Old 5th February 2010, 03:00   #61
star_aqua's Avatar
Thanked: 89 Times
Originally Posted by DirtyDan View Post
Diesels have less engine braking exactly because of their higher compression. The higher compression of a diesel provides far more force to the DOWNSTROKE of the piston than a petrol piston of the same displacement and therefore much more force turns the crankshaft and then the drive shaft etc. than is the case with a petrol engine. What a jake break does is let the air out of the balloon, let the air out of the DOWNSTROKE by venting it out the exhaust valves. This takes force away from the crankshaft and hence the rest of the vehicle. It is the DOWNSTROKE that is the real difference maker in engine braking between diesel and petrol along with the fact that the intake is open on the diesel on the upstroke and closed on the petrol.
I think it is the gearing that makes off-roaders think their diesels brake better than petrols.
Jake brakes were invented to save brakes on heavy vehicles. They might be useful in slowing the free fall of rogue planetoids like the Tata Safari.
DD, lets go according to your explanation. if you consider a petrol engine and a diesel engine of same displacement, diesel has higher compression then petrol. now both work on same principle in terms of strokes. among four strokes one stroke needs compression. during engine braking, the engine is a dead engine and you are driving it through external force(wheels here). now how much energy do u need to over come the compression stroke for diesel and same stroke for a petrol. do you think here petrol engine need more energy? or diesel need less energy to compress? to be more simple if you have two different fly wheels, one is heavy and the other is lighter, will they need same amount of energy to turn both at same rpm? the heavier one needs more right?
the energy you utilized for compression stroke will be dissipated in the next stroke and eventually null in the exhaust stroke. one more thing that many people believe that diesels doesn't have throttle valve and its not true here. an old matador engine features throttle valve. yes please check it out. modern diesels do have throttle flap and it all depends on OEMs to have or not. the usage of throttle flap is not only for engine braking but for controlling emissions too. certain OEMs prefer to use throttle flap for engine braking instead of a exhaust flap. and both the flaps are not always used for engine braking.
they are more useful in EGR mixing.
exhaust flap offer a mild resistance in the exhaust stroke. only suitable for light duty trucks.
jake brakes or technically 'decompression valves' will offer one more stroke and that's the power stroke. jake brakes are more effective and only used on heavy duty trucks.
a small table explaining the techniques and its usage.
usually the heavy duty trucks will have combination of the above techniques for effective control.
and one more techniq is the VGT. using VGT for engine braking. how? just simple, VGT fins are fully open and this offers back force in the exhaust stroke and as well as pumps more air into the cylinder which requires more force to compression the same.
one more factor you guys need to think of, 'engine displacement is to weight of the vehicle' factor apart from gearing ratios.
the problem with the safari is governor calibration.
star_aqua is offline   Reply With Quote
Old 5th February 2010, 08:19   #62
Sankar's Avatar
Thanked: 4,676 Times
Nice info there. My points are inside the quote.
Originally Posted by star_aqua;1717207[B
][/b]DD, lets go according to your explanation. if you consider a petrol engine and a diesel engine of same displacement, diesel has higher compression then petrol. now both work on same principle in terms of strokes.
>> Yes.
>> Diesel engine needs more energy to compress and once the piston is over tdc the compressed air acts as a spring returning the energy. So most of the energy lost in compressing the air is returned.
>> Take a plastic syringe close its mouth with your finger compress the piston it will bounce back. same principle.
>> Petrol needs very less energy to compress so less energy returned.
But wait! Petrol has its throttle valve closed so there isn't as much air there to compress and infact the petrol engine will be operating in a partial vacuum cycle while the throttle valve is closed. Thats what it gives its engine braking, working against vacuum.
>> Heavy needs more energy and heavy will store more energy and heavier the flywheel lesser the engine braking. Be it petrol or Diesel.
>> Cool info there. So Matador engine with throttle valve will engine brake, because it has a throttle valve. Any engine with throttle valve will engine brake. But most Diesel engines do not use a throttle valve.
