Old 14th February 2010, 08:32   #31
khan_sultan's Avatar
Thanked: 3,466 Times
Originally Posted by Rajachu View Post
Can anyone help me designing a suitable skid plate for Gypsy as last time i have seen the t-case sitting on a rock.i remeber viji was refering something similar this.
Raj
We will be getting quite a few made. Just tell Viji to keep one for you.
Originally Posted by Sha View Post
Design is ready with Vijay, only need to manufacture it.
Yeah, it's about time he got it fabricated.
khan_sultan is offline   Reply With Quote
Old 16th February 2010, 10:48   #32
Rajachu's Avatar
Viji/Shanz. placing an order for that here. pls keep one for me as well.
Raj
Last edited by khan_sultan : 16th February 2010 at 11:17. Reason: fixed quotes & punctuation :-)
Rajachu is offline   Reply With Quote
Old 16th February 2010, 11:10   #33
A-jay's Avatar
Default interested
Guys,
I am interested too. whats the cost invoclved?
since its being fabricated for many we should get a good deal?
A-jay is offline   Reply With Quote
Old 16th February 2010, 15:52   #34
whicked wheels's Avatar
Thanked: 56 Times
Even if it a fabricated in bulk i don't think its going to be cheap. Vijay must have spent some a lot of his valuable time and money designing the Skid plate, this should also be taken in consideration. Dont take the designer for granted.
Hey Kunal hows the progress on your skid plate.
whicked wheels is offline   Reply With Quote
Old 4th March 2010, 12:32   #35
Tejas@perioimpl's Avatar
Thanked: 5,058 Times
Last OTR is managed to dent the exhaust pipe just in front of the skid plate. I didn't beached or stuck though.
This resulted in severe vibrations at idle and getting it rectified now.
Could this have been prevented with a longer skit plate?
Any suggestions to prevent this happening in the future?
Tejas@perioimpl is offline   Reply With Quote
Old 4th March 2010, 12:59   #36
ex670c's Avatar
Thanked: 1,799 Times
Hi Tejas,
The Classic has a very short Skid-Plate, make one based on the design of the Original CJ3B Skid-Plate, which extends under the silencer.
Arka
Old 4th March 2010, 13:07   #37
Originally Posted by ex670c View Post
Hi Tejas,
Arka
Thanks. Is it readily available off the shelf? Or do you have the dimensions and thickness?
Old 4th March 2010, 14:13   #38
svsantosh's Avatar
Thanked: 1,392 Times
The Skid plates are available in Scrap/Gujuri, IIRC. Approx 1K last time I checked. The plate is cheap, but again IIRC, the gear box needs to be removed along with the cross member - thus causing a bigger $ wrt to Labor costs. Gurus - Am I right here?
i) CJ3B/CJ500D/MM540 same skid plate
ii) M&M CLASSIC has a slightly different Skid-Plate
iii) The MM550XD have a Larger Skid-Plate
All the above Skid-Plates are interchangeable.
Arka - I believe the CJ340 falls in (i)? Or is it (ii)?
svsantosh is offline   Reply With Quote
Old 4th March 2010, 14:48   #39
ex670c's Avatar
Default Skid Plate
Hi Santosh,
The 4WD Cross-Member has 4 Holes to mount the Skid-Plate.
Ask Suresh Stephen for exact details; IIRC Type I.
If the Plate fouls with the skid-plate a the old type body mounts/bed (Rubberized Canvas Strip aka Balatta Packing) under the Cross-Member and tighten the nut.
The Original cross-member bolts have a rounded head and Square neck to Lock into the Skid-Plate, while tightening the nut.
Arka
Old 4th March 2010, 16:22   #40
Samurai's Avatar
Thanked: 14,529 Times
Tejas, your skid plates are difference than mine, which covers the pipe well.
Ignore the coolant leak, that was an old problem, this is a very old snap.
Old 4th March 2010, 16:29   #41
Now the hunt begins to get one or then fabricate one. If i do have to get one fabricated, should i go wider since you also have a small dent.
Old 6th March 2010, 11:47   #42
Look at the damage to the old one!
Mahindra Milestone has promised to make a mm540 type skid plate for me. Should i make any modification to that design?
Old 15th March 2010, 22:24   #43
What is the gauge of metal used for the skid plate? Should i go thicker than the existing one?
Old 13th April 2010, 16:40   #44
Thanked: 97 Times
guys i am in the process of building a jeep,
which skid plate?, how is it mounted?, what gauge?
sorry my knowledge on this is pretty less, according to the picture i think that it is bolted on to the cross-member with 4 bolts ,am i right ?
and why can i see holes in the skid plate ?,weight reduction ??
details of my jeep here -
http://www.team-bhp.com/forum/4x4-ve...mix-match.html (my new baby A 4X4 JEEP !!!(no specific model because its all mix and match))
garrett_t16 is offline   Reply With Quote
Grand Vitara gets custom made skid plates Samurai 4x4 Technical 107 11th October 2016 10:47
Skid Plate for Innova CDM Modifications & Accessories 5 17th May 2010 15:51
Cute air freshener hangy thingy EDIT - Anti skid mat thingy from Page # 19 Sam Kapasi Shifting gears 622 31st October 2007 18:09
How can we drive out safely from a skid? vnabhi Street Experiences 28 12th October 2007 10:37
Bike Skid on the way to Hogenakkal benbsb29 Street Experiences 6 30th January 2007 15:07
