Old 20th November 2009, 15:56   #1
Thanked: 18 Times
Default INVADER winch installation
Hi guys,
Need help in installing a ramsey winch on INVADER.Problem is the bumper and how to mount on it. At last years Great Escape I had seen an INVADER with a custom fabricated bumper which was increased in width to accomodate the winch. I think this was a factory vehicle . Also need to mount a spade and a high lift jack.suggestions welcome. Invader already has A.C. and power steering.
cheers
rallystar is offline   Reply With Quote
Old 20th November 2009, 15:59   #2
Samurai's Avatar
Thanked: 14,541 Times
This year I installed Ramsey winch my Jeep, it involved quite bit of research and experimentation.
How about posting the image of the front portion of your Invader.
Old 21st November 2009, 09:08   #3
14000rpm's Avatar
Thanked: 589 Times
Originally Posted by rallystar View Post
Hi guys,
cheers
It definitely needs a winch bumper which will replace the existing bumper. In a CJ series jeep and the MM540, there is a good place for mounting the winch but in a invader, you have to have a winch bumper. It'll help if you post pix of your invader in its current state.
14000rpm is offline   Reply With Quote
Old 21st November 2009, 11:11   #4
ex670c's Avatar
Thanked: 1,799 Times
Default Winch Installation
Hi guys,
cheers
Hi Rallystar,
Remove the Bumper Cladding and the Chassis and Bumper will be visible.
Mount the winch on this and make suitable alteration on the Bumper cladding.
Arka
Old 21st November 2009, 12:09   #5
Thanked: 52 Times
Hi guys,
cheers
You bought a Invader?? Which model of ramsey ?
You'll have to cut the bumper [fabricate it round the mounts].
Remove the bumper , make a mount using a 'C' channel beam section and bolt it to the metal cross member, on this the winch can be mounted, the bumper will be around these section on both sides.
Other option is making a new external bumper out of 5mm steel plate and mount the winch on that, this will look good as well as strength to the setup.
dinar is offline   Reply With Quote
Old 21st November 2009, 12:22   #6
arjunrudra's Avatar
Thanked: 13 Times
You should probably do a proper winch bumper .This is essential to hold the vehicle so that the the bumper does not break when you winch the cehicle.
BTW which winch are you going for?
arjunrudra is offline   Reply With Quote
Old 21st November 2009, 13:53   #7
DirtyDan's Avatar
Thanked: 747 Times
Arka, would you believe this thing actually has a large steel bumper, no cladding?
As mentioned above you can cut the old original or remove the old and fabricate a new heavy one that will be welded to the two chassis rails. A good welder will make a weld that will bear up under the load of the winch. You will have to deal with adding signal lights somewhere/somehow. Not a big problem. You could also add tow hooks to this.
The other option is to cut the top center portion of the old bumper and fit a plate across the two chassis rails.
Old 23rd November 2009, 17:43   #8
Thanked: 4,673 Times
Dear all - fyip
Best regards,
Behram Dhabhar
DHABHAR.BEHRAM is offline   Reply With Quote
Old 23rd November 2009, 20:10   #9
swastikviji's Avatar
Thanked: 158 Times
You Can make a custom winch plate and fix it just like this.
swastikviji is offline   Reply With Quote
Old 23rd November 2009, 22:07   #10
svsantosh's Avatar
Thanked: 1,392 Times
Dear all - fyip
Best regards,
Behram Dhabhar
- WHOA!!
BehramJi - Please tell me the pic has some angle-magic to it!! The Drop behind the Scorpio is ~90' DOWN!!! How in the world did it manage it? Who is inside it?
svsantosh is offline   Reply With Quote
Old 24th November 2009, 01:00   #11
Thanked: 7 Times
Default Camera angle
- WHOA!!
There certainly is a good deal of 'angle-magic' involved. Have a look at the angle of the trees and back-ground in relation to the car, that'll tell you the actual angle.
'72 Bullet is offline   Reply With Quote
Old 24th November 2009, 01:54   #12
drifter's Avatar
Thanked: 13 Times
- WHOA!!
Looks like Mr Sudhir Kashyap to me.
Drifter
drifter is offline   Reply With Quote
Old 24th November 2009, 08:16   #13
Samurai's Avatar
Very sharp eyes drifter, it is indeed Sudhir Kashyap.
In the above image, it is impossible to recover the original angle by rotating the photo, so don't try. It was shot from an angle that cannot be re-oriented.
Offroad photography is not easy since the photos flatten the terrain, so people often twist the camera (often too much) to get some reality. However, after lot of trail and error I have learnt to shoot without twisting the camera, the trick is in finding the right location to shoot. These days you will rarely find a bent tree in my offroad shots.
Old 24th November 2009, 10:37   #14
deepaktpatil's Avatar
Thanked: 75 Times
Santosh,
Have a look at the tree near Scorpios front wheel as Samurai has hinted. That should help you in getting a feel of the angle.
deepaktpatil is offline   Reply With Quote
Old 24th November 2009, 10:41   #15
4x4addict's Avatar
Thanked: 2,513 Times
This is so true. If you were at the Palar OTR on Nov 15th in Chennai, some of the climbs were extremely steep which many jeeps and gypsy's struggling to climb. But in the pictures, I took, it looks like a walk in the park. If you see the pictures, a person would be inclined to think what is the big deal, any maruthi can do that :-).
I am sure this is the case with many OTR pictures where the terrain looks so easy in the photograph but in reality it was a very difficult patch.
4x4addict is offline   Reply With Quote
Tata 4 x 4 with winch 8500 lb ( Telcoline Turbo ) Nandyk Shifting gears 11 29th February 2008 11:34
Bed for Electric Winch For Safari jyobeb Modifications & Accessories 7 20th March 2007 14:12
For Sale : 12000lbs Electric Winch for JEEPs & 4WDs ex670c Shifting gears 2 13th March 2007 16:29
Motorized Winch and Jerry can fitment for mahindra classic moodswings Modifications & Accessories 5 23rd August 2006 22:18
Looking for a Winch for My Jeep CJ3B RAINMAKER Shifting gears 3 10th February 2005 18:37
