is not clear, since you have asked question...you can reveal the answer as well.
vinod_nookala is offline   Reply With Quote
Old 24th November 2009, 11:23   #19
Thanked: 411 Times
Default awaiting review
Originally Posted by DirtyDan View Post
Arka, would you believe this thing actually has a large steel bumper, no cladding?
As mentioned above you can cut the old original or remove the old and fabricate a new heavy one that will be welded to the two chassis rails. A good welder will make a weld that will bear up under the load of the winch. You will have to deal with adding signal lights somewhere/somehow. Not a big problem. You could also add tow hooks to this.
The other option is to cut the top center portion of the old bumper and fit a plate across the two chassis rails.
, DD, we are awaitng your long awaited new invader 4wd review. Further, those OE tyres are pathetic! Even Major 4wd gets NDMS 600-16 wonder what makes Mahindra treat Invader 4wd like this!
Old 26th November 2009, 11:30   #20
deutscheafrikar's Avatar
Thanked: 317 Times
Found this pic on the Internet. Maybe it will help you get some ideas.
deutscheafrikar is offline   Reply With Quote
Old 26th November 2009, 13:04   #21
4x4addict's Avatar
Thanked: 2,513 Times
from an initial look this installation is suspect as the bull bar seems to be holding the weight of the winch and the pressure when it is used. But, I suppose we can't be sure until we see how well the bull bar is attached to the frame.
4x4addict is offline   Reply With Quote
Old 30th November 2009, 00:57   #22
whicked wheels's Avatar
Thanked: 56 Times
Here are some pics which may help you out to fabricate your own bumper.
whicked wheels is offline   Reply With Quote
Old 30th November 2009, 11:15   #23
Thanked: 18 Times
dear all,
Thank you so much for all the info.right now waiting for the winch to come.will post photos of the installation as soon as we start.
cheers
rallystar is offline   Reply With Quote
Old 28th July 2010, 09:57   #24
Thanked: 18 Times
Hi guys,
finally got the winch installed.Vincy installed the winch in about 4 days.let me know your comments.
cheers
Old 28th July 2010, 10:10   #25
Samurai's Avatar
Thanked: 14,537 Times
Wow, very clean install. What is it sitting on? Is that a Ramsey, why you went for 6000lbs?
Old 28th July 2010, 10:12   #26
n.devdath's Avatar
Thanked: 1,740 Times
Rallystar: Thats a neat fit and a nice winch too. I was looking at fitting at one on my Scorpio as well.
Where did you get it from and what was the total cost of the same? It would be great if you could share the breakup as well.
@Swastikviji: Can you please tell me if it is possible to get that "winch mounting" somewhere at Blore or recommend a good fabricator so that I need not cut the bumper to install it.
Old 28th July 2010, 14:37   #27
IronWolf's Avatar
Thanked: 36 Times
Very neat and clean install. How about some WIP pics and details on the setup.
IronWolf is offline   Reply With Quote
Old 28th July 2010, 17:41   #28
karizma9292's Avatar
Thanked: 209 Times
Now thats a very clean custom installation of the winch . The winch is popping out of the vehicle , is'nt a guard neccessary to protect it (i do not know just asking)
karizma9292 is offline   Reply With Quote
Old 28th July 2010, 23:25   #29
swastikviji's Avatar
Thanked: 158 Times
Let Me Know Make Model of the winch, i will Ask My fabricator,
swastikviji is offline   Reply With Quote
Old 29th July 2010, 01:34   #30
DirtyDan's Avatar
Thanked: 747 Times
Exactly my thoughts. I think it would be wise not to lead with your winch. If I decide to put a winch on my Invader I will put some substantial steel in front of it so that my winch is not what makes first contact with an obstacle encountered from the front. I have also seen many vehicles leading with with their off-road lights. Lights and winches do not make good bumpers.
Tata 4 x 4 with winch 8500 lb ( Telcoline Turbo ) Nandyk Shifting gears 11 29th February 2008 11:34
Bed for Electric Winch For Safari jyobeb Modifications & Accessories 7 20th March 2007 14:12
For Sale : 12000lbs Electric Winch for JEEPs & 4WDs ex670c Shifting gears 2 13th March 2007 16:29
Motorized Winch and Jerry can fitment for mahindra classic moodswings Modifications & Accessories 5 23rd August 2006 22:18
Looking for a Winch for My Jeep CJ3B RAINMAKER Shifting gears 3 10th February 2005 18:37