>> A butterfly valve in the throttle body is supposedly bad for the efficiency of the engine, be it petrol or Diesel (but Petrol can't do without it so its there). Throttle valve sits there always hurting the flow. This is why Diesels have jake and exhaust brakes, during normal operation it does not affect efficiency of the engine.
>> Diesel engines are more efficient because it uses high compression & compression ignition, diesel fuel have more energy stored in it, diesel engines have better flow & diesel engine have minimal pumping losses. Throttle valve in this hurts flow and pumping loss.
the usage of throttle flap is not only for engine braking but for controlling emissions too. certain OEMs prefer to use throttle flap for engine braking instead of a exhaust flap. and both the flaps are not always used for engine braking.they are more useful in EGR mixing.
>> Nice info there. Any such engines that you know of using throttle valve?
>> No. Its also being used in tractor trailers, many places do not allow the use of jake brakes due to the noise it makes.
>> Jake brake do not offer one more power stroke. Jake brake bleeds the power stroke.
>> Jake brakes are used in lighter trucks too, not just heavy vehicles.
Attachment 281448
>> Yep.
>> Yes, its simple. Its just an exhaust brake but done in trucks with VGT. Resistance provided by a flap in the exhaust pathway is being provided by turbo vanes.
A regular Diesel engine without the aid of all these secondary mechanisms still have less engine braking than a regular Petrol engine.
Any engine with a throttle valve will have engine braking when the throttle valve is closed.
Last edited by Sankar : 5th February 2010 at 08:22. Reason: Underlining for readability
Old 5th February 2010, 10:15   #63
SPIKE ARRESTOR's Avatar
Thanked: 862 Times
Default A small correction
@Dirty Dan- Diesel engines have higher compression ratios not because they have to offer more force to the piston during the downstroke, it is because air has to be compressed to such high values (during constant pressure heating cycle) such that when the fuel is injected in, it automatically starts burning as the fuel has now caused a condition called auto ignition point(177-250 deg C for diesel fuel), also the amount of downforce given to the piston depends on the mean effective pressure(MEP) developed inside the engine which further depends on factors like volumetric efficiency,thermodynamic efficiency, fuel conversion efficiency (Calorific value of fuel). And because compression ratios are so high the diesel engines are made heavier compared to petrol engines. Hope this clarifies,
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 5th February 2010, 10:19   #64
tsk1979's Avatar
Thanked: 16,459 Times
The reason for better engine braking in petrols is the "throttle valve". No such contraption in diesels.
Old 5th February 2010, 10:58   #65
headers's Avatar
Thanked: 464 Times
Not really.. Modern CRDi engines have throttle valves and ensure fuel cut off with respect to accelarator position IMO. The CRDi pump takes care of it alongwith the signal from the ECU.
Old 5th February 2010, 11:19   #66
Thanked: 862 Times
@Headers, Where do CRDi engines have throttle valves? The solenoid switch of injectors gets pulse signals depending on the feedback given by the sensors, this signal is processed according to an algorithm preset in the ECU the ouput is then passed on to the injectors which act as an actuator. The fuel pump (high pressure pump) maintains a continuous pressure head inside the common rail (close to 1600 bar) irrespective of the acc pedal position. Hope it is clear now,
Spike
Old 5th February 2010, 11:42   #67
Sankar's Avatar
Point to ponder:-
In USA why do Diesel truck (pick-up) owners especially with AT transmission go for afer market exhaust brakes and why owners of Gasoline truck with AT transmission do not need any such aids in slowing down?
Owners of these trucks compare the rate of slowing down of their vehicles when they take their foot off the 'go' pedal in their Diesel and Gas trucks.
According to them the need of engine braking in the Diesel trucks is felt more when they have a trailer hooked up to their trucks. Gas trucks naturally offer more engine braking.
Old 5th February 2010, 11:50   #68
headers's Avatar
Thanked: 464 Times
Spike
Spike, Thanks for the clarification.
What sensor gives feedback to the solenoid? The accelerator position sensor?
Maybe I'm wrong in using "throttle valves" in modern terminologies. Me bad..
You are correct that the pressure head inside the common rail is 1600 odd bar. Again how does the injector open and close? Due to the electrical switching solenoids.
The soleniods get their input from the ECU which looks upon the reference table to tell the injector to open or close!
sorry for OT - Have you opened a injector of a modern CRDi Engine?
Old 5th February 2010, 11:56   #69
tsk1979's Avatar
@headers, I think SPIKE_ARRESTOR is a CRD engine guy, regularly experimenting and tweaking engines. Correct me if I am wrong SPIKE_ARRESTOR?
Old 5th February 2010, 12:04   #70
headers's Avatar
Thanked: 464 Times
@TSK - I'm the guy who opens engines and Spike is the guy who does R&D on it [ engines ]and puts it back and educates me too
Old 5th February 2010, 12:56   #71
robinson.s's Avatar
Thanked: 86 Times
Thats a quite a lot of inputs I have to work on my Invader-low gear. Actually, higher the torque on low gear, the better you can preform on extreme off road tracks. Mainly on heavy mud and tough decline on a rocky terrain. In my off road experience, I have driven jeeps live CJ-7, vitara, and dihatsu and these jeeps comes with 4.2 lt cherokee engines / 200 bhp. And all these jeeps will have additional low gear to have better preformance on extreme tracks, specially for speed off road events.
robinson.s is offline   Reply With Quote
Old 5th February 2010, 13:02   #72
Thanked: 862 Times
Hi Headers,
A CRDe engine is a closed loop control system with sensors as input, ECU as controller and Injectors/solenoids as one of the actuators ( i am talking specifically of fuel system). The opening and closing of injectors is controlled through pulses (electrical signals) which is finalised after a lot of calibration/trials, keeping in mind good driveability and FE, yes you are right injectors are controlled through solenoids which get signal from the ECU,yes i have seen a opened injector of a CRDe engine though not opened it myself. i will name a few sensors that find use in a modern CRDe engine Crankshaft position sensor, Camshaft position sensor, HFM sensor, Accelerator pedal position sensor,Boost pressure sensor, Rail pressure sensor,Fuel temperature sensor,Coolant temperature sensor,etc etc, all these sensors are continuously giving feedback to the ECU for further processing.
Spike
Old 5th February 2010, 13:29   #73
headers's Avatar
Thanked: 464 Times
i have seen a opened injector of a CRDe engine though not opened it myself.....
Spike
So we are in agreement then.. Awesome..
I have opened the injector of my old CRDi car myself. Will post some pictures soon for the benefit of the forum.
Old 5th February 2010, 14:10   #74
siddartha's Avatar
Thanked: 24 Times
No clear answer still....as usual
anyway this is what i think. not gonna get into any diesel/petrol, DI/IDI/CRDI etc etc discussion.
i think engine braking is more a funtion of the gearing/ gear ratios and the engine rpm. (and maybe vehicle weight and load on the vehicle)
lets say i am doing 100 kmph in fifth gear in a vehicle, i let go of the accelarator , i will not be getting any engine braking. ONLY when i start to downshift will i get any engine braking.
lets say i am doing 80 kmph in second gear , i let go the accelarator ,i will definitely get engine braking.
In this case, we dont know what gear the starter of this thread had chosen when he made his observations.
also we seem to be getting caught up in subjective terms like "long","steep" etc.
siddartha is offline   Reply With Quote
Old 5th February 2010, 14:55   #75
headers's Avatar
Thanked: 464 Times
@sidd: IMO if you let go of your A pedal, engine braking starts in all vehicles of all types other than Automatics and the ones with freewheeling options [like old vintages]. Ofcourse it is more subjective in some engines and not so in the others.
you will feel like that because of the engine noise/RPM and the gearing.
LOL
Which has more Engine Braking? A petrol or a diesel engine? anilisanil Technical Stuff 3 16th September 2011 14:47
Autocar India & Ford Fiesta achieve 33 kpl? windsurfer The Indian Car Scene 58 22nd August 2011 20:44
How to achieve Max FE in an Opel Corsa? raj_7703 Technical Stuff 22 2nd July 2010 01:17
Max kmpl , and how to achieve it TURBOSAM Technical Stuff 200 6th June 2010 11:28
How to achieve better engine sound? raj_7703 Modifications & Accessories 7 6th November 2009 19:10
